Old 12-24-2023, 04:32 PM   #1
MrBubbles
Identify this door hinge!
I was disassembling my door hinges in prep to rebuild them and the top hinge that was on the drivers door doesn't seem correct. My truck is a bit of a basket case build in that I got it in pieces.
The top door hinge should have provisions for two springs, however it only has one. The passenger side hinges look as expected. The drivers side hinges physically fit. I'm figuring I need to find some different hinges for the drivers side but thought I'd ask if someone knows that hinge this is from?
Seems 'Atwood' is stamped on the hinge. I found an ebay listing that showed similar for a hinge that was listed as a GMC but it had provisions for two springs like you would expect. The bottom hinge has the same stamping.
The hinge pocket side (not sure what to call it) only has one slot in it, not one of each side. Also the hinge slot seems to have a bushing.
Similarly, the hinge bar only has a hole drilled on one side for a spring
MrBubbles is offline   Reply With Quote
Old 12-29-2023, 02:55 PM   #2
joedoh
joedoh's Avatar
Re: Identify this door hinge!
hold it up to the cab, they are 4 unique hinges and it will only fit in one place.
because it has three complete holes in the door side, a spot for a spring, I am guessing its an upper hinge.
