Old 05-12-2023, 05:12 AM   #1
gmc 2500 4x4
rear end shudder
im having a slight issue, 69 gmc k2500, all redone, i went from 4:56 gears to 3:54. it now has a bb 402 and original sm465 trans, and rockwell 221. im getting a shudder when slowing down in 2wd, even when i push in the clutch. would the gearing change affect the t/case? has a 4'' lift also, and i did shim the rear axle for driveshaft alignment...
gmc 2500 4x4 is offline   Reply With Quote
Old 05-12-2023, 06:39 AM   #2
kwmech
Re: rear end shudder
Any other description besides 'shudder'? only thing that comes to mind is while applying the brakes
Old 05-12-2023, 06:56 AM   #3
gmc 2500 4x4
Almost feels like something is binding up with no brakes applied
Old 05-15-2023, 08:56 PM   #4
HO455
HO455's Avatar
Do you have a clutch style Posi?
RIP Bob Parks.
Old 05-16-2023, 04:48 AM   #5
gmc 2500 4x4
i do not, i need to jack it up and run it see what i see, this has the carrier bearing also which is new.
Old 06-02-2023, 09:52 AM   #6
gmc 2500 4x4
i pulled out the degreed shims, also gonna start over and bolt up the rear like its written in my books. its only a 4'' lift so im going to try with out shims
Old 06-02-2023, 10:53 AM   #7
jeffahart
jeffahart's Avatar
First thougt for me is something is loose or broken. Nut and bolt everything while you're under there. An easy 20 minute sanity check. You shouldn't have to play with angles. Read your angles and shim appropriatly, it's all that's needed. How about those bearings?
j
White K20
jeffahart is offline   Reply With Quote
Old 06-02-2023, 11:27 AM   #8
gmc 2500 4x4
Rear was all redone, like i said there is a procedure and not sure if I had all tension out of springs and shackles or proper torque on u bolts. It's what happens when u build something and few yrs later u 4get things...lol keep ya posted
Old 12-23-2023, 07:14 AM   #9
gmc 2500 4x4
when i let off the throttle the pinion angle changes giving me that vibration, been adjusting the angle and seems better. i may use this kit https://www.ebay.com/itm/165624965840, whats yur opinion?
Old 12-24-2023, 05:32 PM   #10
cj847
cj847's Avatar
I think you are on the right track looking at u joints. I bet you can reuse your yoke. Also check your center support bearing.
cj847 is offline   Reply With Quote
Old 12-24-2023, 05:38 PM   #11
gmc 2500 4x4
When you decelerate and brake its worse as the pinion is nosing down even more leading me to believe it's binding. I'll get it
Old 12-24-2023, 08:53 PM   #12
geezer#99
geezer#99's Avatar
Are your spring packs stock with leaf clamps. Also known as rebound clips.
Old 12-25-2023, 08:43 AM   #13
gmc 2500 4x4
4'' lift springs and u bolts
Old 12-25-2023, 01:10 PM   #14
geezer#99
geezer#99's Avatar
Post a pic of your springs etc.
Old 03-30-2024, 08:41 AM   #15
gmc 2500 4x4
http://67-72chevytrucks.com/vboard/s...d.php?t=220466 got my answer #25
