starts and dies
Hello, be awhile,
I have a 1999 Silverado with 6.0. It starts rite up then dies after 2 seconds. This is what I've done so far. Changed fuel pump, and filter, 60 ps1 on fuel rail. Locksmith replaced ignition, No chip on key but its in ignition, checked relays, I've unplugged map MAP sensor, I've been told that it maybe the vats security system and that's why ignition got changed. Ran scan tool and no codes found. I hate to keep changing out parts. would crank or cam position sensor be a posibble? Any help greatly appreciated |
#2 | |
Re: starts and dies
Does the security light stay on?
Re: starts and dies
no it doesn't, blinks when ignition is off but after I crank and starts for couple seconds it goes off
Re: starts and dies
The issue is the VATS passlock module. Do a relearn or replace it
Customization is what you want it to look like -- not what other people think it should look like |
Re: starts and dies
Subbing for info, having a similar ssue with a 89 vette
Re: starts and dies
Scanner or might be able to disconnect the battery for 10-15 minutes.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
#7 | |
Re: starts and dies
Mine doesn't blink when the ignition is off. My security light did some weird stuff when the system failed though. It does sound like the module, common problem on these trucks. You would have had to reprogram it though after changing the ignition.
#8 | |
Re: starts and dies
The Vette is similar but different. Painless Wiring used to sell a bypass module for that system, I used one on a 92 Trans Am.
Re: starts and dies
