01-21-2022, 06:38 PM | #1 |
Did GM ever publish a GCWR list?
Just like the title says - did GM ever publish a list of GCWR’s for Squarebody trucks? GVWR is easy to find, but not GCWR.
Planning a cross country move within the next couple of years and looking to stay DOT legal. Truck was originally a 1978 Chevy K20, 6800# GVW, 350-4, SM465, 3.73 gears, vacuum brakes. |
01-22-2022, 04:34 PM | #2 |
Re: Did GM ever publish a GCWR list?
They are called the trailering guide.
Some appear in the brochures and some in the generic info packets, but not with any regularity. Next time I come across one I'll post it up. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
01-22-2022, 06:05 PM | #3 |
Who Changed This?
Here ya go. It's for '74 but shouldn't be that different.
01-23-2022, 08:30 PM | #4 |
Well done, Steeveedee.
I see my work here is finished. K
01-24-2022, 02:11 AM | #5 |
Thank you guys! Keith, I recall you mentioning before that you evaluated some of these ratings by “launchability”. Was there much design behind that aside from larger engines and deeper gears?
Quite a bit of this truck has been changed since new. It now has Camper Special springs and full floating rear axle, a 5.3L, and hydroboost brakes. It appears from the factory that it was designed as a 9500 GCW, but I’m curious of your opinion on what you think this truck would class in the same test today with these modifications? |
01-25-2022, 11:56 AM | #6 | ||
Really the only knob I was allowed to touch would be to recommend dialing up or dialing down the trailer rating, if needed. Quote:
In any case, if you are trying to stay "DOT legal" you better stick to the published number. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-25-2022 at 12:04 PM. |
01-25-2022, 09:10 PM | #7 |
It’s definitely better, was just more curious of a guess of what it may have achieved in the same test today.
