Old 06-01-2022, 11:36 PM   #1
Nima
Blue 67
Idler pulley, is it necessary?
Hi there:
Since I don't have PS, my belt routing is a little different. As you can see in the picture, the belt rubs against itself routing around the idler pulley. I am thinking about just have a tensioner with no idler. Is that a no no?!
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 06-02-2022, 04:51 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Idler pulley, is it necessary?
If you don't have that idler pulley, the belt will go through where your air intake will be on the throttle body. You might try going from the bottom of the crank pulley, to the alternator, then down under the waterpump pulley then to the tensioner. Not sure if that will have enough wrap on the crank, but its worth a shot.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-02-2022, 02:17 PM   #3
mongocanfly
mongocanfly's Avatar
Could you make a bracket and mount another idler pulley in the general are of where the ps pump used to be?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-03-2022, 12:56 AM   #4
Nima
Blue 67
Thanks guys.
I guess I'll try rerouting the belt to see if that works. If not, I guess I need to come up with some sort of relocation bracket.
Old 06-03-2022, 08:47 AM   #5
bhap
bhap's Avatar
Power steering delete pulley..
bhap is offline   Reply With Quote
Old 06-03-2022, 02:00 PM   #6
kwmech
That is a whole lotta belt just to run the alt.
kwmech is online now   Reply With Quote
Old 06-03-2022, 04:37 PM   #7
LS short box
Check with the folks at ICT. They make all kinds of LS brackets.
Old 06-03-2022, 06:18 PM   #8
Accelo
Accelo's Avatar
Are both idlers the same diameter? If one is slightly smaller switch them out.
I'm betting you could find a smaller diameter pulley, if you were able to look at a few pulleys, at the auto parts store.
Accelo is offline   Reply With Quote
Old 06-03-2022, 06:31 PM   #9
mongocanfly
Accelo, theres only one idler on it...the upper left is the tensioner
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-03-2022, 09:50 PM   #10
Nima
Blue 67
Yes, the left one is the tensioner, which is needed. I actually had a smaller idler which I tried but it didn't make much difference.
Old 06-03-2022, 10:45 PM   #11
Accelo
Accelo's Avatar
LS short box suggested ITC.
Below is an example manufactured by ITC..
Maybe this bracket set up would work if you have room for the low alternator?
Old 06-07-2022, 10:57 PM   #12
e015475
e015475's Avatar
This is a truck accessory drive with an ICT idler relocation kit installed
But I don't think you need one- the idler or the relocation kit
I think you need to reroute your belt to be like the one in the picture above. The way you've got it routed, the tensioner is never going to work
e015475 is offline   Reply With Quote
Old 06-07-2022, 11:36 PM   #13
mongocanfly
Nice setup that e0 showed above..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-10-2022, 02:20 PM   #14
Nima
Blue 67
Well, I just rerouted the belt as was suggested by LS1Nova and it seems it should work, we'll see when I fire it up!
