03-02-2022, 01:53 AM | #101 |
Blue 67
Re: My 53 GMC 3/4 ton project
Also, I have been doing some brake work:
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
03-02-2022, 08:51 AM | #102 |
just a heads up for ya. i run the D52 calipers on the rear of a lot of my stuff, and my TJ should be light in the rear like your truck will be. a few tips ... just turn that adjustable proportioning valve down all the way and back off 1/4 turn so it doesn't stick. then even after that during soft braking around town you'll be using the rears pretty hard vs the front. they'll wear out pads quicker than you expect.
well, that assumes you use the same on the front and not some huge 6-piston |
03-05-2022, 12:39 AM | #103 | |
Blue 67
03-05-2022, 12:45 AM | #104 |
Blue 67
Before I finalize the steering box, while there is more elbow room, I wanted to finish up the headers, intake and the oil pressure gauge sending unit for a dedicate gauge. These parts are done!
03-25-2022, 10:32 PM | #105 |
Blue 67
Okay, it has been few busy weeks but now I got a chance to get back on the project.
Finalizing the steering set up. Moving the steering box couple of inches to the outside has created issue with pitman arm and drag link. The drag link gets too close to the tire and also, it doesn't line up with the spindle:
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner Last edited by Nima; 03-26-2022 at 03:41 PM. |
03-25-2022, 10:37 PM | #106 |
Blue 67
So, my fix was to cut the lower section of the pitman arm and weld it 180-degree opposite! Since I wanted to be sure the pitman arm stays in one piece, I added a 1/4" angle iron as additional support:
03-25-2022, 10:43 PM | #107 |
Blue 67
Flipping the pitman arm like that, created another issue with the drag link which you can see on the 3rd picture above, the spindle end of the drag link faces up, instead of down. The solution, I cut the drag link and rotated it downward! To keep its strength, after welding the cut, I used section of pipe to add additional support. Finally, everything lines up as they supposed to,
03-26-2022, 12:39 AM | #108 |
not sure how things work where you are located but heating, cutting or welding a steering part is strickly forbidden where I come from in Canada. maybe check with the local authorities or your local front end shop. if you need an inspection at some point it may not pass if that is the case locally.
they do make an adjustable drag link that could be put togther as you have yours. pitman arm, maybe not. |
03-26-2022, 03:16 PM | #109 | |
Blue 67
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner Last edited by Nima; 03-26-2022 at 03:36 PM. |
03-26-2022, 05:24 PM | #110 |
You could check and if illegal in your area you may be able to have a new Pitman arm made for you. Same for the drag link, find some ends the right size and have the center section made and use some connector sleeves from something the correct size and easily found. The taper in the Pitman arm and steering arm could also be modified to fit something readily available.
04-04-2022, 10:01 AM | #111 |
Blue 67
So, working a little bit here and there.
I just went with Heater/defrost unit from Vintageair for now since I rarely use AC. Also, I spent some time finishing the tranny tunnel.
04-27-2022, 12:14 AM | #112 |
Blue 67
So, it has been a while!
I have been able to do a little with 53 since I got involved with another LS swap! My 67. I am hoping to finish the 67 fast and get back on 53.
04-27-2022, 08:35 AM | #113 |
other projects happen! that's what my problem is ...
06-01-2022, 11:14 PM | #114 |
Blue 67
Okay, back on the project a little bit. Doing the enginebay wiring and also working on the coolant recovery tank by making a bracket for it:
06-03-2022, 07:01 AM | #115 |
Looking good! That bracket came out nice. Wiring can be so time consuming, but not too difficult once you have it all labeled. Keep the progress going
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
06-03-2022, 10:12 PM | #116 |
Blue 67
So, working on the radiator and tranny cooler braclet at the same time.
I am mounting the raidator on the outside of the rad support to create more room for my junckyard taurus fan.
06-03-2022, 10:15 PM | #117 |
Blue 67
Moving the radiator to the outside, and using chevy radiator with top fill cap created an issue with top ratiator brace/bracket. My solution was are in the pcitures!
06-03-2022, 10:17 PM | #118 |
Blue 67
Radiator and tranny cooler lines are done. I know it is not pretty but it feels solid and I am hoping for fucntionality.
The pictures doesn't show but there is aboutr 1/4" space between the upper rad support brackel and the radiator itself.
06-04-2022, 09:06 AM | #119 |
Nice solution and fab work.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
06-05-2022, 10:33 AM | #120 |
good thinking on the ras support. should work good.
nice to see an AD that still has air under the frame rails. most lately seem to be sitting on the bottom of the cab. nothing wrong with that either, just nice to see a taller one too. should be a great driver. did you get the steering figured out to work with no problems? |
06-05-2022, 10:47 PM | #121 | |
Blue 67
I have just started to work on the wiring. Hoping to finsh that, along with the steering soon. Meanhwile I am finsihing up the cooling system. This is my solution for the cooling fan: a 2 speed junkyard taurus fan. the fan with its shroud is almost perfect fit turned at its longer length. I just had to trim the bottom of it to clear lower radiator hose. I made a little bracket at it bolted up to the original radiator nuts on rad support It clear the front accessories nicely.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner Last edited by Rickysnickers; 06-06-2022 at 10:25 AM. |
06-05-2022, 10:49 PM | #122 |
I would wire it to the ecm fan connection or a thermo switch and also install a manual overide just for peace of mind.
06-05-2022, 10:56 PM | #123 |
Blue 67
That is the plan. I did the same set up on my Nova's LS swap and it works great although the high speed has never come on so far.
06-06-2022, 11:36 PM | #124 |
Nice fab work so far. That fan fits great. Looks like it wade made for your application. Keep it the good work.
06-10-2022, 02:24 PM | #125 |
Blue 67
While I am waiting for few electrical connectors to arrive by mail, I finished most of the exhaust. I just need to add the tail pipes but I am not sure if I am going to cross the tail pipes over the axle all the way back since on the driver side, the coilovers have limited the space over the axle.
