Old 11-17-2021, 09:33 PM   #126
JJH Jimmy
JJH Jimmy's Avatar
Re: Budget Build 1985 K20
I been working on this thing whenever I get time in hopes that I will be driving it next summer. We’ll see!
Got the axles and springs off the frame then blasted and painted. One of the leafs in the rear spring pack was cracked so I had a local spring shop make me a new leaf. I swear this thing was jumped a time or two in its life!
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 11-17-2021, 09:49 PM   #127
JJH Jimmy
JJH Jimmy's Avatar
Next up was the front axle and frame. I was hoping to just clean up the front axle since the previous owner already put new ball joints in it but when I was using my engine hoist to get it in stands it had oil pouring out the axle tube. Crap! New axle seals are in order along with seals bearings brakes and new ball joints I guess.
I also had to weld new shock mounts on the front axle. Did I mention I think this thing might have been used a a Fall Guy truck?
I also farmed out the blasting of the frame. Best $200 I ever spent. This was only the second thing that I have farmed out on this build. The first was the tranny rebuild.
1985 Chevy K20
1994 GMC Yukon
Old 11-17-2021, 09:56 PM   #128
JJH Jimmy
JJH Jimmy's Avatar
Now let’s get some epoxy on this stuff!
I also cobbled together a frame rotisserie. It worked great.
I think I now have most of everything painted! Time for the fun part assembly. But first I think I will clean my shop floor!
1985 Chevy K20
1994 GMC Yukon
Old 11-17-2021, 10:09 PM   #129
OutlawDrifter
Looking good man!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 11-18-2021, 05:05 PM   #130
youngrodder
youngrodder's Avatar
Man you are cranking. Great progress.
Keep it up the white stuff is coming....
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-18-2021, 11:36 PM   #131
Willowrun
Willowrun's Avatar
Very nice work!
Old 11-29-2021, 09:20 PM   #132
JJH Jimmy
JJH Jimmy's Avatar
Looking good man!
Marc
Originally Posted by Willowrun View Post
Very nice work!
Thanks guys!
1985 Chevy K20
1994 GMC Yukon
Old 11-29-2021, 09:24 PM   #133
JJH Jimmy
JJH Jimmy's Avatar
Made some progress on assembly this weekend.
1985 Chevy K20
1994 GMC Yukon
Old 12-03-2021, 11:30 PM   #134
JJH Jimmy
JJH Jimmy's Avatar
Shocks on, engine stands on, sway bar on, brake lines done and back on 4 tires. I also pulled the crate motor out that I bought earlier in the summer. I was planning on going with the GM 350/357 but they upped the price by $1200 so I settled on a Blueprint 355 that has about 400 HP and 420 ft/lb of torque. This is a budget build after all!
1985 Chevy K20
1994 GMC Yukon
Old 12-03-2021, 11:41 PM   #135
OutlawDrifter
That Blueprint setup should do the job!
Rolling chassis looks good ��
1991 Z/28, 6.0L/T56
Old 12-04-2021, 12:18 AM   #136
evan
evan's Avatar
There's not much better than seeing a clean chassis get assembled.
Evan B.
evan is offline   Reply With Quote
Old 12-04-2021, 05:40 AM   #137
legendman
legendman's Avatar
Coming along nice !! Frame came out sweet.
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 12-08-2021, 02:48 PM   #138
youngrodder
We have a rollin chassis. That is one of those milestones on a frame off build. Looks great.
Marc
Old 12-11-2021, 12:41 AM   #139
JJH Jimmy
JJH Jimmy's Avatar
Thank you!
I agree.
Thank you!
Marc
It sure is. It feels good to be putting stuff together instead of taking stuff apart.
1985 Chevy K20
1994 GMC Yukon
Old 12-11-2021, 12:48 AM   #140
JJH Jimmy
JJH Jimmy's Avatar
Drive line is in. Time to build the exhaust. My favorite part.
1985 Chevy K20
1994 GMC Yukon
Old 12-13-2021, 07:02 AM   #141
LT7A
Clean work, that chassis looks great! I really like the sheen on that paint. What did you use?
Old 12-13-2021, 10:35 AM   #142
JJH Jimmy
JJH Jimmy's Avatar
Thank you! It is SPI black epoxy.
1985 Chevy K20
1994 GMC Yukon
Old 12-13-2021, 10:22 PM   #143
JJH Jimmy
JJH Jimmy's Avatar
I got some exhaust pipe tacked up. I just need to build some hangers and pull it out to do the final welding.
1985 Chevy K20
1994 GMC Yukon
Old 12-14-2021, 08:58 AM   #144
OutlawDrifter
Nice, looks clean!
1991 Z/28, 6.0L/T56
Old 12-16-2021, 11:04 PM   #145
JJH Jimmy
JJH Jimmy's Avatar
Getting some welding done tonight.
1985 Chevy K20
1994 GMC Yukon
Old 12-16-2021, 11:36 PM   #146
Willowrun
Willowrun's Avatar
It's clear now that you were serious when you said the exhaust is your favorite part and not being sarcastic. It looks great. Do you mind sharing any of your secrets on building an exhaust like that? Do you start with some sort of kit?
Full disclosure I'll probably never put together another exhaust as it's not one of my favorite things to do but still interested in how you do it.
Old 12-17-2021, 12:02 AM   #147
OutlawDrifter
Nice welds!
1991 Z/28, 6.0L/T56
Old 12-20-2021, 09:33 PM   #148
JJH Jimmy
JJH Jimmy's Avatar
No kit. Just some tube and a box of elbows. There is no real secret other than an angle finder and some masking tape. I like to cut the tube and tape it to the elbows for mock up. Then I when I have things like I want them I mark them with a sharpie and take them to the bench to tack them. I will then put them back on and continue with the next piece of tube and fitting until I have a section done to weld.
I like to try to make both sides as symmetrical as I can get them and brush and clean the welds when I am done. I see a lot of guys leave the blue on weld when they are done welding but I just prefer it clean and shiny.
1985 Chevy K20
1994 GMC Yukon
Old 12-20-2021, 09:35 PM   #149
JJH Jimmy
JJH Jimmy's Avatar
Nice welds!
Thanks! The older I get the harder it is to see welding! It was way easier when I was young. I have upgraded my hood to a 2.0 cheater and the shade is on 9! Haha!
1985 Chevy K20
1994 GMC Yukon
Old 12-20-2021, 09:42 PM   #150
JJH Jimmy
JJH Jimmy's Avatar
Exhaust is all welded up and installed as far as I am going to take it until I get the bed bolted back on. When the bed goes back on I will finish the exit pieces.
I also installed an ep381 fuel pump on a 87 sender for the fuel injection going on……..if it ever shows up!
1985 Chevy K20
1994 GMC Yukon
