Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 04-06-2023, 11:15 AM   #26
Keith Seymore
Keith Seymore's Avatar
Re: Metal Lathe
Originally Posted by Getter-Done View Post
You rung my Bell
Are you ready
I have a 10" Atlas Craftsman lathe (Probably 1940ish)
It has flat ways.
I like it, I use it all the time.
I do not recommend a Flat ways lathe though.
I am restoring a Logan 200 10" lathe currently.
It was made in 1942.
It has a Vee way like most.
Before my Daddy passed away, he drug home a New Haven lathe.
It dates around 1890-1910.
It is a 14"-16" swing, I can't remember.
It's at the shop at Momma's.
With all that said I am a Sucker for old lathes.
But the bad thing about that is,
the parts that cannot be easily made For the lathe itself can
SOME times be bought on E BaYY for a Premium.
I also have a 7"x 10 HF mini lathe.
I Do NOT recommend a Lathe Mill combo.
They are hardly ever perpendicular to each other.
I have a Grizzly Mill drill.
Grizzly makes some good stuff,
Here is one in the price range.
Link: https://www.grizzly.com/products/gri...gearbox/g9972z
An older one is going to probably need work.
One more thing I have an Atlas 7B shaper.
Did I tell you I like old machines.
I will see if I can search for one other than that Grizzly tonight.
If you're still reading this
I suggest no smaller than 10" swing.
At least 24" between centers.
I would stay away for variable drive.
But that's just me because I like old stuff.
Wait I allready told you that
Maybe you could make the part truckster needs and get him going?
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-06-2023, 10:42 PM   #27
truckster
truckster's Avatar
Re: Metal Lathe
Thanks for the kind suggestion.
I looked around for an older, American made lathe, but the prices people were asking put those out of reach.
I used the bed from the Jet lathe and lengthened it to fit the Baileigh. I've been working with it for a while, just practicing in steel and aluminum. I'm getting a pretty good finish in aluminum and getting close with steel. I haven't really built any practical parts yet, but I'm having fun learning.
I got the tailstock alignment dialed in and the ways level within .0005 over the length of the bed, so I think it's cutting pretty true. I also modified it with a quick change tool post, which makes things a lot more convenient.
I still need to buy a few parts, but at least I've got enough to get me started and to get some practice.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 04-06-2023, 10:42 PM   #28
Getter-Done
Getter-Done's Avatar
Re: Metal Lathe
That is a Possibility.
I would be glad to help:metal
As an Experienced machinist taught me.
I will state it nicer than he Did
All I need is a Blueprint and Clear and Detailed instructions
With that being said.
truckers is Street smart on this stuff.
I would be glad to help if I can.
Because I work at a shop with a Lot of years of combined Experience.
truckster what is your status with this project?
84 Chevy K-20
Old 04-07-2023, 02:16 PM   #29
truckster
truckster's Avatar
Re: Metal Lathe
I welded an extension onto the existing lathe bed to accommodate the slightly longer lathe. I have it aligned and leveled. It took me some practice to get proper geometry on my cutting tools. I think I've got a pretty decent finish now.
I think my next project will be a tailstock die holder. I still need to get a 4-jaw chuck, but I haven't gotten that far yet. I'll probably also order a set of change gears so I can do some threading, but, aside from some advice, I don't know of anything else I would need.
Old 04-07-2023, 07:23 PM   #30
JJH Jimmy
JJH Jimmy's Avatar
Re: Metal Lathe
Here is mine late 40’s early 50’s Atlas. It does everything I need. I would like to get a quick change tool holder in the future. I also have an Atlas drill press and it is still way better than the Chinese crap that is out there. Best part is there were both built in my hometown Kalamazoo.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 04-07-2023, 08:54 PM   #31
Getter-Done
Re: Metal Lathe
Nice work on extension
Finish looks great. WD-40 is the best lubricate for aluminum.
I use a 4 jaw all the time to dial parts in to the 0.0005 range (when I can).
Once you get your 4 jaw and get used to it.
I suggest getting a 5C Collet Block Set.
Then buy a set of 5C Collets
I buy alot of stuff from CDCO machinery.
Shars on ebay is also a good source to skip the shipping charge.
84 Chevy K-20
Old 04-07-2023, 08:58 PM   #32
Getter-Done
Re: Metal Lathe
Loving the Quick change box
I have a 10F Atlas about the same vintage.
I also have a soft spot for old Drill presses.
84 Chevy K-20
Old 04-07-2023, 09:55 PM   #33
truckster
truckster's Avatar
Re: Metal Lathe
Attachment 2266091
Thanks for the compliments and for the advice.
Old 03-12-2024, 04:21 PM   #34
68 C10 Driver
Re: Metal Lathe
Antique tools rock. I love the simplicity of them.
68 C10 Driver is offline   Reply With Quote
