10-04-2021, 09:24 PM | #1351 |
Re: What did you do to your truck today part IV
I have similar headers on my 68'. I have been very happy with them.
68' with no bells or whistles unless I add'em. |
10-04-2021, 11:21 PM | #1352 |
Sand blasted the cab today in driveway, will put in primer tomorrow, did the bottom of cab and roof a few days ago, messy job! |
10-05-2021, 03:14 PM | #1353 |
Broke the back glass replacing the rubber. Ordered a new one.
10-05-2021, 09:15 PM | #1354 |
I put the toys in the back that I'm going to take to the toy drive this weekend. It's a car show toy drive. Pier 50 San Francisco
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
10-05-2021, 10:20 PM | #1355 |
10-09-2021, 07:13 PM | #1356 |
Started painting my new wheels today. I've had these for almost 2 years, but was waiting on needing new tires
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 10-09-2021 at 07:29 PM. |
10-09-2021, 07:21 PM | #1357 |
Looks good Christian...that is patience!
10-09-2021, 07:29 PM | #1358 |
Thanks, Andy! I didn't feel like paying to have the tires swapped over to the new wheels when I first got them, so they sat in those boxes on the shelf since
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-12-2021, 12:47 PM | #1359 |
New tires on. More pics in my build thread
10-12-2021, 01:06 PM | #1360 |
new wheels / tyres and those hub caps look tough
1965 c10 project - how does all this stuff go back together... |
10-12-2021, 09:56 PM | #1361 |
Thank you! I'm very happy with them so far
10-12-2021, 09:58 PM | #1362 |
What wiper delay kit did you use?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
10-13-2021, 11:16 PM | #1363 |
Cab interior in primer!
10-14-2021, 09:27 PM | #1364 |
Blasted my wheels and painted them. Got new tires.
10-16-2021, 02:32 PM | #1365 |
Installed KYB Gas-A-Justs to try to keep the top of my tires off the fender well. They help some over the standard Monroes, but still touch when in tight corners.
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" |
10-24-2021, 02:54 PM | #1366 |
Gettin ready to pull the lowered rear leafs and switch over to a nolimit 4 bar.
11-07-2021, 09:58 AM | #1367 |
Have a converted short bed with an LS and a th 400. Had terrible vibration at 70 mph. Shimmed rear 2 degrees down and trans 1 degree up per spicer calculator. Problem solved
11-07-2021, 11:58 AM | #1368 |
11-09-2021, 02:49 AM | #1369 |
So true. I have 4" drop springs I can't use because my Monroes couldn't handle them. These KYBs raise the front slightly, unfortunately, and there's still the occasional rub. Might work if I had shorter front wheels.
11-11-2021, 12:53 PM | #1370 |
I put the doors, fenders, cowl, & cowl extensions back on the truck for the last time until final prep and paint. I still have to work on gap alignments on the cowl extensions, cowl, and hood, and I also need to block out the hood.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
11-11-2021, 12:58 PM | #1371 |
11-11-2021, 06:12 PM | #1372 |
Pdx what is your plan for color?
11-11-2021, 07:49 PM | #1373 |
Greased all of the front end zerk fittings...didn't realize there were so many! Hopefully that will take care of my squeaking front end.
11-11-2021, 07:50 PM | #1374 |
Starting on replacing the bed floor. I have a '72 parts truck with a steel floor bed. I am going to cut down the bed floor and adapt it to the stepside . It will be reversable. I will do a wood floor when I build the truck into a hotrod. I just want it usable now on the cheap. I have the parts and the skill and the time just no money for the replacement bed parts right now.
11-11-2021, 07:51 PM | #1375 |
This looks great, can’t wait till I’m near this state!
