Old 02-14-2023, 10:58 AM   #201
KyleSeal
KyleSeal's Avatar
Re: My 1967 Build (Finally)
Post #200! Not necessarily any update, just glad to have the truck mostly together (sheet metal wise, minus drip rails Im installing tonight). In all honesty I didn't think I'd make it this far! Its been a long journey and its a lot of tough work, long nights, stress... but I walk out through the garage to go to work every week day and Im happy with what I see!
I do also apologize for those who aren't picture happy, I just like posting photo evidence of progress.
Size:  92.3 KB Name:  IMG_4983.jpg
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 02-19-2023, 04:36 PM   #202
zicc1835
zicc1835's Avatar
Originally Posted by KyleSeal View Post
Good catch! I had not considered that, but to my calculations, if that is the case, I can drop the pushrod position on the original pedal accordingly to drop the ratio. The numbers on the diagram are not mine, just a given example from Wilwood. But given the case, if the bellcrank ratio flipped is 0.66:1, and I drop the main pedal ratio to a 2.8:1 then I will achieve about 4.2:1. Which will still help with my operating angles, and give me a proper pedal. The truck isnt back together yet, so I wont know about pedal feel until Ive got it reassembled.
EDIT: I added a diagram of my unit, with my setup + measurements and how I calculated mine with my flipped assembly.
Nice work you guys are designing something I am interested in ...would like to try something similar but on another build (Doc & Kim) that is in moth balls at the moment ill keep this for reference when/if I get there
thanks
zicc1835 is offline   Reply With Quote
Old 03-01-2023, 09:53 AM   #203
KyleSeal
KyleSeal's Avatar
Time to move onto the doors... told myself I wouldn't go into the doors.. I lied.
However, the new stampings on the door bottoms is soooooo much better than the old ones.
Size:  69.2 KBName:  IMG_5423.jpg
Size:  90.2 KBName:  IMG_5457.jpg
Old 03-01-2023, 09:54 AM   #204
KyleSeal
KyleSeal's Avatar
Some pics of the new stampings....
Size:  35.2 KB Name:  IMG_5465.jpg
Size:  30.5 KB Name:  IMG_5461.jpg
Old 03-01-2023, 09:59 AM   #205
KyleSeal
KyleSeal's Avatar
Final pics... and one of the speaker grill I am planning on grafting into the lower door panel.
Size:  100.6 KB Name:  IMG_5459.jpg
Old 03-03-2023, 12:32 AM   #206
cornerstone
cornerstone's Avatar
I can't say that I've ever seen this mod done before... seems like a good solution for guys who still want speakers in the doors but don't want to see them. Cool.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-03-2023, 11:53 AM   #207
KyleSeal
KyleSeal's Avatar
I have personally not seen it myself either. I was checking all over to see what people were doing, and I just didn't want to run kicker speakers or cut a huge hole in the door to put a modern speaker in, just thought it would look out of place. Now I just need a way to mount the speaker inside the door shell, I was thinking of doing studs welded to the backside, but not sure yet!
Old 03-03-2023, 04:11 PM   #208
chewychevy67
The studs welded on is what I would do. Nuts mounting from the inside. Then I would put a insulation cover over it for water and to push the sound into the cab instead of in the doors. That's what I did with my speakers in the kicks.https://www.ebay.com/itm/32424943927...Bk9SR-Csw5HVYQ
chewychevy67 is offline   Reply With Quote
Old 03-06-2023, 12:05 PM   #209
KyleSeal
KyleSeal's Avatar
That sounds like a plan. I doubt the speaker will weigh much, but I will probably make a small structure that incorporates the door frame and the window stop bracket. Thought about doing components, but not sure on where I'd place the tweeter. Maybe same idea, just below the vent window corner, with a small grill grafted into the door as well.
Old 03-06-2023, 03:58 PM   #210
KyleSeal
KyleSeal's Avatar
Couple irons in a couple fires this weekend... painted all the column pieces, rear speaker brackets, and started inventorying what I will use on the column new vs original. Learned these 67 columns are a bit different than the later years. Also tried out the dry ice + isopropyl alcohol trick to remove the inner door sound deadener. It actually works really well. Inexpensive as well.
Size:  80.0 KB Name:  IMG_5569.jpg
Old 03-06-2023, 11:12 PM   #211
cornerstone
I can't say that I've ever heard of the dry ice and isopropyl alcohol trick before. Would you mind elaborating? I'd like to get the rust concealing crud off the inside of my doors as well.
Brian
Old 03-07-2023, 09:13 AM   #212
KyleSeal
KyleSeal's Avatar
Essentially I went to my local supermarket (Harris Teeter), bought a 4lb bag of dry ice and two 16oz bottles of isopropyl alcohol, and used a small cooler to mix/break them up. I used 16oz of isopropyl to 4 lbs of dry ice. I chopped it up so it was in small manageable pieces, and would lay the dry ice mix on the sound deadening material for about 10 minutes or so, and slowly chip away the material. It works really well. This makes the material lose its mechanical bond to the surface of the door, and seemingly did not damage the outside paint on the door skin (my goal with this method).
