Junior Member
![]() Join Date: Jun 2003
Engine to frame ground
Looking for a picture or diagram of engine (small block) to frame ground connection. Any help is appreciated. Thanks
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Engine to frame ground
This is how I ground my motors...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Junior Member
Thank you, Ironangel.
Your welcome! I have a spool of that stuff so I make my own. Never hurts to add a strap to the fender and the fender to the cab. Cant have to many grounds...
![]() Join Date: Nov 2018
I bought straps on Amazon and put them where the FSM showed for a 6 cylinder
As said above you cant have too many good grounds. I go from battery to engine block. Then engine to frame with heavy gauge cable.
Then frame to cab on both sides with 6 gauge cable using ring terminal and heat shrink. Then radiator to frame with 6 gauge like the cab. Then frame to box for good tail light grounds. Also if you have a rear mounted gas tank/fuel pump they need good grounds. My builds are LS swaps and they demand good grounds. |
Who Changed This?
![]() Join Date: Jan 2013
Back when I was having hot start problems, one of the things I did was to run the battery ground cable directly to a starter motor mounting bolt. I'd have to go back and see if that actually helped. The reasoning is sound, though. A little resistance here, a little resistance there...when you're running a lot of amps, it makes a difference.
