View Poll Results: If you had the option, which of these grills would you use? | |||
Original 66 painted grill | 1 | 20.00% | |
64-66 C60 painted grill | 2 | 40.00% | |
an original aluminum grill that needs to be restored | 2 | 40.00% | |
the repo aluminum grill that is now available | 0 | 0% | |
Voters: 5. You may not vote on this poll |
08-20-2023, 09:28 PM | #1001 | ||||
Re: pdx-sanity66
Thanks. I haven't even seen it in person yet. Quote:
Here are a few more pics of progress. The right fender needs a repaint and the front bumper and grill are still at powder coat. Just a few more days.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
08-21-2023, 09:34 AM | #1002 |
Re: pdx-sanity66
Looks great!
08-22-2023, 11:48 AM | #1003 |
Re: pdx-sanity66
Just a little update. The front grill and bumper are back from powder coating, and the fender repainted.
I'm hoping to pick Sanity up on Friday.
08-22-2023, 07:01 PM | #1004 |
Re: pdx-sanity66
Very nice... love the colors.
08-26-2023, 12:16 PM | #1005 |
Re: pdx-sanity66
Thanks Clem, I love the color. It turned out just as I had envisioned. I'm looking forward to getting the bed finished up. The temperature down here has limited my time getting the urethane laid down. I've got 2 coats on so far.
My Sanity has come home. Now it's time to finish up a few loose ends to finish it up. The front grill insert "CHEVROLET" needs to have the background painted black. pics of Sanity back home.
09-13-2023, 10:42 AM | #1006 |
Re: pdx-sanity66
I'm sure I've missed quite a bit so I'm planning on reading back but man sanity is looking good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
09-13-2023, 03:45 PM | #1007 | |
Re: pdx-sanity66
We took a week off and went to Vegas. 5 days of Blues music and fun at the Westgate Big Blues Bender. This was our 3rd time and we're planning on next year, hopefully. Now it's time to get back to work.. I'm still working on the bed wood. 3 coats so far. I'm also working on the grill letters. They were powder coated with the grill and bumper but on the letters. they just blend in with the background. So I am painting the background black. I am also prepping the inside of the doors and the door panels for paint.
10-22-2023, 11:41 AM | #1008 |
Re: pdx-sanity66
It's been a while since I've posted but I've been getting done.
I've got the door window fuzzies in and the windows roll up and down very nicely. I've got new door handles with matching locks installed. I found some reverse lights I like and they are installed but I need a switch for them. I serviced the transmission. drained, remove the pan and installed a new gasket, removed the temporary filter that was installed to catch any debris that might have been in the lines, cooler, etc. It was in the output line of the cooler. I also installed the temp sender for mt trans temp gauge. More on that later. I took the grill letters off and painted the background black and reinstalled it. And I've got 5 coats of satin urethane on the bed and it is ready for the final coat. We're getting some cooler weather coming this week so I should be able to get it done.
10-23-2023, 10:04 PM | #1009 |
Re: pdx-sanity66
The black paint behind the letters really makes them stand out much better. Well done!
I also like your reverse light idea. Are they pointed straight out on both, or do you have each angled towards the side of the truck a little?
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-24-2023, 04:11 AM | #1010 |
Re: pdx-sanity66
What a nice truck, the grill thing is very well done.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
10-27-2023, 01:09 PM | #1011 | |
Re: pdx-sanity66
I really like how the letters turned out. Thanks, I have the grill off right now and I have put the insert back in. While the grill was out I decided I would redo the headlight wiring. I did this a long time ago and I used a kit with 30A relays and wiring for the headlights. There was extra wire and some questionable wiring that I needed to clean up. So I rewired and cleaned up the mess and it is much better now. Final assembly today and the job is done. My bed wood is finished so I will be figuring out how I'm going to get the bed off without buggering the paint, getting it put together, and back on the truck.
10-28-2023, 05:54 AM | #1012 |
Re: pdx-sanity66
Looking great man! I also like the reverse light idea and it wouldn't be too bad to make a little shim for them if they do need angled some. Looking at it actually seems like a kinda obvious place that is never used, I even have a bracket for a set of hitch mounted back up lights and never thought to use the plate.
11-02-2023, 12:30 PM | #1013 | |
Re: pdx-sanity66
First, I removed the filter at the outlet of the tank. It looked fine but I decided to bypass it while continuing checking the lines. Oh, and Next I checked the filter by the inlet to the carb. It is fine. I did some checks on the fuel pump It was pumping but it doesn't seem to have enough pressure to get gas to the carb. So I'm guessing the pump is bad. Any thoughts on my problem are welcome.
