Old 06-08-2023, 12:57 AM   #1
Bob B.
Coolant Overflow Bottle
What is the best factory appearing radiator overflow bottle anyone has come up with? I figure there must be some GM car or truck that used one that fits well and looks right in a '67-'72.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is online now   Reply With Quote
Old 06-08-2023, 03:13 AM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Coolant Overflow Bottle
I use this washer bottle and bracket. I simply run a 5/16" or 1/4" hose from the radiator filler neck barb to the bottle. Use a 16 PSI Lever lock radiator cap and your radiator stays full and drip free. Bottle should be about half full when the engine is up to temp. https://www.lmctruck.com/1967-72-che...per-and-washer The bracket, bottle and cap, and enough hose to plumb it. LMC has the bottles backordered but Classic Parts has them. One of the venders here will surely have these as well... https://www.classicparts.com/Misc-Wi.../products/294/
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 06-08-2023, 05:04 AM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have one for a late '70s Nova.[?] It's an OER part. Got it from Jeg's. Kind of a teardrop shape, but it tucks perfectly inside the passenger/side fender, next to the battery box.
Sorry I can't recall P/Ns, and my pix are trapped on my old computer.
The only drawback was that I had to pull the battery carrier to mount it. It's suspended by a single bolt thru the pass/side fender, just aft of the fusible link terminal. Most of the weight is borne by the inside fender skirt.
Old 06-08-2023, 06:38 AM   #4
Ironhorse
Ironhorse's Avatar
On my '71 4x4 I used a factory mount bracket and W/S washer bottle like is found on the driver's side and mounted it to the passenger side just aft of the battery. Use a 16 lb. closed system cap with the safety release lever and some clear vinyl tubing. Keep it at about 1/3 full when cool, works well and looks as if it is a factory install.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 06-08-2023, 07:23 AM   #5
A1971Blazer
A1971Blazer's Avatar
https://67-72chevytrucks.com/vboard/...light=overflow
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 06-08-2023, 10:19 AM   #6
truckster
truckster's Avatar
I used the washer bottle and bracket as well. It looks like it belongs there. I used an S-10 washer bottle with a pump for the windshield washer.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 06-08-2023, 10:36 AM   #7
72SB
This is a $11 Dorman "coolant recovery" tank (read it is like a modern closed system vs "overflow")
I used a spacer to match the offset from core support on one of the 2 attachment screws. The hole for the hose from radiator is already in the core support. Coolant recovery tanks require a "closed system" cap. You fill radiator completely up vs leaving them 3" low for coolant expansion. As coolant heats up it expands into the "recovery" tank and when the motor cools, it is drawn back into radiator. The hose from radiator goes into the bottom of the tank vs the top of a "overflow" only tank so it can be drawn back into radiator, like a modern cooling system.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The tank noted that would fit inside PS fender is for a 75 Nova ($45 on Summit). I have one in my 67 Camaro. My 72 C10 has the vapor canister in that area so I elected to go Dorman route on the truck
72SB is offline   Reply With Quote
Old 06-08-2023, 11:21 AM   #8
truckster
truckster's Avatar
The hose on an overflow tank goes to within 1/2" of the bottom of the tank. It works the same way. Manufacturers have built them like that for years. Modern cooling systems on most vehicles incorporate the tank into the cooling system (it's under pressure), so there is technically no recovery tank.
Old 06-08-2023, 12:55 PM   #9
Bob B.
Thanks! I will look into the Nova bottle. Saw on the web some use a G body bottle, it's curved on the bottom and fits on the right inner fender too.
Old 06-08-2023, 12:59 PM   #10
72SB
This is the 75 Nova tank I put in my 67 Camaro. It should also work on a C10 unless you still have EVAP canister installed
Old 06-08-2023, 05:42 PM   #11
slikside
slikside's Avatar
I bought another windshield washer tank for a '72 right off the parts board here. I mounted it on the core support same as in post #6. Works great, and looks like it was meant to be there.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor.
slikside is offline   Reply With Quote
Old 09-06-2023, 05:44 PM   #12
MikeB
MikeB's Avatar
What are the dimensions? I have some A/C hard lines in that area.
Never mind, I found them. But is it really 4.25" wide (front to back)?
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 09-06-2023, 06:52 PM   #13
samkost
samkost's Avatar
Some impressive and functional mounting ideas here.
The tucked away Nova one in particular.
I used an aftermarket windshield washer tank.
Works well.
Sam
1972 C10 LWB
2020 Z71 Tahoe
samkost is offline   Reply With Quote
Old 09-06-2023, 07:13 PM   #14
1967GMCC20
1967GMCC20's Avatar
I've seen these at swap meets, going to get one. Opticlean glass bottle.
1967GMCC20 is offline   Reply With Quote
Old 09-06-2023, 08:11 PM   #15
maverickmk
maverickmk's Avatar
Is this the one you're talking about?
https://www.oerparts.com/product/all...ts/551448.html
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 09-06-2023, 08:26 PM   #16
'68OrangeSunshine
I can pull up my own pix now. New computers take a while to get used to.
But, Yeah, that's it. Looks like they went up another $5 in price. But I got mine from Jegs.
I had the Nova puke tank installed on my '68 C/10 Stepside, but the 292 runs so cool, I didn't need it, so I moved it over to my '71 GMC Jimmy K/1500 w/ a 350. Still working out the bugs.
The Radiator shop repaired my 4 core copper/brass radiator OK, but they ignored my instruction to clock the filler neck relief outlet to the rear at 6'o'clock.
Old 09-06-2023, 08:46 PM   #17
maverickmk
maverickmk's Avatar
Thanks for the picture - I was wondering how it fits in there. I'm definitely going that route now!
Old 09-06-2023, 08:50 PM   #18
'68OrangeSunshine
Kind of a PIA, that you have to pull the Battery, then the Batt Box, to get it in there, but once you're past the surgery, it fits like it was meant to be there.
My old Batt Box was corroded thru, so I had to replace it anyway.
Old 09-07-2023, 09:00 AM   #19
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Coolant Overflow Bottle
A member used a '90's GM van tank
The 1972 OEM tank:
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 09-07-2023, 10:05 AM   #20
MikeB
MikeB's Avatar
I have electrical stuff mounted in two of those areas, and A/C hard lines in another, but you all have given me some ideas.
Mike
Old 09-07-2023, 01:05 PM   #21
72SB
I have sold the truck but yes, the dimensions are what listing notes. One good thing about Amazon is easy returns
If you see my pic I used a spacer to absorb the gap for the PS hold down screw to core support.
Old 09-07-2023, 08:49 PM   #22
davischevy
davischevy's Avatar
Mine.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 09-09-2023, 01:20 AM   #23
Casper42
Casper42's Avatar
my set up on '72 C10 with 350 from the Atlanta plant
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 09-09-2023, 12:29 PM   #24
Bob B.
Someone needs to repop that 994230 kit!
