Old 09-06-2022, 02:21 PM   #101
slammed57
slammed57's Avatar
Re: Back to the fifties with a 59 project
Lookin REAL good bud!
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 09-14-2022, 10:32 AM   #102
Hubscrub
Cruzin
Hubscrub's Avatar
Passenger side done.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 09-14-2022, 06:29 PM   #103
Hubscrub
Cruzin
Hubscrub's Avatar
Started a floor patch. I didn't see the point of spending close to $100 for a patch I would only use a small part of so I'm just using metal I have. It won't look factory but nobody will probably ever notice.
Proverbs 3:5,6
Old 09-14-2022, 06:49 PM   #104
57FleetsideC4
Looks great Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 09-17-2022, 02:10 PM   #105
Hubscrub
Cruzin
Hubscrub's Avatar
Floor patches done.
Proverbs 3:5,6
Old 09-17-2022, 02:14 PM   #106
Hubscrub
Cruzin
Hubscrub's Avatar
I have to fix above the windshield some spots but I'm gonna take a break from the welding,cutting, grinding. Would like to remove the cab and finish the frame cleanup and suspension.
Proverbs 3:5,6
Old 05-20-2023, 12:40 PM   #107
Hubscrub
Cruzin
Hubscrub's Avatar
Cleaned up the rest of the frame. Welded in some metal where I clearenced for the rac and pinion. Also removed the old trans crossmember.
Proverbs 3:5,6
Old 05-20-2023, 12:43 PM   #108
Hubscrub
Cruzin
Hubscrub's Avatar
Welded up everything fully and got the front suspension mocked up and the steering rack also.
Proverbs 3:5,6
Old 05-20-2023, 12:53 PM   #109
Hubscrub
Cruzin
Hubscrub's Avatar
Got a late 70s camero rear end and got it bolted up moved to the top of the springs, not welded until I set the pinion angle etc. Fab up me some leaf spring plates. Got it centered and good enough be able to make it roll. Got to work on shock mounts still maybe a small c notch not sure yet. Also planning on do a disc brake conversion since the price isn't really that much more than totally rebuilding all the drum brakes.
Proverbs 3:5,6
Old 05-20-2023, 12:54 PM   #110
Hubscrub
Cruzin
Hubscrub's Avatar
We have a roller!
Proverbs 3:5,6
Old 05-20-2023, 10:41 PM   #111
dsraven
nice progress.
question, with the lower control arms sitting level, what angle is the upper control arm?
Old 05-22-2023, 07:58 AM   #112
Hubscrub
Cruzin
Hubscrub's Avatar
Originally Posted by dsraven View Post
nice progress.
I really haven't even noticed, but it needs weight on the front to get everything where it needs to be. It is stiff up front with everything new and i ordered the upper end of stiff coil springs. I will probably end up cutting a little off of them but i'm waiting till i get all the weight on it and they have time to settle.
Proverbs 3:5,6
Old 05-22-2023, 09:46 AM   #113
72 tigger
72 tigger's Avatar
Looks good!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 10-04-2023, 05:05 PM   #114
Hubscrub
Cruzin
Hubscrub's Avatar
Gonna post some progress. I finished cleaning the frame and underside tof the cab. Painted and seam sealed, painted frame where cab will set.
Proverbs 3:5,6
Old 10-04-2023, 05:07 PM   #115
Hubscrub
Cruzin
Hubscrub's Avatar
Reinstalled cab with new mounts etc. And decided to try and mock up engine and trans.
Proverbs 3:5,6
Old 10-16-2023, 06:56 PM   #116
Hubscrub
Cruzin
Hubscrub's Avatar
Built some motor mounts and mocked them up. Not a professional job but I made with what I had and a welder and a grinder. I'm not as happy with the driver side it was a little different mounting wise but I think I'm gonna leave it.
Proverbs 3:5,6
Old 10-16-2023, 07:00 PM   #117
Hubscrub
Cruzin
Hubscrub's Avatar
Got the trans crossmember fitted and welded on some mounts and mocked in place. It came from speedway motors universal 2in drop crossmember very happy with it.
Proverbs 3:5,6
Old 10-16-2023, 07:28 PM   #118
dsraven
engine mounts look fine. curious what your driveline angle is now. angle at pinion should match but be opposite the angle at the trans. that way the vibrations cancel each other.
Old 10-16-2023, 07:31 PM   #119
dsraven
if you needed to by steel for that i suggest square tubing with a decent wall thickness, then cut one side off to open it up. works well.
Old 10-16-2023, 07:53 PM   #120
Stepside Jim
I like the amount of space the 6 cylinder gives for the steering column to rack gives, should be a straight shot.
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132
Stepside Jim is offline   Reply With Quote
Old 10-16-2023, 08:42 PM   #121
dsraven
I noticed that as well. nice.
Old 10-16-2023, 11:06 PM   #122
Hubscrub
Cruzin
Hubscrub's Avatar
Thanks, I haven't welded the rear end perches in place yet so I can set it to a happy angle.
I was worried about that but looks like it not gonna be to bad.
Proverbs 3:5,6
