Old 10-30-2023, 09:40 PM   #176
zicc1835
zicc1835's Avatar
Re: I am from the Desert
Originally Posted by loudchevy View Post
Looking good!
thank you....ill get back to it tomorrow
zicc1835 is offline   Reply With Quote
Old 11-13-2023, 09:21 PM   #177
zicc1835
zicc1835's Avatar
double pulley installed no more belt noise
Old 11-14-2023, 10:58 AM   #178
Shifty One
Shifty One's Avatar
Belts are about maxed-out on that adjuster bracket, eh?
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 11-14-2023, 10:55 PM   #179
zicc1835
zicc1835's Avatar
good eye Shifty ...the belts come in one inch increments as far as I can find out this way and that does not give me enough room going the other way with the alternator on a aftermarket bracket cause of the headers and original 327 heads have no provisions for bolting up a bracket to the head! originally the bracket bolted to the exhaust manifold I have clocked the alternator also ...long winded answer but I have run out of options ...there is just a tad left to pull the belts tighter ...no need to at this point ....thanks for looking as always open for advice
Old 11-15-2023, 12:24 PM   #180
Shifty One
Shifty One's Avatar
I had that same issue on my 55 Belair that had a nice set of fuelie heads....I ended up with two of those brackets, one on either side of the alternator ear.
What belt number are you currently running?
Old 11-15-2023, 08:50 PM   #181
zicc1835
zicc1835's Avatar
please send me a picture of your set up ....
I was using the Napa belt shown
and when I put the double pulley on I went to auto zone for two Duralast that were supposed to match ....
Old 11-16-2023, 01:39 PM   #182
Shifty One
Shifty One's Avatar
Much to my dismay, I haven't had the Belair since the late 80's...
Seems to me that you could use 15545's for a 1/2 shorter, or 15540 for a full inch. It's kind of old skool, but you can ask for a matched set, and hopefully you are dealing with an older counterman.
Old 11-16-2023, 09:07 PM   #183
zicc1835
zicc1835's Avatar
im going to ask for the 15545s matched set ( your right about older counter man I should say politically correct more mature) and give it a try if not they will take them back ...funny after I asked you for a picture I thought I wonder if he still has the car hey thanks for the responses what's great about this board is its people
Old 11-17-2023, 12:05 PM   #184
Shifty One
Shifty One's Avatar
Well, I am an old counterman (since 1983), so I get it.
I truly miss that ol' 55, wasn't the fastest, wasn't the best stopping or handling, didn't get great mileage, etc...but it was by far the best car I've ever owned.
Old 11-28-2023, 09:28 PM   #185
zicc1835
zicc1835's Avatar
I rescued this one in 2019 my neighbor bought it new in 55 put 78k on it then parked it in 74 in his garage for 46 years he is now 90 ...when I got it running ( took me 3 months oiled down them cylinders marvel mystery oil )first thing I did was took him for a ride.....so there you have the rest of the story OLD Counter Man
God Bless
Old 11-29-2023, 11:56 AM   #186
Shifty One
Shifty One's Avatar
Cheers!
Old 12-02-2023, 08:12 PM   #187
zicc1835
zicc1835's Avatar
finally .....so never a short story paint shop didn't make enough paint to complete the entire truck ( gave them a entire disassembled truck) so when they made the new batch didn't match come to find out PPG discontinued a tint that was being used in the formula( body shop offered to paint the entire truck again I said no because of my time invested in reassembly etc. they agreed and turned up the heat on PPG, PPG rep came out got it 97% close only good in horse shoes and POLITICS ):body shop kept the pressure on PPG and then they ask us to send them a correct color part(step from stepside) to their Lab in Pittsburg so they could create a formula and do a spray out .........we have a match ....its tuff with pictures and this color looks more blue gray than blue in some light and a lot blue in the sun light .....so after weeks of the back and forth ....we have a match so back to assembly ..first get the bed wood prepped ....stay tuned
Old 12-16-2023, 09:26 PM   #188
zicc1835
zicc1835's Avatar
no match back to shop for repaint
Old 12-16-2023, 09:29 PM   #189
zicc1835
zicc1835's Avatar
starting on bed wood fed up with paint fiasco trucks in shop being repainted in is entirety
Old 12-18-2023, 10:11 PM   #190
zicc1835
zicc1835's Avatar
satin................bottom side 24hr dry time another coat tomorrow
Old 12-19-2023, 01:02 AM   #191
chewychevy67
What finish coat are you using on the wood?
chewychevy67 is offline   Reply With Quote
Old 12-19-2023, 10:38 AM   #192
Shifty One
Shifty One's Avatar
Really brings out the heavy graining!
Old 12-19-2023, 10:52 AM   #193
jaros44sr
jaros44sr's Avatar
X2, looks great, don't forget to do the ends of boards, mine checked
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-19-2023, 07:54 PM   #194
zicc1835
zicc1835's Avatar
McCloskey Man O War Marine Spar Varnish Satin ...I was going to use an automotive clear but talked myself into this after reading a lot on the subject....I think im going to like it
Old 12-19-2023, 08:54 PM   #195
zicc1835
zicc1835's Avatar
[QUOTE=Shifty One;9268042]Really brings out
yes it has second coat made them look a little darker... now on to top side tomorrow
Old 12-19-2023, 08:56 PM   #196
zicc1835
zicc1835's Avatar
got the ends Jim
Old 12-20-2023, 09:24 PM   #197
zicc1835
zicc1835's Avatar
buffin...bedsides
Old 12-28-2023, 10:21 PM   #198
zicc1835
zicc1835's Avatar
shifting gears again.... truck out of paint finally now putting it back together for the finale
Old 12-29-2023, 10:52 AM   #199
Shifty One
Shifty One's Avatar
Coming along nicely!
Old 12-29-2023, 10:49 PM   #200
zicc1835
zicc1835's Avatar
TY .....a little more today
