Old 10-08-2022, 07:02 PM   #51
Jason Banks
Jason Banks's Avatar
Re: CPP Rear Disc Brakes not bleeding!!
Seriously... did you replace the rubber line from frame to axel yet? I speak from experience....
Jason Banks is offline   Reply With Quote
Old 10-08-2022, 11:01 PM   #52
Tx70Gmc
Tx70Gmc's Avatar
No, thats what i an going to try next.
I have been out of town, so i haven't had a chance yet.
Tx70Gmc is offline   Reply With Quote
Old 10-16-2022, 09:16 PM   #53
Tx70Gmc
Tx70Gmc's Avatar
Just replaced the flex line. Now im able to bleed the back calipers, but still no brakes.
Old 10-16-2022, 09:36 PM   #54
Jason Banks
What do you mean 'no brakes'?
Old 10-16-2022, 09:50 PM   #55
davischevy
davischevy's Avatar
I put Cadillac disc brakes on the rear of my 55 Chevy.
I had to move the pushrod up 1" on the pedal to get brakes.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 10-16-2022, 09:53 PM   #56
Tx70Gmc
Tx70Gmc's Avatar
The calipers wont engage.
I bled the entire system again with my wifes help. The old 2 person pump method.
She said the pedal didnt go to the floor when bleeding the back.
So its not building pressure
Old 10-16-2022, 09:55 PM   #57
Tx70Gmc
Tx70Gmc's Avatar
So you had to drill a new hole on the pedal?
Old 10-16-2022, 10:49 PM   #58
davischevy
davischevy's Avatar
Yes.
other Larry
Old 10-16-2022, 11:00 PM   #59
Tx70Gmc
Tx70Gmc's Avatar
Yes.
I am getting brake fluid from the hardline/flex line connection (before the new line being installed) when i press the pedal
So it makes me think the pedal location is correct.
Old 10-16-2022, 11:03 PM   #60
davischevy
davischevy's Avatar
I went through a similar experience as yours. I was about to remove the discs and throw them away. Try moving the rod. It's cheap and easy, and what have you got to lose.
other Larry
Old 10-16-2022, 11:06 PM   #61
Tx70Gmc
Tx70Gmc's Avatar
Yea ill try that. I already tried lowering the rod without success.
Old 10-17-2022, 08:10 AM   #62
Jason Banks
Moving that rod is just going to increase or decrease pedal pressure required to stop.
Are you sure the valve is adjusted so that you are getting pressure to the rear? Maybe it's dialed all the way to the front?
Old 10-17-2022, 11:43 AM   #63
PbFut
At this point I am inclined to think it is the proportion valve as well. Do you have a way of measuring the pressure? Line pressures can get pretty high. Well over 500lbs when you press with authority. It may be worth buying a brake pressure gauge. I have 1 on each circuit for the race car. It was very helpful with adjusting the bias initially but didn't use them much once I got the feel of the car and sorted what pads to use. Just get a cheepo brake gauge and set it up at the caliper. Then fiddle with the proportioning valve. I recall you having a manual type. If you are using the factory type button reset valve, I assume you have reset it.
PbFut is offline   Reply With Quote
Old 10-17-2022, 12:54 PM   #64
Tx70Gmc
Tx70Gmc's Avatar
I have adjusted it three different ways. All the way to the front, all the way to the back and right in the middle.
None of which worked.
Old 10-17-2022, 01:32 PM   #65
Jason Banks
"She said the pedal didnt go to the floor when bleeding the back."
So, she pumped up the pedal a couple times and held it. You then loosened the bleeder. Right?
Did you get fluid out? Lots? little?
Did you then tighten the bleeder, without the pedal going down?
I'm pretty sure from your pictures, you have this right and with the parking brake I think it would be hard to mess up. Do you have the bleed screws UP on the caliper? They are not facing down? It would be calipers swapped side to side on the truck.
Old 10-17-2022, 08:09 PM   #66
Tx70Gmc
Tx70Gmc's Avatar
Yes the old pump 3 times and hold method then Release the bleeder and tighten bleeder then she pumps 3 more times, etc.
Bubbles came out out first, but then a steady fluid stream, just like its suppose to.
The bleeders are facing towards the front.
Old 11-07-2022, 08:03 PM   #67
Tx70Gmc
Tx70Gmc's Avatar
Any ideas on how to attach a power bleeder to a willwood master cylinder?
