03-19-2023, 09:43 PM | #101 |
Re: Lets see the engine pics!!
Wow - lots of great engines! Mine is tame by comparison to most, but fine for my '67 farm truck: GM 350 crate motor w/Brodix IK180 aluminum heads, Comp Cams hydraulic roller cam & lifters, Edelbrock Performer EPS intake & AVS2 carb. I dressed it up a bit with a pair of GM Corvette LT-1 valve covers.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
03-19-2023, 10:11 PM | #102 |
Try a couple more of the new engine:
Trying to get the jist of posting pix. So, this engine was a 572/620 engine with very low miles. But, I figured, if I’m going through all the trouble of installing a new engine, I may as well go through it first. I sold the GM aluminum heads off of it, and bought a set of AFR 335v2 heads. Then I messaged Chris Straub, and asked if he could make me a nice solid roller for the street. He asked me what kind of horse power I was looking for, and when I said around 700-750, he just last he’d and said, “That’s it?” I said it only has 9.6:1 compression. He said we can make a lot more then that if you want it to. Make it at least 750 then, I said. So with the cam, I got solid lifters, which took eight months to get, due to Covid. The Jomar stud girdle fits perfect. I had to buy another set of taller rocker arm studs, as with the proper length pushrods, the nuts were nearly on by four threads. Smith Brothers 7/16” x .120” pushrods. And a set of Straub Tech roller rockers. This is a gen 6 block, and I’m using a double roller timing chain from Straub Tech as well. Had to get a different front cover, and modify a cam button for it. Lots of, one step forward, two steps back, on this build. Headers are from Dan Lemon, Lemon’s Headers. (2 1/8” primary, down to 3 1/2” collectors) Edelbrock Super Victor intake. And more I’m sure I forgot to mention. Last edited by Extended Power; 03-19-2023 at 10:26 PM. |
03-20-2023, 04:32 PM | #103 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
It's a .060" over 427 with forged JE domes, L34 closed chamber heads, Comp Magnum roller rockers & rods, Clay Smith 304 solid cam, Howards EDM lifters, Hedman Elite headers. L34 forged crank balanced w/rods & pistons to "dead nuts" Motor for "Nasty Sally" 72 LWB C/10 400THM 12-bolt 4:56 Posi...Low 11's in the 1/4.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
03-20-2023, 04:55 PM | #104 |
WHYBYNU when old will do
My ZZ6 installed 1 year ago. Drove it on power tour 2022.
71 Cheyenne super 2 tone green and white ZZ6 - Th350 4/6 drop 20x8.5 / 20x10 Billet Specialties |
03-21-2023, 02:57 PM | #105 |
Here's a before, after, and nearly complete.
03-21-2023, 04:40 PM | #106 |
Pic of the 68 I did a frame off. LS6/T56 combo.
03-22-2023, 04:14 PM | #107 |
A couple recently after I tidied up the plug wires.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
03-24-2023, 06:54 PM | #108 |
Boy you guys are a tough act to follow ! Incredible workmanship…
71 C-20 07 Magnum RT AWD |
03-25-2023, 05:45 PM | #109 |
No kidding right. Amazing.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-25-2023, 07:57 PM | #110 |
How did I get this OLD!
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023 Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt. |
