Starter Question
I have a 1970 GMC that occasionally will not fire up when I turn the key. The lights come on, but nothing from the starter. If I use the 'ol "hit the starter with a hammer" trick, it fires right up.
I'm tired of doing that and it's embarrassing when I'm in public. ![]() Looking at replacing the starter and it seems like the Summit Racing Mini High-Torque Starters (SUM-829105) get a lot of praise for it's output and longevity. Anyone have any good/bad experiences with them? Or, do you recommend a different/better starter? Thank you in advance! ![]() |
Who Changed This?
![]() Join Date: Jan 2013
Re: Starter Question
I have a Hitachi (I think) that has been on my truck, that I got at a local speed shop. Works fine, but longevity is unknown, since I've only driven it about 10k miles in 10 years.
IMHO a Remy starter from Rockauto will be fine. I get the "gear reduction" type (aka mini starter) for around $75. Gear reduction starters are smaller, lighter and provide considerably more "cranking" RPM's than conventional starter
Here is a X reference chart for REMY starters showing conventional to gear reduction and also if they are 1 vs 2 wire. I have the 153 tooth SBC 2 wire (with R terminal) on my 67 Camaro and will get the same if/when I need one for the C10 |
Who Changed This?
^ I paid a bit more for my starter. That was before I saw this style mentioned here. I'll replace it if it ever goes bad.
![]() Join Date: Aug 2018
I got this acdelco starter that’s been on my truck for sometime haven’t had any issues…
https://www.summitracing.com/parts/ado-337-1022
Doug ![]() 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US |
I’m rolling the dice and going with the one I posted. Talked to a few of the local guys who have trucks similar to mine and they love it and have had no issues. Here goes nothing.
If turning the key to start doesn't do anything there's a solenoid issue. It's also likely to be a wiring issue.
Rather than throwing parts at it maybe try some troubleshooting. What's the voltage to the solenoid case from the S-terminal with the key in the start position? Maybe loosen and tighten all the electrical connections for the starter and solenoid. |
![]() Join Date: Nov 2001
I have my original starters and alternators rebuilt by a father and son only, small shop. Been doing business with the dad for over forty two years, never had any issue and cool dudes just to stop in and shot the breeze with, small talk there busy. Good luck with yours.
Take care |
I use Powermaster starters in all my vehicles . Stock starters quit quickly I bought a cheaper I think DB Electric mini starter in my chevelle it lasted 2 years . The Powermaster is now 4 years and not one problem . I have since put them in all my trucks too .
Good quality and made in USA
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
for intermittent no start, your starter solenoid has a large copper washer inside that makes contact to engage the starter motor.
Over time the washer becomes non conductive in spots due to the arcing of engaging solenoid. to fix remove starter solenoid, disassemble, flip large copper washer over, clean up copper contact stud, and you will have a solenoid that functions reliable like new. your best alternative is a gear reduction starter. good luck ! |
#11 | |
1.Disconnect your battery first 2.Try to get under the truck and do a visual of the starter, wires, state of connections/terminals, battery cable (anything dirty, loose, frayed etc?) 3.Check to ensure the starter itself is not loose (starter bolts) 4.Reconnect battery and try to start checking voltages as franken mentioned above This will give you piece of mind and ensure all starter related systems/wiring are in good shape and help determine if you really need a new starter or not. With that said, I have had very good reliability and performance from many different mini starter brands: Summit, Powermaster, GM reduction starters etc.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
put the right starter bolts in it now, save breaking a block
#13 | |
While the OP is trying a new starter, for others with a similar issue, a starter that works when 'hit with hammer', could have bad brushes. A few years ago when mine did this, a set of brushes was a $4 fix.
