![]() Join Date: Dec 2013
Battery cables
I'm Building a heavier set of battery cables using Batterycablesusa.com parts , I ordered parts on Wednesday and they arrived today so 2 day shipping , All copper parts and heavy duty at a good price and fast / low shipping cost I used gauge 2 cables and ordered extra for a few heavy duty ground cables . Good Stuff !
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Battery cables
Looks great! I think I see a hint of flux, is the connector soldered on, or crimped.... or both? I don't own a good crimper and I solder everything. No failures yet.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: May 2012
Re: Battery cables
Nice! Lugs and slugs are the way to go if you don't have the proper crimpers, which I don't. I keep an assortment of lugs and slugs on hand, they're handy.
![]() j
White K20 |
Re: Battery cables
Solder pellets sure make it easy!
When I did mine I used this kind of battery terminal: https://www.wiringdepot.com/ordnance...terminals.aspx They have one large bolt, so you just build all your cables with copper lugs. Makes it nice if you have multiple batteries, winch or other accessories as you can just stack them onto the bolt. |
#5 | |
Re: Battery cables
![]() j
White K20 |
Re: Battery cables
No connection: just thought I'd add this to the discussion:
https://www.ebay.com/itm/Brute-Hamme...0/323773835989
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
Old member
Just for future reference Harbor Freight carries a nice set of cables and connections for this type of stuff.
Already to go 6' and 3'. ![]() https://www.harborfreight.com/6-ft-i...awg-63747.html ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#8 | |
Re: Battery cables
![]() https://www.amazon.com/gp/product/B00QMTAZ1W/
Re: Battery cables
I had three five foot high strand 2 gauge cables, I got on the cheap. Anyhow, a couple of the lugs slipped off from a poor crimps. I like the price, but am now skeptical of the quality of the assembly. Hacked off all the ends and re-lugged. I use the 2 gauge for my winch grounding, the shielding is kind of bunk also. I'll check out the HF stuff too.
Just give the lugs a twist and a yank to see if they're on there good. If not, the re-lug and slug only takes a couple minutes. ![]() j
White K20 |
Old member
I build custom golf carts all the time with 00 welding cables. I have the crimpers and lugs to make whatever size I need.
Grumpy old man, I agree I would rather make my own but sometimes the pre fab ones are just the right length. ![]() ![]()
Re: Battery cables
good cable info back up ^
Re: Battery cables
I really like that terminal with the 90 degree bend for the solenoid post.
Re: Battery cables
I did my booster cables 4/0 used lugs and slugs from napa
I sold my crimper several years back I used it once in 20 years |
Re: Battery cables
I used 2 gauge cables from what I think was an early 2000's GM truck of some sort. Not sure really. I deciphered the battery cable code and then just searched for that on RockAuto until I saw something that looked about right. Since it is for a late model truck the cables were inexpensive and professionally terminated. I think I paid $25 for one and $20ish for the other. Both have a 6 gauge secondary whip that I shortened and torch soldered a copper lug. These 6 gauge are a superior connection to the main harness through a 30 amp MIDI fuse. A red Bussmann Series LMI1-E-0-0 Fuse Holder was used to replace the lame-O factory fusible link.
Here is the fuseholder: https://www.waytekwire.com/item/4639...0-Fuse-Holder/ By the way, if you ever have the GM "hot start problem", switching to 2 gauge makes the problem go away.....
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs Last edited by bry593; 12-07-2020 at 02:30 PM. |
#15 |
All about them K’s
![]() Join Date: Jun 2014
Re: Battery cables
0/0 welding cable with soldered ends on mine, major overkill but I’d rather it be that way than not enough. I don’t do crimped ends, I’ve never had good luck with them. I build battery cables for our compressor engines several times a month at work.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#16 |
Re: Battery cables
To the top per request .
#17 |
![]() Join Date: Dec 2009
Re: Battery cables
Subbed to this for future reference
![]() Good info ![]() .
#18 |
Re: Battery cables
Those look good Grumpy. It's always good to know your electrical system is as good as it can get.
#19 |
Re: Battery cables
#20 | |
68 C10 Longbed
![]() Join Date: Sep 2006
Re: Battery cables
#21 |
Re: Battery cables
Gumpy, what did you do for the pig tail to the terminal on the fender. Simply squeeze a 6 or 8 guage wire into the terminal before solder? Fuse Link? Fuse terminal?
I have been meaning to do this project as well. |
#22 | |
Re: Battery cables
![]() Here is what you need -- fits all GM Cars/Trucks 14 Gauge Thickness 9" Lead Wire Re: part # 8915135 Show Quality! https://www.ebay.com/itm/25587876523...yABEgKkmfD_BwE
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 03-28-2023 at 12:17 PM. |
#23 |
Re: Battery cables
Switching to 2 ought cables is one of the best things you can do on any of our trucks.
I had hot start issues with my 77 454 for several years even though if you were on a slight incline where the truck could roll you could pop the clutch and fire right up. I did the Ford Solenoid trick and that helps a bunch but going to size 2 cables and installing a heat shield were the real cure. I've got the same setup in my 71 with the Cad 500 in it. That truck is still a work in progress but I am gaining slowly.
#24 |
Re: Battery cables
"Rolling your own" cables using #2 is great so you can dress the cables exactly where/how you want. You need a good crimp tool.
I prefer and have side post, 78 series battery, on my 72 and buy premade #2 cables the length I need. I found a link on AC Delco cables that breaks down cable size & length so you can pick a part # that meets those needs. The part # itself will not be the one for your truck per say but be the gable gauge and length you want. Then I just order that part #. I typically get them on Amazon for a very reasonable $ This one for example also has insulation on + cable where it runs along the engine (2=#2, 43= "). https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
#25 |
![]() Join Date: Apr 2016
Re: Battery cables
I wonder if you could please share the link about AC Delco cables?