Here's a description from Google: "Adding isopropyl alcohol to dry ice makes the liquid cool very quickly ⏤ the mixture's temperature can reach -90°C (-130°F). At this point, the water inside the flowers, candy, and banana quickly freezes and turns into ice, making these objects 'stoney'."
Old 03-08-2023, 11:25 AM   #213
KyleSeal
KyleSeal's Avatar
I tell ya'll, I know I say the weather where I am holds me back a ton, but I swear it isn't an excuse. Last weekend, around 65 degrees. This week/weekend, high of 50ish. Trying to do the painting I need to when I can, but man its hard to do. Like watching grass grow waiting for better temps to paint in.
Old 03-12-2023, 02:27 AM   #214
Marine15Z28
Although Im a ways away from having the seat in its final spot, I just had to toss it in the truck and see how it felt, and man oh man Im happy with it. I think this seat will wear well and will really make this interior a talking point. I also want to thank n2billet for putting this design on his Tiffany. It was the inspiration for the layout of this bench.
Attachment 2251109 Attachment 2251110
Attachment 2251111
Who did your seat? I wanna do mine with that color vinyl
Marine15Z28 is offline   Reply With Quote
Old 03-13-2023, 08:18 AM   #215
KyleSeal
KyleSeal's Avatar
Lee's Upholstery in Newport News VA, Steven got the job right for me. Give them a call and Im sure they could send the material your way or get you the supplier.
Old 03-13-2023, 04:53 PM   #216
KyleSeal
KyleSeal's Avatar
the many steps to making a repair area look like it wasnt touched.. still have to weather it, but I stacked my colors pretty well hopefully, so maybe it wont be too tough.
Size:  97.6 KB Name:  IMG_5666.jpg
Size:  88.9 KB Name:  IMG_5670.jpg
Old 03-14-2023, 08:09 AM   #217
KyleSeal
KyleSeal's Avatar
Got to getting the patina kind of matched. Some water splatter, multiple layers of rust and dirt colored paint, and some rock salt helped a bit. Given the area they're in, I think Im pretty pleased with how they came out. I wish the paint color was a bit closer, but this was so hard to match given each area is gradually different shades, so the paint guy had a hard time getting a good read on his machine. The hood hinges should break it up some though and make it not as noticeable!
Size:  98.7 KBName:  IMG_5707.jpg
Old 03-17-2023, 10:50 AM   #218
Kronald_70GMC
Kronald_70GMC's Avatar
Just finished getting up to date on this thread. Your doing an excellent job on the truck. I look forward to seeing more.
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is online now   Reply With Quote
Old 03-18-2023, 12:53 AM   #219
PowerdbyChevy79
PowerdbyChevy79's Avatar
Man.. im loving the work.. keep it up.
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 03-19-2023, 10:47 PM   #220
KyleSeal
KyleSeal's Avatar
Hadnt posted the results of the dry ice mix... very clean. I took outside, blew it all out, and went after it with wire wheels, bristle brushes, and finished with a 80 grit DA with a contour pad. Also replace the door hinge pins. Did they really use plastic bushings from factory? These werent sloppy but I figured why - glad I did now that I found those. Also patched the upper portion of the door, had some rust growth and a small section of holes. Came out pretty well actually, not to be seen anyways so I wasn't too pressured to make it look amazing, just straight.
Size:  80.5 KB Name:  IMG_5778.jpg
Size:  76.9 KB Name:  IMG_5774.jpg
Old 03-19-2023, 10:52 PM   #221
KyleSeal
KyleSeal's Avatar
Thanks! Life-stuff has slowed me down a bit... but getting back on it some.
I appreciate the kind words! May sound funny but this thread and my Facebook updates keep me sane working on this stuff!
Old 03-23-2023, 10:05 AM   #222
KyleSeal
KyleSeal's Avatar
Fixed the front edge of the door bottom and it came out pretty good. Need to get it mounted to see about the fitment of the outer skin, so I can remove it and get the new one fitted better.
Size:  73.5 KB Name:  IMG_5801.jpg
Old 03-23-2023, 10:07 AM   #223
KyleSeal
KyleSeal's Avatar
Sound deadener down... Kilmat and Siless 80mil, ran out Siless and put down the excess Kilmat I had from the roof.
Size:  77.5 KB Name:  IMG_5812.jpg
Old 03-23-2023, 10:08 AM   #224
KyleSeal
KyleSeal's Avatar
Satin clear put down on the firewall, dash, and interior. Came out good! I used the Spraymax aerosol can that has the button for the two part mix. Really impressed.
Size:  66.2 KB Name:  IMG_5808.jpg
Size:  82.8 KB Name:  IMG_5811.jpg
Old 03-23-2023, 11:45 PM   #225
cornerstone
I've been impressed with Spraymax also. I used the high gloss clear on a truck I recently bought and sold and that was a great product. The satin clear fits the look of your truck very well.
Your metal work looks good too!
Brian
1967, custom, dropped, lowered
