#701 | |
Re: My 1970 GMC “Project Splice”
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#702 |
IDK Kyle is going pretty fast compared to me haha
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
#703 | |
![]() Join Date: Sep 2015
#704 |
Haha thanks guys! Hopefully more progress coming soon. I have been replacing the garage door opener today. Old one was getting a little scary.
#705 |
I finally got around to making a template for my cargo light off of my dad's truck. I know I should have done it before I did the body work but I wasn't able to access my dad's truck until recently and mine has a cap in the way. Now I have to touch up the filler around where I cut as the heat from cutting cause the filler to let loose a bit.
#706 |
Looks like an awesome build, just looked over your thread. I’m in warman and almost to the same point on my 68. Where did you get your harness? Rpm?
"Lifes to short to drive an ugly truck." Project 55 To Life http://67-72chevytrucks.com/vboard/s...d.php?t=432994 |
#707 |
Thank you! Yes I picked it up at RPM.
#708 |
Do you have a build thread for your 68?
#709 |
#710 |
Haha yeah this guy is my uncle.^ Was wondering if you guys had met already or not both being in Warman. I'll assume not
#711 |
Cab is definitely coming along great. Are you planning on doing the inside of the cab, also?
#712 | |
#713 |
Kyle your persistence is impressive man. You are building one sweet truck and I can't wait to see the future progress on it
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
#714 |
Thanks man! Means alot coming from you, I've enjoyed all of your builds.
#715 | |
Like much to look at yet. Lol
#716 |
Well tonight kinda sucked. I feathered the filler back in around my cargo light hole and went to set the rivnuts. For some reason or another, the damn things went offset and crooked. One offset left but at least stayed straight to the panel. The other offset upwards and went crooked as well. I could not even get the screw into it all the way. There was no way the light was going fit properly or sit straight. So that was a bust, spent more time trying to remove them without damaging my filler than I did getting them in.
#717 |
Alright so I think I now know what went wrong the other night. I believe that the Rivet nuts I had were made for thicker metal. Thus when I riveted them into place, there was too much crumple zone causing them to move on me. I have gotten a hold of some shorter ones and a nice new tool to set them. Hopefully I will find some time tonight to see how they work. You live and you learn.
#718 |
So much better!
#719 |
Here is where my theory about the longer vs short comes in. As you can see, the longer ones crimped very poorly compared to the shorter.
#720 |
I borrowed my Dad's cargo light tonight to do a test fit. Couldn't have turned out any better!
#721 |
I got some more filler done on the drivers cab corner today. I'm getting so close to primer, I can almost taste it.
#722 |
You just keep plugging away. I've been really lax because it's been in the teens here and my garage has been in the 20s. I don't have the ambition to go out and heat it up. lol
#723 | |
#724 | |
![]() How do you heat your shop/garage? Mine is a small propane bullet heater and I also have one of those infrared heaters on a stand. I hate the cold. I don't know how you deal with those temp. ![]() |
#725 | |
