Old 01-25-2022, 12:21 PM   #1
Bowtiguy
Bowtiguy's Avatar
DEAL ALERT: 1968 C/10 restomod at barret jackson on thursday
This is not a for sale post.
I built this truck back in 2016 with the help of this group. Unfortunately, I never had the time to do a build thread. I sold it last summer for $40K to what turned out to be a high end car flipper. He's running it across the auction block this thursday close to some other well know builds off this site.
This could be a steal of a deal due to the fact that I never did any paint work and its a good 20 footer in appearnce. Mechanically, IT IS DIALED!
Link to the auction.
https://www.barrett-jackson.com/Even...-PICKUP-251912
Build stats...
Original Colorado 1968 short wood bed C/10
-all original Colorado metal with the exception of the ( bed header panel, wheel tubs & rockers).
Features
-Aluminum 5.3l (327) LS engine
-TR6060 6 speed transmission w/ hydraulic clutch
-5 lug 4 wheel power disc brakes
-No Limit Engineering ( NLE) suspension throughout
-NLE power Rack & Pinion steering
-Stainless steel 2.5” custom exhaust
-Vintage Air heat
-Optima battery relocated passenger side frame rail under bed
-Complete composite bed
-No Limit Engineering underbed mounted fuel tank.
-3” front, 5” rear static drop (CPP springs & ridetech adjustable shocks)
Engine/Driveline
-2012 all aluminum 5.3L LS engine with 243 heads. Completely stock with VVT, no DOD, complete GM truck front drive system.
-MSD atomic EFi sytem
-2014 Tremec TR6060 transmission w/ GM LS3 hydraulic clutch
-CORE/ Hurst shifter assembly
- Custom Driveshaft shop aluminum driveshaft ( $1000 w/ C/V input from trans).
-Original 12 bolt rear end modified by Mark Williams Enterprises. ( 4:10 gear, eaton posi, MW master line axles, shortened axles for correct wheel offset, c-clips eliminated, `1350 series yolk, HD aluminum rear cover).
-New U bolts
- 20” ridler wheels ( 255 front 295 series rear).
Fuel System
-NLE under bed mount Baffled aluminum fuel tank. Serviceable from under the truck
-Walbro 255lph fuel pump
-Holley Hydromat system
-PTFE return style fuel line system
Chassis
- Factory original short bed frame rails
- NO REAR C NOTCH!!!
- ALL rivets removed/replaced with grade 8 hardware
- NLE front/rear frame cross braces
- NLE transmission brace
- CPP Trailing arm crossmember
- blasted/powder coated radiator core support
- front wheel tubs were blasted/powder coated/raptor liner on the underside
Suspension
Front
- CPP 2”drop spindles
- CPP 1” drop spring
- MOOG ball joints
- Energy suspension bushings
- All parts blasted/powder coated
- NLE front sway bar ( custom heim joint end links)
- RIDETECH adjustable shocks
- POL front shock mount relocation
Rear
- Stock powder coated trailing arms
- NLE Pan hard bar
- NLE shock relocation
- 2” CPP lowering block
- 2”CPP lowering springs
Brakes
-CPP big brake kit ( 13” front, 12” rear)
-Stainless braided lines
- Power brake booster
-CPP brake bias controller
-In line tube stainless steel lines everywhere
-Hawk HTS brake pads
-Parking brake assembly functional
Interior
-Custom blue/black hounds tooth seat cover w/ new foam
- Original GM 67’ fold forward bench seat (blasted & painted)
-Custom vinyl/sewn door panels ( NOT welded vinyl reproductions)
- ALL NEW weather stripping
- Roll up windows and vent windows have been completely restored
-GM logo 3 point belts ( 2 point in the center)
- New matching dash pad
-Period correct silver loop carpet from ACC
- Matching loop floor mats from ACC
- Complete Painless Wiring harness interior, engine bay & chassis
- Nu Vintage Guage set
- Vintage Air heater/defroster
- New window seals
- ALL original tinted glass ( vent windows are reproductions)
-IDIDit tilt steering column w/ GM reproduction corvette “wood” steering wheel
Cooling System
- Full size brass reproduction radiator
- GM hoses
- 180 degree thermostat
- DUAL spal electric fan assembly controlled by the Atomic MSD system
Exhaust
-Doug Thorely Tri Y coated headers
- custom 2.5” staines tubes (with H pipe)
- Borla Pro XS mufflers ( turned down before rear axle)
Body
-Colorado rust free original metal truck ( Bed header panel, bed wheel tubs, rockers are AMD metal).
