Old 08-14-2021, 12:21 PM   #26
Getter-Done
Getter-Done's Avatar
Re: Low mileage 1987 Chevy 1/2 ton to 3/4 ton - Undoing the hacks!
Great deal on the tailgate.
Your'e making good progress
84 Chevy K-20
Old 08-15-2021, 11:41 AM   #27
Nick_R_23
Nick_R_23's Avatar
Thank you! More progress this weekend. Painted all of the engine’s sheet metal.
I picked up a new single roller timing set, the factory one had more chain play than I really wanted to see. I also got new upper and lower oil pressure sensors, knock sensor, coolant temp sensor, thermostat and gasket, EGR gasket, and an oil filter.
New timing set installed!
New front main seal, timing cover, and new water pump installed.
Rear main seal, oil pan, and oil filter installed!
I poured some oil in the pan and spun up the oil pump, and we have oil at the rockers! Installed the valve covers, harmonic balancer, and some of the new sensors.
Old 08-15-2021, 08:11 PM   #28
Nick_R_23
Nick_R_23's Avatar
Finished up with most of the accessories. Still have the power steering plus one or two small things, but the alternator, A/C, pulleys, exhaust, and minor other parts are on!
Old 08-16-2021, 12:32 AM   #29
LT7A
I like seeing the TBI getting all cleaned up. Looks good. It is the stock TBI water pump aluminum? It looks like it in the picture.
Old 08-16-2021, 02:48 AM   #30
Nick_R_23
Nick_R_23's Avatar
Thanks! And no, they’re just regular cast iron. However, this is a “-P” water pump from Napa, which is supposedly higher flow and better internals than the typical stock replacement.
Old 08-28-2021, 04:18 AM   #31
Nick_R_23
Nick_R_23's Avatar
I managed to nearly finish up the engine today! Finally got both of the correct oil sensors in from the parts store.
I finished painting the rest of the accessory drive, as well as a few bolt on pieces. I also replaced all the belts.
Finally, cleaned and rebuilt the throttle body as the last project for the night.
Old 08-29-2021, 04:14 AM   #32
Nick_R_23
Nick_R_23's Avatar
Painted the final remaining engine parts
Old 08-29-2021, 08:09 AM   #33
Greenlee
Greenlee's Avatar
Looking good. Nice work!
Greenlee is offline   Reply With Quote
Old 08-29-2021, 09:40 PM   #34
Nick_R_23
Nick_R_23's Avatar
Thank you!
Since the biggest portion of this project is looming near (swapping the cab over), I decided to use this weekend to repair the hole cut in the bed, since I won’t be able to access it once the cab is on. Started out by bending some metal as filler pieces.
The hole I’m dealing with.
Cleaned up the area.
Cutout traced.
Old material cut out.
Started on the inside piece due to easier access from the front.
Front piece welded in!
Cleaning up the welds.
Applied some primer.
Not completely perfect, but far better than what was there!
Also bolted the last of the accessories to the engine, the fan, dipstick, and motor mounts.
Finally got around to painting the transmission as well! Primer applied
Paint applied!
And tape off!
Old 08-30-2021, 08:53 AM   #35
lunatic1968
Nice work!! I see you invest in Brake Kleen like I do.
lunatic1968 is offline   Reply With Quote
Old 08-30-2021, 09:04 AM   #36
Nick_R_23
Nick_R_23's Avatar
It’s been on back order for months! I didn’t want to take another chance Chevy LS oil filters are the same way. Back ordered for almost 90 days now.
Old 09-01-2021, 10:13 AM   #37
84 400
Sb 400 club
84 400's Avatar
Old truck looks yo have some cool home bree 4x4 parts like front shackle mounts and crossover steering. Nice progress!
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 09-04-2021, 02:22 AM   #38
Nick_R_23
Nick_R_23's Avatar
Right? Whoever built it had good intentions, just poor execution
I painted the front panel on the bed, since it won’t be accessible once the cab is swapped over.
I also pulled the transmission (going to a friend), and transfer case, which will be getting a rebuild.
Old 09-05-2021, 03:18 AM   #39
Nick_R_23
Nick_R_23's Avatar
Small progress today, painted and transferred the shift lever from the old transmission!
Old 09-06-2021, 12:29 PM   #40
lunatic1968
Nice progress, that's crazy about the filters,maybe I need to go buy 2 more just for my break in time .
Old 09-09-2021, 12:40 PM   #41
Nick_R_23
Nick_R_23's Avatar
Thanks!
I started on the transfer case rebuild yesterday, and it turned into a disaster.
First, I noticed large metal chunks everywhere with no real source.
Found a shift fork partially worn through.
Front output shaft thrust surface destroyed. Bearings were missing.
Input shaft grooved, bearings weren’t removable. Looks like they had spun in the case as well.
Synchro worn in an almost impossible way.
So, this 208 is officially junk!
I picked up another 208, dirty, but with low mileage for $50. These internals are much nicer!
Old 09-09-2021, 11:12 PM   #42
Getter-Done
Thanks for sharing the Pictures.
That is what I have in my 84.
84 Chevy K-20
