Help I got a draw
On a 04 Avalanche. I have unhooked the neg cable and placed my test light one side on the cable the other to the neg term at the battery. I have unhooked one at a time every single fuse and relay and even the breaker. I also unhooked and unplugged the alt, yet still the test light shines. I rolled down the dimmer[heard that some GM had that as a problem] yet I still have a lit test lamp. Any ideas where to look I'm stumped. This truck has nothing extra added to the electric stuff it is all just a stock Av. Thanks in advance Jim
Re: Help I got a draw
When you say every fuse and relay, you did both fuse boxes?
Customization is what you want it to look like -- not what other people think it should look like |
Moderator
![]() Join Date: Jun 2017
Unplug the computer plug and check again....most computers need a small draw which would account for your light.
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
Moderator
![]() Join Date: Aug 2017
Hvac blower motor resistor
Alex 1967 C50 292ci Lumber truck 1967 C50 292ci Dump truck 1967 C60 366ci Fire truck |
I suggest using an amp meter or an amp setting on a DVOM. Test lights work great for older cars without modules in them. Not so great with these trucks that have modules that have time delays to turn off.
*If you have RPO CJ2, the HVAC module can take 4-5 hrs to turn off. That is normal A draw should be 30 milliamps or less after all modules have shut down. |
