01-22-2022, 01:18 PM | #1 |
Help with Frame ID
This frame has a cab off a 66 but the owner thought maybe the frame is a 67-72. I figured the professionals here would know what it is.
72 Chevy C20 86 Silverado Shortbed |
01-22-2022, 02:29 PM | #2 |
Re: Help with Frame ID
A good picture of the bumper would help.
From that picture that appears to be a 67-70 bumper. From research of other threads. That it is probably a 1970 frame from St. Louis. Because partial VIN's are stamped on the frame. The first digit on the frame would be the 5th digit in the VIN of the truck. 5th digit is last number of the year and 6th digit is Assembly plant. Link: https://gmcpauls.com/67-72_chevy.htm
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 01-22-2022 at 04:11 PM. Reason: Update |
01-22-2022, 03:42 PM | #3 |
Okay thanks! I was looking in other threads but I couldn’t figure out how the frame number meshed into the VIN. I’ll see if I can get a picture of the bumper.
01-22-2022, 04:21 PM | #4 |
Also is it possible that the 0 could be 1960?
01-22-2022, 04:29 PM | #5 |
I think the 60-62 frames look like this,
From what I have read on here the front bumpers won't interchange from the 60-66 to a 67-70 frame.
01-22-2022, 05:14 PM | #6 |
Okay thanks! Here is the front bumper.
01-22-2022, 05:35 PM | #7 |
With pictures from the forum.
Here are the60-66 bumpers they have different bolt spacing also.
01-22-2022, 06:28 PM | #8 |
Ya that’s certainly not the same bumper. The frame must be a 70 then. Thanks for the help.
01-23-2022, 12:39 PM | #9 |
I see disc brakes
01-23-2022, 01:10 PM | #10 |
I believe the front is a d44. Maybe converted or out of a newer truck?
01-23-2022, 05:42 PM | #11 |
All about them K’s
Definitely a 70 4x4 frame. I’m guessing K10 long bed. That’s a th350/205, looks like it’s got the ‘70 only automatic tranny transfer case shifter still there as well. Also looks like the transfer case crossmember is still riveted. Front axle had to have been swapped at some point but still a great find if the rust isn’t too bad, which it doesn’t appear to be.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
01-23-2022, 06:35 PM | #12 |
Fantastic thank you. The block casting is 330817. Looks like it’s a 400 small block. Did these trucks come with a 400sbc?
01-23-2022, 07:20 PM | #13 |
All about them K’s
No sir, no big blocks or 400 small blocks for the 4x4 trucks. The 350 was the biggest V8 you could get in a 67-72 4x4.
That should be a 400 casting. Not a bad score at all if it’s still good.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 Last edited by 57taskforce; 01-23-2022 at 07:28 PM. |
01-23-2022, 07:58 PM | #14 |
Okay thank you. Time to negotiate.
