01-25-2022, 01:32 AM | #326 |
Re: Walter DeWayne...Walt for short
Looking good!
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Project "Little Sister" (70 c10 blue original paint refresh) Project "C10 Fever" (68 factory black 396 swb) Project "Blue Bomb" (70 c30 blue original paint refresh) Project "Vitamin C" (71 c10 orange original paint refresh) |
01-30-2022, 07:02 AM | #328 |
Proprietor of Dale's Corner
I see you had a cold snack..... Keep it up, it's looking good.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
01-31-2022, 07:58 PM | #329 | |
Just to prove I made some progress. I got the new ball joints installed into the Porterbuilt control arms and got them mounted up on the chassis. |
02-01-2022, 07:38 AM | #330 |
Nice!
02-03-2022, 09:48 AM | #332 |
It looks mean too.
02-07-2022, 08:08 PM | #333 |
Walter ROLLS!!! Frame is square, tight and ready for plumbing. So, plumbing for the Sniper EFI, trans cooler lines, Accuair system and brakes need to happen next. Then motor & trans go in for the final time & exhaust can happen. Then cab goes on & painless harness, then …. GEEZUS, it’s a long way to the finish line.
02-08-2022, 07:36 AM | #334 |
At this pace it will be together in no time!
06-07-2022, 09:08 PM | #335 |
Life got in the way again and it came to a screeching halt. But firewall and interior paint are about to happen. Remember, I’m leaving the exterior alone. First bath the cab has had since 1984’ish.
06-08-2022, 01:09 AM | #336 |
Glad to see this. Keep @ it.
06-08-2022, 01:00 PM | #338 |
I really need to do the same on my '64. The problem is the truck was re-painted years (and years & years) ago w/the Lt Green vs it's OG Turquois Poly.
There are areas where both colors are clearly visible since the truck was not completely disassembled. My original thought was to clean & paint the firewall only (to the upper lip) in Satin black along w/the inner wells & leave the cowl area/s as is. But, a good friend of mine whom shall remain nameless suggested 'hell no'. I have zero intentions or desire to paint it. Ever.... Your situation (from the pics) looks like it will work well.
06-08-2022, 05:23 PM | #339 | |
06-08-2022, 06:45 PM | #341 | |
06-12-2022, 07:41 PM | #342 |
To prove that I’m working on both pieces.. I got the 468/700r4 installed and the Chevelle headers fit without issue. MOVING FORWARD!!! Shooting for September finish date.
06-12-2022, 08:06 PM | #343 |
It looks awesome!
06-17-2022, 02:38 PM | #344 |
Inching along. GEEZUS, painting the interior was true act of acrobatics. But almost done. Still gotta paint all the small parts and the firewall.
06-22-2022, 11:44 PM | #346 |
Wow pretty sharp color. It’s gonna look great!
06-23-2022, 10:10 AM | #347 |
Thanks man! It’s actually just the oe 507 paint code. I only did the firewall and interior. I’m leaving the exterior the original used & abused paint.
06-24-2022, 09:15 AM | #348 |
PROJECT 7DEUCE
Its been awhile since ive logged in but very nice build its giving me motivation to get on mine again....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-25-2022, 10:54 AM | #349 |
Looks great!
08-24-2022, 11:14 AM | #350 |
Its been awhile since I've been in here, great progress!
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
