Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-07-2021, 12:16 PM   #3276
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16100353309602190201967324232011 by James Jaros, on Flickr
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-07-2021, 12:42 PM   #3277
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16100376010412674429208406588402 by James Jaros, on Flickr
Don't lose roll pin or wave washer as they don't come in the package
SAFETY FIRST
AS usual, off topic
Jim
Old 02-07-2021, 10:49 AM   #3278
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Now you did it big time,jinx
16127092134329001020493342322196 by [url=https://www.flickr.com/photos/97391199@N06
But, 70 degrees in the shop
SAFETY FIRST
AS usual, off topic
Jim
Old 02-07-2021, 10:56 AM   #3279
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: PO has me PO'd
Looks real pretty though. It’s -19 here right now.
Old 02-07-2021, 11:03 AM   #3280
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Started a jig to support window frame
1612709999404596003859227051884 by [url=https://www.flickr.com/photos/97391199@N
SAFETY FIRST
AS usual, off topic
Jim
Old 02-07-2021, 11:05 AM   #3281
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
thats my record temperture for fishing in NY for steelhead
Time to start up snowblower
SAFETY FIRST
AS usual, off topic
Jim
Old 03-17-2021, 06:46 PM   #3282
bcfishon
Re: PO has me PO'd
Did someone mention steelhead?And cold, nay I say Oregon
bcfishon is offline   Reply With Quote
Old 03-28-2021, 10:27 AM   #3283
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thats a great looking fishing hole, enjoy
SAFETY FIRST
AS usual, off topic
Jim
Old 03-29-2021, 11:01 AM   #3284
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
161702980659020955855144450075 by [url=https://www.flickr.com/photos/97391199@N06
The other day I was looking thru the classifieds and came across a thread for parts needed for wind windows, followed the link to car and truck site
They had the division bar in shock, ordered the part and was happy with what I received, but, I didn't read the note which mentioned the original felt channel that was not included
Ordered that part and was even more pleased with parts
Originally what was supplied was a sticky thin piece of felt, which may have worked, but was the wrong thickness for the glass, so if you order the division bar, don't cheap out. Buy the felt with it as recommended in the notes
The bead on the division bar is exact replica
Now, I have to drill all the holes for the rivets
SAFETY FIRST
AS usual, off topic
Jim
Old 04-05-2021, 09:55 AM   #3285
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Drilling new holes in division bar, stainless steel ,so make sure to use a cutting fluid, or you may work harden material
16176305772346572405670059651929 by 16176304306102791501434747171038 by [url=https://www.flickr.com/photos/97391199@N06
Using old division bar as a template
SAFETY FIRST
AS usual, off topic
Jim
Old 07-10-2021, 09:43 AM   #3286
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16259242469812399531286890872079 by [url=https://www.flickr.com/photos/97391199@N06
Been working on my aftermarket doors, couldn't get the gaps right, so I tried something extreme, I jacked the body up, about 1 inch and got the gap you see.
Now just have makeup a body mount to fit
SAFETY FIRST
AS usual, off topic
Jim
Old 07-10-2021, 09:49 PM   #3287
litebulblsc
litebulblsc's Avatar
Re: PO has me PO'd
1 inch seems like alot to shim a body mount
litebulblsc is offline   Reply With Quote
Old 07-11-2021, 09:32 AM   #3288
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Well actually the original mount is 1/2” and the space to get the door lined up is 1/2”, so considering age of truck maybe the rubber mount is shot. Don’t know what size they should be
Thanks for the input
SAFETY FIRST
AS usual, off topic
Jim
Old 07-22-2021, 11:34 AM   #3289
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Picked up a new helmet from yes welder, about 60 dollars, needed one for awhile
16269677645786977449666548940319 by 16269680015024971326383071013235 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 08-03-2021, 10:19 AM   #3290
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
New tool 300 watt American beauty soldering Iron
Don't want to use bondo, just lead
1628000088984249214174123495496 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 08-03-2021, 10:48 AM   #3291
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Correct thickness to get my door gaps, oem on right side
16280019717295277883792602035810 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 08-03-2021, 11:08 AM   #3292
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Gaps look workable
16280031752258545380681853025694 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 09-13-2021, 10:35 AM   #3293
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16315432678685759242049036878614 by [url=https://www.flickr.com/photos/97391199@N06
Started to grind down welds to see if leading works waiting on tinning butter to arrive from eastwood
SAFETY FIRST
AS usual, off topic
Jim
Old 09-16-2021, 10:14 AM   #3294
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2mrk3Px]
Working on my weatherstripping ,making sure my door closes right, I put down 1 layer of cement, dry to the touch, then add 1 more wet and clamp in place
Once you get it started its easy to turn inside out or backwards to apply glue
SAFETY FIRST
AS usual, off topic
Jim
Old 09-16-2021, 01:28 PM   #3295
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16318049326633600541790131990024 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 09-26-2021, 08:19 AM   #3296
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16326585196707778945394499907987 by [url=https://www.flickr.com/photos/97391199@N06
Don't know where this gap came from, nor how to fix
SAFETY FIRST
AS usual, off topic
Jim
Old 09-26-2021, 10:12 AM   #3297
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16326654041606314819141062400952 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 09-26-2021, 11:01 AM   #3298
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16326682957322477564073761525475 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 09-26-2021, 11:40 AM   #3299
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Computers are out for safety
16326685308443721197222329170359 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 09-29-2021, 11:11 AM   #3300
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16329245714681929701592013281691 by [url=https://www.flickr.com/photos/97391199@N06
Chase threads
SAFETY FIRST
AS usual, off topic
Jim
