temp sensor machining
Someone on this board was(is) machining the OEM temp. sensor down to fit the LS 1 head, Can't seem to find him on old threads, HELP Please.
Re: temp sensor machining
May be not for you but I drill and tap the head for the correct NPT size. That way if the sensor fail a new one is only a NAPA parts store away.
#3 | |
![]() Join Date: Nov 2013
The standard sensor has 1/2"-NPT threads, the Vortec heads are 3/8"-NPT the LS is 12mm There isn't enough material to modify the original sensor to 12mm (.472") here's a cut-away of an original sensor, the small end is .550" diameter.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
thanks, I was thinking you were doing machining for LS1 heads. My mistake.
no worries…I wish they would work
![]() Join Date: Mar 2015
I used one of these.
https://www.amazon.com/Engine-Adapte.../dp/B015NG418C Seems it would change the calibration because it extends out so far. I have not had any issues with mine. Others use the LS part and connect it to the original system. Maybe someone can find the link as I had no luck. Cheers |
![]() ![]() Join Date: May 2015
I do what ls short box did...drill/tap pass head to npt..
#8 | |
![]() Join Date: May 2005
I drilled and tapped water pump for correct sending unit.