-Repainted 7 year ago by the previous owner
-Original 50th anniversary fender badges
-reproduction grill and headlight surround trim
-reproduction chrome bumpers
- Blasted/ powder coated hood hinges
- side trim and turn signal delete by previous owner
BED
-support rails were blasted/powder coated
-bed wood upgraded to high grade capped decking material
-ALL factory bed strip mounting points were reused ( no new holes)
-136 Stainless steel fasteners were assembled w/ anti-seize
- New AMD wheel tubs ( raptor liner applied to the underside).
-New AMD header panel
- original tail gate
-new bed mount isolators
Bowtiguy is offline   Reply With Quote
Old 01-25-2022, 12:44 PM   #2
jimijam00
Re: DEAL ALERT: 1968 C/10 restomod at barret jackson on thursday
Kinda cool, but it will sell for more than it's worth. Not my definition of a deal, but I'm sure the buyer will think so.
jimijam00 is offline   Reply With Quote
Old 01-25-2022, 12:47 PM   #3
Bowtiguy
Bowtiguy's Avatar
based on Mecum sales last week, I wouldnt be surprised. He sold $5.5 mil worth of cars/bikes last may. so hes just playing around at this point. I have a buddy there this week. If it goes for under $xxK, ill buy it back.
Old 02-03-2022, 01:35 PM   #4
Bowtiguy
Bowtiguy's Avatar
Turns out he got what I sold it to him for, minus shipping & 10% to Barret Jackson.
Now, I have a NEW Cover Craft indoor car cover I need to find a new home for. I never got a chance to install it. Anyone looking for one 1/2 off?
Old 02-03-2022, 01:57 PM   #5
Jason Banks
Jason Banks's Avatar
What sideview mirrors are those?
Jason Banks is offline   Reply With Quote
Old 02-03-2022, 02:05 PM   #6
Mid-Pack
Mid-Pack's Avatar
I might be. Can you PM me a price.
Mid-Pack is offline   Reply With Quote
Old 02-03-2022, 02:08 PM   #7
Bowtiguy
Bowtiguy's Avatar
69' camaro side mirrors.
Old 02-03-2022, 02:10 PM   #8
Bowtiguy
Bowtiguy's Avatar
PM sent.
Old 02-03-2022, 02:17 PM   #9
A1971Blazer
A1971Blazer's Avatar
Link says it sold for $44,000.00...not much profit on that one...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 02-03-2022, 02:42 PM   #10
HO455
HO455's Avatar
You need to be a member to post items to sell.
Please contact a moderator to set things right.
RIP Bob Parks.
Old 02-03-2022, 03:01 PM   #11
custom10nut
custom10nut's Avatar
If the guy bought it for $40k and Sold it for $44k, he lost money.
The Auctioneer fees are 15%, (I think, And I think there’s other fees too), so if that’s the case, seller’s take home was around $37k
This doesn’t include the advertising, marketing, and transportation fees
Beautiful Truck though, and a well done build.
custom10nut is offline   Reply With Quote
Old 02-03-2022, 03:59 PM   #12
Bowtiguy
Bowtiguy's Avatar
so much for peace love & trucks. Looks like much has changed since I was last active. feel free to delete whatever portion of the post constitutes a rules infraction.
Old 02-03-2022, 03:59 PM   #13
A1971Blazer
I've ever bought at the high end auctions...most around here are 10% buyer premium....I suppose "you gotta pay to play"...
1967 C10 Step side
1968 C10 Step side
Old 02-03-2022, 04:41 PM   #14
Bowtiguy
Bowtiguy's Avatar
He definately lost $5-6K, 10% BJ seller fees plus shipping. Internet buyer bought it. He will be happy with how it sounds/drives. I never had a thing go wrong with it after I completed the build other than fuel level senders getting wiped out from all the G's.
