Bed Wood Install Question?
What Steps Do I Take Going About Installing The Bed Wood On My 69 C10?
The Woods Painted. Do I Keep Everything Loose Then Bolts The Tailgate on Then Tighten Everything? Any Help Would Be Appreciated Posted via Mobile Device |
![]() ![]() Join Date: Apr 2022
Re: Bed Wood Install Question?
Is the rear cross sill still welded to the sides to keep the box square? If it is you can install the wood and strips without the tailgate on. On the one wood floor truck I did, I left all the strips loose until all the wood was in and then started tightening down everything.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
Im Not Sure If Its Welded. I Have All The Panels On The Box Loose
![]() Join Date: Dec 1999
Are you converting from a metal floor? Replacing the rear crosmember and front bed panel?
I built an entire wood floor bed from parts. Put it all together except the bedwood, strips and wheelhouses. Then I made sure everything lined up. Took the tailgate back off and painted everything. Did like camaroboy68ss says and put all the wood and strips in loose to get everything gapped 'equally' and then started tightening. Then I put the rear wheelhouses in and the tailgate back on. |
![]() Join Date: Mar 2005
Get ready for 10 million bolts to tighten. I did mine not long ago.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
![]() Join Date: Jan 2007
Sounds like what I remember lol
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
![]() Join Date: May 2012
Here's link on doing bedwood install I documented. Maybe something in there can help.
http://www.67-72chevytrucks.com/vboa...d.php?t=712823 It not hard just some busy work. Good Luck! ![]() j
White K20 |
![]() Join Date: Sep 2001
If you have a step side bed, you will need to loosen the step supports to tighten two of the bed bolts. I took out the two top bolts and loosened the two smaller bolts that go down through the step into the support, and this let me move the support out of the way for removing those two bolts - I took my bed wood out yesterday for refinishing.
Jeffahart I was looking through your writeup and it reminded me of something I did on mine. If you use the Mar-K cross sills they have square holes to capture the carriage bolts that attach the bed to the frame. You can then rout out the wood for the bolt head and not have them visible on your bed floor.
Picture from the Mar-K catalog... |
#10 | |
![]() j
White K20 |
