Old 02-01-2024, 11:05 AM   #501
LockDoc
The Older Generation
LockDoc's Avatar
Re: LockDoc's "Low Budget", "Low Maintenance" Project Thread
Here is a summary of the components I used for the build. I had 90% of the parts left over from other builds.
1972 GMC 3/4 ton frame
1971 cab and title
Stock gas tank with modified 2003 electric fuel pump in tank
1977 Chevy C30 front spindles, hubs/rotors, and calipers
2001 Chevy Van Hydroboost assembly
1967 Cab and Chassis HO72 rear axle assembly
1972 GMC 3/4 ton rear springs with rear spring hangers narrowed 2"
1967 complete front clip
2003 Chevy 8.1, 496ci engine and Allison 1000 automatic overdrive transmission
2003 8.1 complete original wire loom, modified by me
I really enjoyed building this truck and it is something I have wanted to do for many years.
I want to thank everyone for following along on this sometimes boring journey. I will post updates when I complete some of the leftover tasks like the rear wheel tubs, auxiliary small bed mounted gas tank, and any modifications I may decide to do.
LockDoc
Leon
Old 02-01-2024, 11:15 AM   #502
LockDoc
LockDoc's Avatar
Originally Posted by 72gmguy View Post
Nice job! I want one now. I like the way it sits the way it is. Looks like a great workhorse. Enjoy it!
Thanks Jeremy!
Leon
Old 02-01-2024, 01:24 PM   #503
pjmoreland
pjmoreland's Avatar
I think that stance looks excellent and just right for the heavy-duty truck that it is.
pjmoreland is offline   Reply With Quote
Old 02-01-2024, 01:54 PM   #504
Getter-Done
Getter-Done's Avatar
Perfect stance
84 Chevy K-20
Old 02-01-2024, 05:02 PM   #505
cj847
cj847's Avatar
I have enjoyed the entire journey. It's a great truck.
cj847 is offline   Reply With Quote
Old 02-01-2024, 06:26 PM   #506
LockDoc
LockDoc's Avatar
Originally Posted by Getter-Done View Post
Perfect stance
Thanks guys. I appreciate the feedback.....
Leon
Old 02-01-2024, 07:36 PM   #507
Great job on the truck!
Old 02-01-2024, 09:19 PM   #508
Sheepdip
Sheepdip's Avatar
1/2"or 1"......It's still a mighty fine job and a looker!
Sheepdip is offline   Reply With Quote
Old 02-01-2024, 09:40 PM   #509
67C10Step
67C10Step's Avatar
Great build and nice truck! I think the stance fits the truck just fine.
You will get a lot of waves and thumbs up when that rig rolls down the highway.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is offline   Reply With Quote
Old 02-02-2024, 09:21 AM   #510
D.B
Perfect stance, I wouldn't change it. It looks like it's ready to get some work done.
D.B is offline   Reply With Quote
Old 02-02-2024, 12:36 PM   #511
LockDoc
LockDoc's Avatar
Thanks for the feedback and kind words everyone. Hopefully it will get a lot of work done next Spring....
Leon
Old 02-03-2024, 06:06 PM   #512
fatbass
fatbass's Avatar
I predict $140K at Barrett-Jackson.
'71 C/20 350/T350.
fatbass is offline   Reply With Quote
Old 02-04-2024, 02:37 PM   #513
LockDoc
LockDoc's Avatar
I'd say you are very optimistic, but I like the way you think....
Thanks.
Leon
Old 02-06-2024, 05:27 PM   #514
LockDoc
LockDoc's Avatar
My friend Ron came down yesterday to go out to lunch with me and he stayed long enough to help me get started on the rear wheel tubs. I had the pieces cut so he helped me get the filler pieces tacked onto the inside sections.
First picture shows the inside section and the filler piece. Second shows the pieces tacked together (I finished welding it up after he left) and the third shows the passengers side finished up and set in place. The filler piece is slid underneath the outside section, that way I can just mark along the outside edge of the filler for my width, pull it back out and cut it off.
Leon
Old 02-07-2024, 09:16 AM   #515
raggedjim
raggedjim's Avatar
You guys are doing great work! Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 02-07-2024, 09:42 AM   #516
LockDoc
LockDoc's Avatar
Thanks Roger. I'm hoping to get the other side finished up today.
Leon
Old 02-07-2024, 11:05 PM   #517
LockDoc
LockDoc's Avatar
I pretty much finished up the drivers side and set it in place I will have to take a picture tomorrow. I had to unload an old safe that a friend of mine gave me. It probably weighs 600 or 700 pounds.
Leon
Old 02-08-2024, 11:15 AM   #518
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work Leon! I'm guessing this is one of the lowest budget trucks you've built? Just think if you started acquiring the parts for it now. You'd probably have 30% more into it minimum I bet.
Ryan
1969 Chevy milk truck
Old 02-08-2024, 11:36 AM   #519
LockDoc
LockDoc's Avatar
Yes it is Ryan.
I don't think I would have tackled the project if I was starting to collect parts for it today. I haven't figured up how much I have in it but I'm guessing it's around 5 or 6 thousand.
Leon
Old 02-08-2024, 02:34 PM   #520
LockDoc
LockDoc's Avatar
A picture of the driver side tub. I need to weld a piece of metal on the back edge of the filler. I will do that when I take it back out to finish it up.
Leon
Old 02-19-2024, 01:08 PM   #521
LockDoc
LockDoc's Avatar
I made the under floor brackets for the seat belt retractor bolts yesterday. Since I used the '91 seat belts I had to drill new mounting holes in the cab floor for the retractors.
I use aluminum flashing material to make my patterns with. It cuts and bends easily and holds it's shape while you are working with it, unlike cardboard.
I sold my sheet metal brake but the guy only lives a couple of miles from me and he said I could come over and use it any time I wanted to. I took them over yesterday afternoon and bent them up. Cleaned them up, drilled the holes, and put a couple of coats of paint on them last night, and installed them this morning. That's another job off the punch list.... .
Leon
Old 02-19-2024, 05:13 PM   #522
Dieselwrencher
Nice work and good 8dea on the aluminum pattern.
Ryan
Old 02-19-2024, 10:50 PM   #523
Getter-Done
Nice work as Usually and Very smart gaining shop space.
Then going to the Neighbors to use the bender.
All jokes aside I will Remember the Flashing trick.
84 Chevy K-20
Old 02-19-2024, 11:54 PM   #524
LockDoc
LockDoc's Avatar
Nice work and good idea on the aluminum pattern.
Thanks Ryan. I have used that stuff for a long time
It was a 4 ft long bender and the stand was made out of the back of a big truck frame, so I gained quite a bit of room in the shop and made a few bucks in the process...
Leon
Old 02-20-2024, 12:14 AM   #525
3757chevy
3757chevy's Avatar
That is very nice Leon . I've been sitting back watching and am impressed with the amount of money you saved by using what you have. I need to learn how to use up some of my extra parts I been sitting on before they're not worth using.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
