Old 05-05-2023, 08:48 PM   #1
1967GMCC20
1967GMCC20's Avatar
Putting miles on 67, 402bbc VS 67 V6 305E
Amazed how much better this GMC drives after pulling 305E and upgrading to 402 BBC. conversion.
Drives like a car, smooth, V6 was unique, but seriously under powered.
305E V6 7.5mpg. 170hp
402 bbc 12mpg. 310hp
1967GMCC20 is offline   Reply With Quote
Old 05-05-2023, 08:58 PM   #2
jimijam00
Re: Putting miles on 67, 402bbc VS 67 V6 305E
What year is the 402? GM didn't punch out the 396 until 1970.
jimijam00 is offline   Reply With Quote
Old 05-05-2023, 09:06 PM   #3
1967GMCC20
1967GMCC20's Avatar
I got the 402 from a 1970 SWB CST takeout.
All date codes are correct for vehicle it came from.
All I changed was intake to a Holley cast iron 1966 hi rise.
Old 05-05-2023, 09:08 PM   #4
1967GMCC20
1967GMCC20's Avatar
Thinking next upgrade, is a gear vendor over drive. Then I can run freeway speeds..
Old 05-05-2023, 09:20 PM   #5
Gladyou like it. Theb6 can rip a building out of its foundation, but definitely lacks hiway guts. The OD will definitely help calm the BBCon the hiwY also
Old 05-05-2023, 09:26 PM   #6
1967GMCC20
1967GMCC20's Avatar
Yep, V6. Had good low end lugging torque, but also lacked RPM. It went to a good home, guy restoring K20 4x4 GMC V6 truck.
This 402.. goes up steep hills in Drive that put my V6 in 1st.
I only need OD and then this is a true parts chaser.
I have the NP435G trans, and trans cross member and mounts, and engine mounts for V6 if someone needs them.
Old 05-05-2023, 11:18 PM   #7
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Your very likely ruined for life! Once you feel the torque and the pony's them BBC's make, they own you! "Jus sayin"
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 05-06-2023, 01:11 AM   #8
RustyPile
RustyPile's Avatar
Got a 454 in my '71.. It's a disease I tell you. The first symptom is you go around with a smile on your face. Also makes you forget about gas mileage..
RustyPile is offline   Reply With Quote
Old 05-06-2023, 10:19 AM   #9
factorystock
factorystock's Avatar
When GM started offering the 396-402 in 3/4 tons, a 3.54 Dana became standard equipment, but, if you have the wallet......................
factorystock is offline   Reply With Quote
Old 05-06-2023, 12:24 PM   #10
MikeB
MikeB's Avatar
What's the current axle ratio? A mild 402 with all that torque should work just fine with a 3.08 or even a 2.73, depending on tire height and desired highway speeds.
My 82 C10 had a mild 355/TH350 with a 2.73 and 29.5" tall tires. Cruising at 70mph was ez-peezy, but it would spin the tires in first gear.
Just trying to save you from OD expense and hassles, although the GV should be less of a PITA than a 700R4. And it will never break!
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-06-2023, 01:49 PM   #11
1967GMCC20
1967GMCC20's Avatar
Ran another 100mi + today, with 10gal of premium thru the big block.
Truck has 4.10 gear Dana 60.
Old 05-06-2023, 04:11 PM   #12
So 8 to 10 MPG whether your driving easy, towing or whatever then.
Old 05-07-2023, 08:23 AM   #13
1967GMCC20
1967GMCC20's Avatar
Front sway bar is going to be next.... lot of nice winding roads to be seen.
Old 05-07-2023, 08:27 AM   #14
1967GMCC20
1967GMCC20's Avatar
12mpg rolling empty road trip, 55mph is. 402bbc
V6 7.5mpg uphill, down hill, hauling water.. it just liked fuel. But since designed in late 50s, looks like ports from a 348...anchor, neither designed for fuel economy, but fuel was cheap. Massively heavy built, designed for durability. My old V6 is going in a 67 4x4 restoration, his block was cracked. Win-Win
Old 05-08-2023, 02:53 PM   #15
67km1590
Junior Member
If your friend would happen to know of a extra set of V6 4X4 engine perches I'm in bad need of a set for my restoration. My truck had been converted to a sbc at one time but it did have the original V6 with it. Thanks for any help.
67km1590 is offline   Reply With Quote
Old 05-08-2023, 04:31 PM   #16
1967GMCC20
1967GMCC20's Avatar
Are the front mounts the same? Bell housing on mine was 4spd,
If yours is a stick, it might be the same.
Old 05-08-2023, 04:32 PM   #17
1967GMCC20
1967GMCC20's Avatar
You pay shipping, you can have them.
Old 05-08-2023, 04:33 PM   #18
1967GMCC20
1967GMCC20's Avatar
Where in ohio? Pick them up, you can have three mounts, brackets, x member.
Old 05-08-2023, 04:48 PM   #19
67km1590
Junior Member
I'm in Batavia, mine is a 4sp. Could you send me pictures, if they're right I'll be on the way. Thanks
Old 05-08-2023, 05:41 PM   #20
1967GMCC20
1967GMCC20's Avatar
Bet it's same, not too many ways to mount that V6. Heading down to barn.
Old 05-08-2023, 06:00 PM   #21
67km1590
Junior Member
I may not be able to get back to you until tomorrow.
Old 05-08-2023, 06:04 PM   #22
1967GMCC20
1967GMCC20's Avatar
No problem, bet there is only one set of mounts for V6, big engine tight fit. I have eng mounts and frame mounts. And crossmember for bell housing to frame with mounts.
My 67 is here to look at frame hole locations.
Old 05-08-2023, 06:19 PM   #23
1967GMCC20
1967GMCC20's Avatar
Had a 78 suburban with 454, ran good, ended putting eng and trans TH400 in a 78 Silverado that was originally a diesel. It had 2.73 gears. Was perfect for Texas freeways and FM roads.
Old 05-09-2023, 09:44 AM   #24
67km1590
Junior Member
The frame mounting brackets (perches) and front crossmember are different on 4X4 vs 2WD. I have the brackets on the engine and a crossmember I've found (same as chevy 292 4X4) but I'm short the frame brackets. The rear mount crossmember I have as it was the same for chevy V8 or GMC V6 4X4's.
Old 05-09-2023, 09:59 AM   #25
1967GMCC20
1967GMCC20's Avatar
So the rear X member on bell housing is same. Mine is all there. The engine Bell housings were (Not HD SAE), so I suspect similar.
I chisled the rivits, not torched.
I have the dust shield from Bell housing. Got left behind when I sold engine.
1967, 305e, 402, gmc
