10-10-2022, 12:02 PM
#1
Re: Brake vacuum
Originally Posted by vin63
Not at all. I'm saying that if your engine combination (and you plan on keeping the engine combination) is not making enough vacuum for the booster you have, then I would not run the vacuum-based booster. My current engine combo does not make much vacuum either, so I didn't install a vacuum booster for my brake system. As the others have mentioned, double check that the rest of your braking system is working properly.
Thanks for clarifying.
