Old 09-06-2023, 09:24 PM   #1126
chewychevy67
Re: 67 GMC super custom build
I didn't like the look of the overdrive words in the red color as it isn't a warning so I changed it to blue. It is just supposed to let you know that the overdrive unit is turned on. Won't be as hard on the eyes either in blue.
chewychevy67 is offline   Reply With Quote
Old 09-06-2023, 10:14 PM   #1127
IronCanine
I'm trying....
IronCanine's Avatar
Let the record show that almost 2.5 years, 200 posts, and probably 20 mods ago...you said you were done with mods.
Can't stop. Won't stop. And I love it!!!!
Looks awesome bud.
IronCanine is offline   Reply With Quote
Old 09-06-2023, 10:16 PM   #1128
Getter-Done
Getter-Done's Avatar
84 Chevy K-20
Old 09-06-2023, 10:43 PM   #1129
chewychevy67
While I wait for metal work I just can't sit idle. Its a disease i tell you. I better get it all out now cause nothing is coming apart (unless its for repair) for mods after it is assembled.
Old 09-06-2023, 10:55 PM   #1130
IronCanine
I'm trying....
IronCanine's Avatar
It's a disease that I enjoy looking at.
Old 10-20-2023, 11:12 PM   #1131
chewychevy67
Well progress has slowed. When I added the fog lights I used a 71 72 chevy bumper as the outer bumper bolts are further to the outside to clear the signal lights. So I got bumper brackets for this bumper and they almost fit without modification. I had a small spot I had to concave . I also had the shop weld in the recessed areas by the signal lights only 69 up gmc trucks had.
Old 12-08-2023, 09:38 PM   #1132
chewychevy67
I got my stuff back from the 3d printing place today. He made me a whole bunch of washers for the cab to fender seals and my fog light and ignition plaquard. Turned out pretty cool.
Old 12-10-2023, 06:53 PM   #1133
IronCanine
I'm trying....
IronCanine's Avatar
Super cool.
Old 12-16-2023, 12:15 AM   #1134
chewychevy67
Here's how it will look in the dash with the ignition and lettering lit up.
Old 12-16-2023, 08:34 PM   #1135
clay68c10
clay68c10's Avatar
That’s a cool feature. Very Cadillac-esque from that era.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-17-2023, 07:30 PM   #1136
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Very cool build man, I just read the entire thing.
The fact that you have so much in there as far as old parts go is pretty wild. Excited to see it as a finished truck.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 12-18-2023, 07:32 PM   #1137
chewychevy67
OK so I had some free time today and I've been thinking about this for a while.. the mirror bses had a hole in each one that is where the cables ran in on the car they were for but now they were unused. So I made little lenses for them and ran an led bulb that matched the color of the door lick ring and made a puddle light. It's kind of overkill buti had to fill these holes anyway. They will come on with the lock lights for 30 seconds when the door handles , in or out, move.
Old 12-18-2023, 09:30 PM   #1138
zicc1835
zicc1835's Avatar
awesome
zicc1835 is offline   Reply With Quote
Old 12-18-2023, 10:05 PM   #1139
Getter-Done
You are Holding Strong to the ( super custom build ) Title.
Great Job.
84 Chevy K-20
Old 12-19-2023, 11:57 AM   #1140
loudchevy
loudchevy's Avatar
Those on/off pieces are pretty neat. I'll be checking out the first 28 of your build soon.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 12-19-2023, 01:15 PM   #1141
Tip70
Tip70's Avatar
nice mod! that's a great idea, love it!
1970 C/10 LWB
build thread:
https://67-72chevytrucks.com/vboard/...d.php?t=847860
IG- Tip70
https://www.etsy.com/shop/Tip70Designs
Tip70 is offline   Reply With Quote
Old 12-19-2023, 01:43 PM   #1142
chewychevy67
Thanks guys . I was concerned that this might be to modern for this build but after humming and hawing I decided that as long as you can't blatenly see these in the mirror arms I'd do it. I can't make them work with the power locks like modern vehicles as they are vacuum operated but still should work nicely.
Old 12-19-2023, 03:55 PM   #1143
Tip70
Tip70's Avatar
I dont have a leg to stand on for too modern. I put M3 fender vents on my truck
1970 C/10 LWB
build thread:
IG- Tip70
Old 12-19-2023, 05:29 PM   #1144
chewychevy67
I have no problem with modern add ons for these trucks just trying to keep this build all 60s-70s appearing.
Old 12-19-2023, 06:09 PM   #1145
chewychevy67
I also got my fog light plaquard placed on my gauge bezel today.
Old 12-23-2023, 04:29 PM   #1146
chewychevy67
Well I put my seat in to make sure I could adjust my mirrors properly and I got side tracked. I worked these seat skirts from a 61-62 cadillac to fit around my buddy seats. They will hold the seat switch.
Old 12-23-2023, 08:05 PM   #1147
chewychevy67
Got the passenger side switch mounted now to. Just on the passenger side cadillacs has a body by fisher emblem. I obviously don't want that and I can't weld up the holes because the metal is stamped to look like leather so I'm going to have to make something to go there. Possibility are endless I suppose. Now to make mounting brackets for these.
Old 12-24-2023, 06:12 PM   #1148
chewychevy67
So I felt the mirrors may be a bit unstable when driving and I didn't want them to turn while they vibrate (because on these arms they all do) so I made a sleve on the arm that holds it more steady and here's a slot in the sleeve that lines up with a key like part on the chrome stem so it can't spin at all. Im not sure I'll be able to put the lights in the mirrors with these sleeves on the mirrors. I may have to get creative there. Not much room inside there with the cables running thru there now.
Old 12-27-2023, 01:15 PM   #1149
chewychevy67
Got these mirrors all mocked up so the mirrors adjust to areas that are proper. Not much mirror to view out of though as they are only 5 inches around. Went to a pub in Hudson Bay SK last night and they have this 68 outside the building. The pub is full of vintage views all around. Thought it was neat.
Old 12-30-2023, 02:20 PM   #1150
chewychevy67
So I assembledmy mirrors and my thermometer and when i lit the thermometer up it was fairly bright in the mirror chrome. Wasn't sure I liked that and dont want to get in trouble for front lighting by the cops so being that the arm will be painted black i figured I would paint the inside of the lens black as well to block the lighting. I think it turned out well.
