12-06-2021, 08:13 AM | #51 |
Re: LS turbo advice needed...
It takes up one of your already limited input's with the term x, only real advantage would be for data logging to see if you have a fuel supply issue under load.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
12-06-2021, 07:50 PM | #52 |
the fuel pressure doesn't take up any inputs, it is nice to have for fuel pressure monitoring, you can also setup a safety with it. I don't think the term x uses the fuel pressure for any fueling calculations. A $10-50 sensor and some table scaling you could have actual pressure displayed is pretty easy.
Are you running a boost reference 1:1 fuel pressure regulator? |
12-06-2021, 09:38 PM | #53 |
Mine has the factory 2001 truck intake with the vacuum regulator and return line.
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
12-07-2021, 02:18 PM | #54 |
it would probably be helpful to have the fuel pressure reading just to keep an eye on it. i believe there's an adapter fitting on the market for the fuel pressure schrader valve to 1/8" npt thread.
12-08-2021, 07:22 AM | #55 |
My bad, I've been looking at so much different holley stuff lately I don't know why I forgot the term x has the provisions for it built into the harness. So with that being said like akdg87 said, pick up a sensor, I recommend looking into low dollar motorsports for a sensor vs an over priced holley sensor. It's a handy thing to have for sure.
01-29-2022, 06:05 AM | #56 |
Gentlemen,
Only just discovered there is an LS section on the board so a bit late to the party! Unlike the OP I am new to Both LS swaps and turbo but have been learning as much as I can over the past few years so when I started back on my truck last year I had the majority of parts and knowledge to get to the burn outs and ice cream stage as quickly as possible.. If you have not watched Matts series yet I would highly recommend it https://youtu.be/X1v7b3ewAUg Also watch this. https://youtu.be/0NWLJt6SFwU Bit out of date now but it is what I am using as my build recipe Look forward to following your build. P.
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
