![]() Join Date: Jul 2015
Leveling chassis
I'm getting ready to cut c notches and do other chassis work on a bare frame. What points do you all use for leveling, are these spots good to use for front to back &side to side?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
Re: Leveling chassis
Bump, anyone?
Looks good. I like to use the bed mounts cause they're normally parallel to the frame.
![]() Join Date: Jan 2011
I always use the top of the frame. Check it in three places front, middle and back to ensure no twist.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Thanks guys, I'll do just that next week when I get back out in the garage.
#6 | |
When I built my chassis, I checked @ the front (as far up front as possible); near the center (between front & rear cab mounts), & @ the end of the rails.
