Which adjustment on Edelbrock chart for rich at WOT?
To adjust wide open throttle air fuel ratio do I need to adjust the main jet and metering rods based on the chart or the secondary metering that is noted to the side of the chart?
After rebuilding and re-jet here are my results: Idle: mid 12's Part throttle acceleration: mid 12's Highway cruising: mid 14's Letting off the accelator: mid 12's Wide open throttle: low 10's. According to the manual I'm in the ballpark for everything except the wide open throttle.
Evan B. Last edited by evan; 08-29-2022 at 06:40 PM. |
Re: Which adjustment on Edelbrock chart for rich at WOT?
I would change the secondary jets. If you change the main rod/jet combo you will lean out the WOT along with all the rest. Doing the secondary only should not affect the other parameters.
If the motor isn't a race engine I would say you are rich across the board. 12.5:1 is the WOT ratio. Idle should be closer to 14 without the choke. Now your ratios look good for a wild cam that's run on the street. Every motor has different AFR requirements but slightly lean usually makes more power. Rich is a safety margin that kills mpg and sparkplugs.
So I'm assuming you have an AFR guage. I'm going to do one this winter. If I may ask, Which one do you have?
#5 | |
https://www.innovatemotorsports.com/...-kit-8-ft.html
Evan B. |
When you re-jetted do you go richer or leaner than the stock set up?
#7 | |
I went for a quick drive tonight and it was shooting up to 17-18 on part throttle cruising. I’m leaving town for a week but when I get back I’ll let it warm up fully, do another test drive and if it’s still doing weird things I’ll pull it off again to make sure I didn’t screw it up the first time. I’ll double check the metering rod spring strength too.
Evan B. |
Leaner. I went to setting 7 and one stage leaner on the secondary jet.
Evan B. Last edited by evan; 08-30-2022 at 03:05 PM. |
If this was a holley I would say the air bleeds were off causing the lean out. It sounds like the idle circuit is running out of fuel before the primary sides main jets are coming in. I have a feeling that the main jet is to large also. I just don't know how to adjust this on the edelbrock carb.
The Doug Roe Rochester Carb books shows 16 as the ideal A/F for economy on part throttle cruise with 15~17 as being OK. For power he has 12.5 as ideal with 11~14 as OK.
For idle, you want as lean as possible while still getting a smooth idle. (Assuming a OEM cam). The shade tree mechanic method was set timing and idle rpm, then adjust idle mix for max rpm, then lean a 1/4 turn on each screw. Then readjust idle rpm to desired. What initial timing are you using? Do you have one of the Eddy calibration kits with the variety of jets, rods and springs? |
#11 | |
Here are the specs from my cam. It's got a bit of a choppy idle. Duration at 050 inch Lift: 227 int./241 exh. Advertised Duration: 279 int./297 exh.
Evan B. |
What’s your initial timing?
Do you have a vacuum gauge? Wonder if the cam is keeping vacuum a bit low and causing the power pistons to lift and run rich? Might try one spring level difference and see what that changes. At least those can be swapped without lifting the carb top.
10 degrees at idle. 31 at 4100rpm.
Evan B. |
#15 |
Not nearly enough.
You should be running up close to 18 to 20 degrees. At your elevation you need to start the burn earlier. More initial also let’s you turn down the idle on your carb getting it back idling on the idle circuit. Right now you’re likely idling on the power circuit. |
#16 | |
Evan B. |
#17 |
Sneak up on the max initial. Try 14 first and see if that changes your afr’ s. Then bump it 2 degrees.
Listen closely for pinging though. A good way to see if you’re idling on the power circuit is to adjust either mixture screw in slowly to see if the motor wants to quit. Where do you go camping? |
#18 | |
We’re heading to Jasper, AB. I’ve been through a few times but never stayed. Looking forward to it.
Evan B. |
#19 |
It’ll go lean.
Good place to go to. Stayed there a few times. Went up on the ski hill gondola and to Miette hot springs. One of my old trucks is still around there. A white 56. Have a good time. |
#20 | |
Ok, I set the initial timing with the vacuum advance hose disconnected. It gained idle rpm and smoothed out more and more the higher I went. Stopped at 18 degrees and figured I’d check total timing. Tightened down the distributor, set idle to 800 rpm, plugged the vacuum advance hose, and the rpm jumped up a few hundred rpm. Checked timing and it was at 37 degrees. Is it normal to have the timing jump 19 degrees when the vacuum advance is plugged in?
Evan B. |
#21 |
Yup.
But your 19 degrees from vac pot might be partly mechanical timing starting to kick in. Most start to kick in near 800 anyway. Get it to idle down as low as you can then check timing. |
#22 |
I set idle to 650 and it’s about 33 degrees at idle (vac line still plugged into the distributor).
Evan B. |
#23 |
And at 2500 rpm it’s at 48 degrees advance.
Evan B. |
#24 |
#25 |
You can’t count the vac advance until it starts, so you’re only starting with 18 initial.
I had a rowdy 350 once. More cam than yours. 10 to 1 compression, trick flow heads. I ran 22 initial, 12 from mechanical plus a limited 10 degrees from vac pot. Used a limiter like this one in the link. I can tell from the way yours starts that you’re close with timing. Sounds good. https://www.summitracing.com/parts/m...yABEgKeI_D_BwE |
