01-30-2024, 06:10 PM | #1 |
1970 Chevy k20 front drums
Anyone know if these rear drums part number BrakeBest Select Brake Drum - 9625DGS from a dodge 3/4 ton van fit the front of my 1970 Chevy k20 with Dana 44 open knuckles front axle? I know there was an older thread but I want to make sure they fit good and work before I possibly buy them. Thanks
01-30-2024, 09:22 PM | #2 |
I'm trying....
Re: 1970 Chevy k20 front drums
I am working toward this. That's what I have bought. If I beat you to it, I'll let you know.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
01-30-2024, 09:44 PM | #3 |
Ok thanks let me know if they work out for you then I’ll grab a set thanks.
01-30-2024, 09:58 PM | #4 |
01-31-2024, 08:33 AM | #5 |
At my NAPA store I was sent home with the wrong Dana60 shoes twice. I brought my shoes in and the better parts man grabbed a book that had drawings and dimensions or various shoes. For an 8-lug it's all about the diameter and surface width. Your drums should have "max dia" stamped on the back edge. Mine said 12.125", so 12" drums allowing for 1/8" machining
01-31-2024, 08:46 AM | #6 |
I am not sure about the open knuckle dana 44 with drums, but for my closed knuckle dana 44 on my 1967 K20, the Raybestos 2008R drums were a fit. I did have to drill out the lug holes and ream them as I have upgraded the studs to 9/16" but the drums themselves fit over the shoes perfectly. I believe that this drum was used on 1950's Chevy 3/4 tons, but I am not 100%.
https://www.rockauto.com/en/moreinfo...t=1744&jsn=727 Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
01-31-2024, 09:31 AM | #7 |
Ok thanks probably won’t work I’m thinking I’ll possibly try the oreillys part number drums and see if they work if not I’ll probably return them.
02-01-2024, 10:39 AM | #8 |
Born Psycho
a place called torque king 4x4 shows them (406)384-0270, they are quite pricey @ $283.98 each
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
06-11-2024, 09:29 PM | #9 |
I'm trying....
So far so good.
06-12-2024, 08:58 AM | #10 |
Is your front axle open or closed knuckle? Is your year a 1970 also? Year doesn’t matter Just trying to make sure it fits on mine thanks.
06-12-2024, 09:04 AM | #11 |
I'm trying....
70 K20. Open knuckle. June of 70 build date.
06-12-2024, 09:28 AM | #12 |
Ok thanks are studs long enough also? They look like it thanks
06-12-2024, 09:45 AM | #13 |
I'm trying....
Factory length studs are fine on the front. When you get to the rear it may be a different issue. I had to bump it up there to have enough. I don't have the Dorman numbers with me at work, but I could post later if needed. There are a few threads that document the rear stud problem.
06-12-2024, 09:48 AM | #14 |
Yeah I have different ones for the back I was just more worried/concerned about the front because they are basically impossible to find and since these work for the front I’m going to buy these.
06-12-2024, 01:11 PM | #15 |
I'm trying....
Raybestos 2009R works for the rear, but the Eaton is a different animal altogether. Many threads on here are very helpful with that. You can see my set up with the longer studs.
06-12-2024, 01:43 PM | #16 |
You mean Eaton rear end? I don’t know which rear end I have or even what rear end gears I have. lol
06-12-2024, 02:08 PM | #17 |
I'm trying....
Yes. The rear axle. You most likely have an Eaton H052 axle with either 4.56s or 4.10s.
06-12-2024, 02:26 PM | #18 |
Mine came factory with a 350 SBC and 2 barrel carb along with a 4 speed manual. That’s all I know about it.
06-12-2024, 05:16 PM | #19 |
Carpe manana
Any list of art that transcends generations will include the walking liberty half dollar, Bach's cello suites, Neuschwanstein castle, Rubens's The Descent From the Cross, and a Hall Brothers truck.
06-12-2024, 05:40 PM | #20 |
I'm trying....
"Excuse me, Mrs. DeadheadNM, is this your husband? We found him wandering around downtown mumbling something about a castle and a truck."
Pete you're crazy. But thanks I think.