Old 11-08-2022, 10:09 AM   #68
Joyridin
If you are getting fluid at some decent pressure, is the pad contacting the rotor? With your foot off the brake, the pad should still be hitting the rotor a very small amount. Not actual drag on the rotor, but if you spin it, you can hear it hit.
Joyridin is offline   Reply With Quote
Old 11-08-2022, 10:45 PM   #69
Tx70Gmc
Tx70Gmc's Avatar
Yes, but the problem is the pistons dont seem to move at all when the brake pedal is pushed.
Old 11-15-2022, 09:18 PM   #70
Tx70Gmc
Tx70Gmc's Avatar
Any ideas???
Old 11-15-2022, 11:19 PM   #71
JEM Motorworks
Junior Member
All the heart ache you have gone through, man I feel for you! I would figure out how to adapt a 2000 psi gauge to a rear caliper line and see what kind of pressures you are getting. This would at minimum tell you if you are getting any pressure to the rear. Then you can see if it’s a caliper problem or upstream.
JEM Motorworks is offline   Reply With Quote
Old 11-16-2022, 09:48 PM   #72
Tx70Gmc
Tx70Gmc's Avatar
I purchased a Motive power bleeder and was hoping that I could attach it to the wildwood master. The people that have felt the pedal and have seen it tell me it feels like I have air in the line. So I want to power bleed to help process of elimination.
Old 11-17-2022, 08:33 AM   #73
Joyridin
I have worked on literally hundreds of brake systems on cars both OEM and aftermarket and never used a power bleeder.
At this stage, you might want to consider taking it to a shop.
Old 11-18-2022, 02:40 PM   #74
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
The bleeders should be on top of the caliper piston reservoirs, facing up to allow all the air escape and not be trapped in a higher location in the piston reservoirs. Do you have a pic of the calipers and bleeders? Also, I dont know where you got your bleeding method but it's wrong! The shop manual gives a clear detailed procedure. Your helper slowly depresses the pedal after you have opened the bleeder. Before the pedal reaches the bottom of the stroke, you close the bleeder. Then your helper slowly releases the pedal. You can bleed your brakes by yourself with a glass quart jar and a section of 1/8" or 3/16" approximately 24" inches long. You simply attach one end of the tubing to the bleeder barb, it must fit tightly, and the other end of the tubing in the jar filled 1/3rd full of brake fluid. The end of the tubing must be be submerged in the brake fluid. Open the bleeder 1/4 to 1/2 turn and make sure the reservoirs in the MC are filled. Now press the pedal slowly down and release it slowly, do this about 3 times and check the level of fluid in the MC reservoirs. Fill as needed and check the fluid in the hose at the bleeder and jar. When no air bubbles are no longer seen in the (clear) tubing, your done, tighten the bleeder and move to the left rear caliper. Follow the same procedure...Never mind that power bleeder because your just going to complicate your problems with it. You may need to take your calipers off the mounts (one at a time) and either rotate them on the rotor where the bleeder is up at the highest point where air bubbles would gather and have your helper pump the pedal while you hold the caliper on the rotor. The open bleeder with tubing attached and jar must be in place before pumping the pedal. Maybe using a piece of scrap steel the same thickness as the rotors placed between the pads will allow you to remove the caliper and hold it in a position with the bleeder up. The scrap steel is only to hold the pads at the correct width so you can reattach them to the rotor. I think those calipers are possibly positioned wrong not allowing all the air to escape. Again, a picture of the caliper and bleeder would be helpful. Take that power bleeder back and get one of these, this will allow you to reverse bleed your system by pumping fresh fluid right into the calipers and right on into the lines pushing air out at the MC reservoirs. You'll need a turkey baster to draw fluid out as you refill the system from the rear forward. https://www.amazon.com/Phoenix-Syste...2-8997e41410bb Here's a very good video depicting the correct procedure. https://www.youtube.com/watch?v=TOF4vhblUvw
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 11-18-2022, 06:42 PM   #75
72c20customcamper
72c20customcamper's Avatar
I was just rereading this thread . Yours are positioned just like mine on my Chevelle . And just realized that when I bleed my rears I had to remove the front bolt and spin the caliper up I put a piece of plate steel in between the pads . As the bleeder is below the top of caliper . The bleeder needs to point straight up .
I copied your picture . If you look at it it’s pretty clear the bleeder is about midline in relation to the piston .
After I did the one I rotated the bracket so the bleeders point straight up so in the future I didn’t have a problem
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