11-02-2023, 04:47 PM | #1014 |
Re: pdx-sanity66
Weak pump due to bad diaphragm or clog in the actual lines would be my next guess. Checking the lines is a free fix where the new pump will cost money so I would start by blowing air through lines one at a time. If you have someone that can hold a rag over the other end I would try little air from pump connection back to tank line and just see if anything comes out and then try the line from pump to carb.
11-03-2023, 03:39 AM | #1015 |
Re: pdx-sanity66
Maybe you would like to take the filter out of the suction line in front of the fuel pump and test it without it.
I know that the filter should be located in the pressure line to the carburettor.
11-03-2023, 10:36 AM | #1016 |
Re: pdx-sanity66
I went through three (THREE!) Carter mechanical pumps in the course of two (TWO!) years with my '77 Silverado, then went electric with an AC Delco EP12S which lasted six years, and lastly did a Carter 4070 with a regulator and then sold the truck.
Most fuel pumps can push well, but do not suck well - make them push through the filter, not suck through it.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
11-03-2023, 01:32 PM | #1017 |
Re: pdx-sanity66
Thanks for the comments. I have done all you recommended. I cleaned the lines with air and no plugging. I decided to remove the filter at the back near the tank. It did not seem to be clogged but I left it out. I also checked all of the lines and filter from pump to carb and they were also clean. I had my wife crank the engine while I checked to see if any gas was getting through the pump. It was pumping gas but very little pressure. It doesn't seem to have enough to get to the carb. It is still dry. So I was pretty sure it was the pump, so I removed it and took it apart. The gasket/seals were not torn but looked stretched out and dry. have bought a new Edelbrock pump and I will be putting it on today. Man, I hope this is it. This is show and cruise time down here in Tucson that I'd like to start taking part in.
11-07-2023, 02:02 PM | #1018 |
Re: pdx-sanity66
I got the new pump installed. I pumped the gas 5 or 6 times while cranking and Sanity fired right up. In fact, after it sputtered a few times it smoothed out and is running great. I took Sanity for a test ride and I think it's running the best it has run. I think the pump had been weak for quite a while before it finally failed. Anyway, I'm back on the road and getting some miles on the truck. I've got the inside of the doors to prep and paint, the new bed wood is finished and ready to install, and a couple of other small things to finish, but I'm driving. It feels really good.
11-09-2023, 12:22 PM | #1019 |
Re: pdx-sanity66
I've got all of the lights working.
11-10-2023, 12:53 AM | #1020 |
Re: pdx-sanity66
Well, that's convinced me. I need to get a set of roof lights too. Looks great all lit up!
11-12-2023, 02:05 PM | #1021 |
Re: pdx-sanity66
I've always liked the roof lights but most trucks have 5. I don't like the way they are mounted with 5. I was also looking for painted rather than chrome.I finally found these and restored them. I also showed Sanity for the first time at the "Truly Nolen" show here in Tucson. There were about 150 cars and trucks at the show. I didn't win anything, but I got a lot of great comments on Sanity and I got to see some really nice cars and trucks but just a few 60-66 trucks. I had a great time.
11-22-2023, 06:20 PM | #1022 |
Re: pdx-sanity66
I've decided to do the bed wood install on Sanity.
I've had the wood done for some time but I have been having fun driving the truck. The weather is starting to get cool, so I decided to go ahead and get it done. I set up my overhead lift, removed the rear bumper because it sits so close to the bed (it just made things easier), unhooked the wiring, and got started. I was not sure if I would need help but once I got started, it lifted off reasonably easy. I pulled Sanity out from under the lifted bed, and then set the bed on sawhorses. I'm the Thanksgiving cook around here so things have come to a halt. Happy Thanksgiving to you all.
11-22-2023, 10:06 PM | #1023 |
Re: pdx-sanity66
When I did mine I stood it up on the front panel( on some blankets). I used a couple of ratchet straps in an x to hold it square.
Edit: found the picture Last edited by bigmoe; 11-23-2023 at 09:27 PM. |
11-25-2023, 01:37 PM | #1024 |
Re: pdx-sanity66
I have seen it done this way before on the forum but I was just afraid of messing up the front edge of the bed. I have been doing this by myself and I think this is a pretty good way for me to reach everything and I can make any adjustments as needed. I had everything pre-fitted before I tore it down and finished the wood. I'm hoping it hasn't moved much or at all. Right now I am just about ready for assembly. I have one cross sill that I need to work on first.
12-13-2023, 04:41 PM | #1025 | |
Re: pdx-sanity66
-Pickman (Mike) 1964 C10 Fleetside LWB “George” 1963 C50 “Green Machine” 2019 Silverado 2500HD My story (Welcome Page) |
