06-14-2022, 08:45 PM | #376 |
Re: 1969 C20, CST. 396, 21,000 mile documented Survivor
And the 7?
06-14-2022, 10:45 PM | #377 |
Now the question is typically how far in advance was glass produced in relation to the truck?
06-14-2022, 11:13 PM | #378 |
Based on what I have found for my truck, the vent window glass was made about two months before my truck was assembled, and the other windows were made about one month before. The "7" is a plant code, and it seems to be for Ottawa, IL.
06-15-2022, 12:43 AM | #379 |
Most major components have their assembly date stamped or otherwise indicated. Most on my truck precede what is currently believed to be a first week of December build date by 1 to 2 weeks.
Here's a link to some threads that may be helpful. https://67-72chevytrucks.com/vboard/...d.php?t=764404 http://67-72chevytrucks.com/vboard/s...d.php?t=740875 A/C Compressor decals are also dated. https://67-72chevytrucks.com/vboard/...d.php?t=791330
Jim Last edited by FirstOwner69; 06-15-2022 at 01:08 AM. |
06-15-2022, 08:40 AM | #380 |
I believe the 7 was the plant location where the glass was made .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
06-15-2022, 04:09 PM | #381 |
Thanks guys!
06-19-2022, 08:12 PM | #382 |
So to get back on the side marker light subject I snapped a photo of them today. Date code is 69 what say you guys?
06-19-2022, 08:42 PM | #383 |
If you are asking whether they are original to the truck, it's anyone's guess since they could have been swapped around - but given they are the correct side marker for a 69 CST and have a 69 date stamp, well, it's as close as you're gonna get. I'd suspect they are original.
06-19-2022, 09:46 PM | #384 |
Without question!
06-20-2022, 12:16 AM | #385 |
These comments are being added just for the record. I am not suggesting that you make any changes to this truck! Hell, I added the deluxe markers to my CST as did many others over the years. Your truck has obviously received a lot of love.
I'm not buying that these markers are original to this truck without knowing when the truck was produced. As I stated in an earlier post, I personally had a phone conversation with Chevrolet corporate (not a dealer) regarding CST package content when I realized my new early December build CST appeared to be missing several items from the CST package (the most obvious being deluxe lighted markers, headliner, cargo light). They told me these items were added to the package no earlier than late December, 1968. The dates on various light lenses does not indicate the year the item is made. In this example, I believe the "69" indicates the year the DOT or other agency approved first usage of the design and functional compliance. I bet every one of the the deluxe markers originally on one of these trucks from from late December,1968, through 1972 has the "69" on it. I don't think the repros have any dates or any other info on the lens. Also, I'd bet a beer that every van produced through the 70s that used the same design deluxe marker (if required by the trim level) has a "69" on it. It's very easy to swap these in. As stated above, I've done it with my CST/20. The required harnesses are easily removed from a donor. Lighted markers used for the first year or two did not blink with the turn signals. The last couple years blinked sequentially with the turn signals. If the owner wanted lighted cargo light but didn't want to go to the pain of cutting the cab, lighted markers would have been a walk in the park.
Jim Last edited by FirstOwner69; 06-23-2022 at 10:20 PM. |
06-20-2022, 12:35 AM | #386 |
06-20-2022, 08:58 AM | #387 | |
06-20-2022, 09:01 AM | #388 |
Normally I never cared for bed rails but the low profile and design of these fit the truck like a glove. And their flawless.
06-20-2022, 09:48 AM | #389 |
Your glass was manufactured in October, 1968 in Ottawa, IL based on the glass codes. Your truck, however, was assembled an unknown amount of time (1 to 2 months?) after that in Flint, MI based on the F in the VIN.
06-20-2022, 11:25 AM | #390 | |
Active Member
As for other date codes, the printed circuit on my gauge cluster was about a month earlier than the date on my FMVSS, so you can check that too to corroborate a build date range.
1971 Pontiac Firebird 1971 GMC C2500 |
06-20-2022, 07:24 PM | #391 |
You are correct that the 69 indicates the model year first used, However, something first used in 1969 model year may have been first used starting well into the the model year. That was the case in this situation according to Chevrolet.
Jim |
06-21-2022, 12:04 AM | #392 |
I'm trying....
Cool truck for sure. Jim knows his stuff on these '69s...heck it's in his handle. Sure helped me a lot when we built our 69. A couple of things on build dates, plants, options and '69 CSTs (and apologies if I'm treading trodden ground in this thread).
I don't think Flint was as prolific as say St. Louis. But the production rates among plants were generally similar, and similar year to year within a single plant. I think we can safely say that your truck was built in that Dec/Jan range...so it's not surprising that you might have some elements and not another of what was expected for a CST. A lot of stuff was getting added on the fly in 69 and it would be unreasonable to expect plant processes to change quickly and consistently among plants. A rear view mirror was not standard at the beginning of the model year and was a SPID callout as an option. The smooth mirror mount was '69 only (unless you count the few 70s that got em early in that model year). The perforated headliner was also 69 only. Here are some 69 CSTs with no cargo lights (but one has rear view mirror and headliner).
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 07-09-2022 at 03:33 PM. |
06-21-2022, 12:05 AM | #393 |
I'm trying....
Here are some late model year 69s with the whole shooting match...
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
06-21-2022, 12:16 AM | #394 |
I'm trying....
Finally...here's the SPID on the black step side in post #392. It's a very early truck and you can see the SPID call out for the rear view mirror...not yet standard at that point in the MY.
And for good measure, a '69 Blazer SPID with a side marker call out.
06-21-2022, 07:59 AM | #395 |
Good info! So basically if an option was not on the SPID the truck did not come through with it? No deviations?
06-21-2022, 08:22 AM | #396 | |
1. was included as standard equipment for that truck model 2. was not factory built with that option (RPO) Dealer installed options/accessories would not be printed on the SPID as RPO's.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
06-21-2022, 08:32 AM | #397 | |
I'm trying....
And the focus of your discussions has been what features comprised a CST trim PACKAGE in 1969. Early in 69 it was different on paper than later in the year. Even then it varies because the assembly directive was not quickly and fully implemented at individual assembly plants. But yes line workers made mistakes and there are crazy SPID anomalies (spend some time in that thread, it's fun). And the same RPO codes meant different things year over year (and sometimes within the model year). Z84 meant different things throughout the run of these trucks and 508 dark blue was a completely different color in 1970 than 1969. Yours is a cool truck with idiosyncrasies consistent with an idiosyncratic year and some nice period mods/updates.
06-21-2022, 05:55 PM | #398 |
I agree 100%.
Jim |
06-22-2022, 11:26 AM | #399 |
Carpe manana
Can anyone confirm this is actually a date code?
06-22-2022, 12:47 PM | #400 |
