10-08-2022, 07:02 PM | #51 |
Re: CPP Rear Disc Brakes not bleeding!!
Seriously... did you replace the rubber line from frame to axel yet? I speak from experience....
10-08-2022, 11:01 PM | #52 |
10-16-2022, 09:16 PM | #53 |
10-16-2022, 09:36 PM | #54 |
What do you mean 'no brakes'?
10-16-2022, 09:50 PM | #55 |
I put Cadillac disc brakes on the rear of my 55 Chevy.
I had to move the pushrod up 1" on the pedal to get brakes.
10-16-2022, 09:53 PM | #56 |
10-16-2022, 09:55 PM | #57 |
10-16-2022, 10:49 PM | #58 |
10-16-2022, 11:00 PM | #59 |
10-16-2022, 11:03 PM | #60 |
I went through a similar experience as yours. I was about to remove the discs and throw them away. Try moving the rod. It's cheap and easy, and what have you got to lose.
10-16-2022, 11:06 PM | #61 |
10-17-2022, 08:10 AM | #62 |
Moving that rod is just going to increase or decrease pedal pressure required to stop.
Are you sure the valve is adjusted so that you are getting pressure to the rear? Maybe it's dialed all the way to the front? |
10-17-2022, 11:43 AM | #63 |
At this point I am inclined to think it is the proportion valve as well. Do you have a way of measuring the pressure? Line pressures can get pretty high. Well over 500lbs when you press with authority. It may be worth buying a brake pressure gauge. I have 1 on each circuit for the race car. It was very helpful with adjusting the bias initially but didn't use them much once I got the feel of the car and sorted what pads to use. Just get a cheepo brake gauge and set it up at the caliper. Then fiddle with the proportioning valve. I recall you having a manual type. If you are using the factory type button reset valve, I assume you have reset it.
10-17-2022, 12:54 PM | #64 | |
None of which worked. |
10-17-2022, 01:32 PM | #65 |
"She said the pedal didnt go to the floor when bleeding the back."
So, she pumped up the pedal a couple times and held it. You then loosened the bleeder. Right? Did you get fluid out? Lots? little? Did you then tighten the bleeder, without the pedal going down? I'm pretty sure from your pictures, you have this right and with the parking brake I think it would be hard to mess up. Do you have the bleed screws UP on the caliper? They are not facing down? It would be calipers swapped side to side on the truck. |
10-17-2022, 08:09 PM | #66 | |
Bubbles came out out first, but then a steady fluid stream, just like its suppose to. The bleeders are facing towards the front. |
11-07-2022, 08:03 PM | #67 |
Any ideas on how to attach a power bleeder to a willwood master cylinder?
11-08-2022, 10:09 AM | #68 |
If you are getting fluid at some decent pressure, is the pad contacting the rotor? With your foot off the brake, the pad should still be hitting the rotor a very small amount. Not actual drag on the rotor, but if you spin it, you can hear it hit.
11-08-2022, 10:45 PM | #69 |
Yes, but the problem is the pistons dont seem to move at all when the brake pedal is pushed.
11-15-2022, 09:18 PM | #70 |
11-15-2022, 11:19 PM | #71 |
Junior Member
All the heart ache you have gone through, man I feel for you! I would figure out how to adapt a 2000 psi gauge to a rear caliper line and see what kind of pressures you are getting. This would at minimum tell you if you are getting any pressure to the rear. Then you can see if it’s a caliper problem or upstream.
11-16-2022, 09:48 PM | #72 | |
I purchased a Motive power bleeder and was hoping that I could attach it to the wildwood master. The people that have felt the pedal and have seen it tell me it feels like I have air in the line. So I want to power bleed to help process of elimination. |
11-17-2022, 08:33 AM | #73 | |
At this stage, you might want to consider taking it to a shop. |
11-18-2022, 02:40 PM | #74 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 11-18-2022 at 03:05 PM. |
11-18-2022, 06:42 PM | #75 |
I was just rereading this thread . Yours are positioned just like mine on my Chevelle . And just realized that when I bleed my rears I had to remove the front bolt and spin the caliper up I put a piece of plate steel in between the pads . As the bleeder is below the top of caliper . The bleeder needs to point straight up .
I copied your picture . If you look at it it’s pretty clear the bleeder is about midline in relation to the piston . After I did the one I rotated the bracket so the bleeders point straight up so in the future I didn’t have a problem
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
