Old 11-30-2021, 11:02 AM   #1
Toro
Toro's Avatar
Rear seat floor mount leveling shims
Pretty sure these aren't re-popped, but wondered if someone had ever made up a batch and had some left over. Or had luck removing a good set. The ones I've seen or tried to remove almost disintegrate. Thanks, Jon.
Toro is offline   Reply With Quote
Old 11-30-2021, 11:42 AM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Rear seat floor mount leveling shims
Can you post a photo of what you're describing? I'm drawing a blank as to what these shims are. I've just seen the rear seat bolted to the floor without shims.
Old 11-30-2021, 11:54 AM   #3
Toro
Toro's Avatar
Like these four in the picture. They allow the back legs on the rear seat to sit level across the ridges in the bed.
Old 11-30-2021, 01:09 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Gotcha. I've not seen those reproduced FWIW.
Old 12-01-2021, 01:51 AM   #5
Tmend
Tmend's Avatar
Have these they’ve been media blasted. One on far left has a minor rust through
May need to go through the for sale section not sure. Thanks much , Thomas
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old 12-08-2021, 04:32 PM   #6
caseyfromMO
How many do you need? All of them?
caseyfromMO is offline   Reply With Quote
Old 12-08-2021, 10:16 PM   #7
Toro
Toro's Avatar
Yes, all four.
Old 12-08-2021, 10:18 PM   #8
Toro
Toro's Avatar
Attachment 2149175
Attachment 2149176
Yes, those are them. Looks like they came off better than mine did.
Old 12-09-2021, 10:18 AM   #9
hemi43
hemi43's Avatar
Those can easily be reproduced anywhere.
If anyone is interested, I can make a DXF file that you could use at your local fab shop with a plasma/laser table.
I will need dimensions.
hemi43 is offline   Reply With Quote
