Old 05-19-2022, 11:03 PM   #176
SCOTI
SCOTI's Avatar
Re: 2wd swap
I like it.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-20-2022, 01:44 PM   #177
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
The gov lock did its normal thing.
This is the 2nd time the 12 bolt gave up.
Couldn't believe the amount of hate the 9in replacement got.
Didn't know the gm fan boys where that way.
Old 05-20-2022, 02:33 PM   #178
SCOTI
SCOTI's Avatar
Re: 2wd swap
Well..... The GOV lock set-ups are known weak links so there's that. I'm fine w/the 9" or 8.8 options.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-20-2022, 05:06 PM   #179
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
He knew the issues with the gov bomb.
Also don't suppose the donuts spun had anything to do with it.
Lol
Old 05-20-2022, 05:24 PM   #180
SCOTI
SCOTI's Avatar
Re: 2wd swap
Lol
No way...
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-25-2022, 01:30 PM   #181
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Kid surprises me again.
Cal trac housing bracket won't cooperate with the dual shock brackets.
Because pre runner stuff.
So he downloaded fusion 360 Tuesday. Sends me this Wednesday
Old 05-25-2022, 03:30 PM   #182
SCOTI
SCOTI's Avatar
Re: 2wd swap
Man.... How cool would it have been to have tools like this that one-time I was a young-gun?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-25-2022, 11:34 PM   #183
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Would have saved hundreds of cut off wheels
Old 05-26-2022, 07:44 AM   #184
SCOTI
SCOTI's Avatar
Re: 2wd swap
I'm sure we saved them..... In our lungs
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-26-2022, 07:48 AM   #185
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
I was thinking about my ears, but yeah that too.
Old 06-12-2022, 11:58 PM   #186
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
After a complete failure with the local guy, sendcutsend.com blew us away.
Kid left a .010 tolerance and it fit together so well that it needed a love tap to take apart for the final fit up
Old 06-18-2022, 11:23 PM   #187
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Brother's on vacation.
Back on the K5 my son's got the fusion360 working pretty well I think.
Since we sectioned the crossmember 1.5 inches then raised the upper pivot the same trying negate some bumpsteer and got only a 2° camber change thru the usable travel.
He drew us up a new upper pivot that's 1.75 taller than stock
and created an access hole for the airbag fittings.
May also ad in a coil over mount into it.
Old 06-21-2022, 10:36 PM   #188
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Final render
Old 06-25-2022, 06:50 PM   #189
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
1st mock up
Old 06-29-2022, 08:10 PM   #190
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
New parts came.
Old 07-03-2022, 08:24 PM   #191
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Welding it out.
Old 07-09-2022, 12:29 PM   #192
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Sperical washer.
Sure why not.
Old 07-09-2022, 07:17 PM   #193
SCOTI
SCOTI's Avatar
Re: 2wd swap
What's the purpose (need?) for the spherical washers?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-09-2022, 08:29 PM   #194
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
The choppin block arms have a tight(er) tolerance on the stud.
And with any caster in the shim stack it bends the stud overvwhen flange nut is tight.
And looks better than the factory stuff.
Old 07-09-2022, 09:51 PM   #195
SCOTI
SCOTI's Avatar
Re: 2wd swap
Makes sense. Where did you source them for reference?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-09-2022, 10:01 PM   #196
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Jungle site.
Morton - SP-2 Low Carbon Steel Spherical Washer Sets, Equalizing Washers, Inch Size, 1/2" Bolt Size https://a.co/d/fsst9WR
Old 07-10-2022, 12:44 PM   #197
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Brother's 9 inch back from powder.
Hopefully get it under it today.
Old 07-11-2022, 01:45 AM   #198
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Got hosed, axles are wrong.
Bar brackets came out neat
Old 07-18-2022, 03:00 PM   #199
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
.250 spacer
And the calipers clear
Old 07-25-2022, 10:41 PM   #200
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 2wd swap
Success
