#1 | |
Re: 1970 GMC - Disc brake conversion recommendations?
Using the 73-87 prop valve can work but the lines are routed differently vs pre-73. There might be some difference in the two so that's a decision you'll have to make. Lines were def routed differently on the 71-72's vs square-bodies.
