Old 02-01-2024, 03:23 PM   #176
mr48chev
mr48chev's Avatar
Re: Eliminate draft tube options
Originally Posted by TX3100Guy View Post
I've noticed in working on this engine that many of the gasket surfaces (not the oil pan) that the previous owner used a blue silicon type gasket sealer. I've not seen anything like this before and wonder if that is something that I should look into. Right now, I use either the "Right Stuff" and/ore Permatex RTV type sealer. But the blue silicon material seems to seal better and frankly has been easier to remove.
Engine sealers come down to the concept of "this is what works best for me when I seal this area". Blue silicone has been around for ever and I use it along with the black and there are a ton of other great sealers out there.
The main thing with silicone is do not use too much. Years ago a buddy of mine who worked in a Honda Dealership said that the instructor at a school he went to told the guys to hold their finger out and squirted a dab on each guys finger and told them that dab was all the silicone they needed to seal the whole engine. I've pulled six inch long silicone worms out of oil passages of blown up engines before.
On the main cap thing, I would have the best idea is search out a good front main cap and line bore the block with it in place. Extra $$ but peace of mind knowing it was done right.
If you were closer to Waco I'd just say put the tools you need to pull a pan and pull the main cap in a 5 gallon bucket and head to M Lipsizt in East Waco and hunt through the scrap engine pile that after looking at the map I don't see where it was years ago. Scrap cars don't sit around in that place though, I can remember 50 years ago following a couple of charactors who would run an add in Penny press that they would haul scrap cars away for a fee of 25 each as long as they could be flat towed and they towed the cars across the scale at Lipsitz and over to the side where they would pull the tires off and throw them in the back of their tow rig that wasn't much better and go back across the scales and collect their money. Before I could get weighed, unloaded, weighed and out the door that car was often already in the Texas Shredder. Funny thing is that those two were often doing that three or four times a day when wages were about 3.50 and hour around Waco.
My ongoing truck projects:
Old 02-02-2024, 06:12 PM   #177
TX3100Guy
TX3100Guy's Avatar
Well, I never said that I wasn't going to take the head off, but I waiting for my new best buddy (the engine builder) to look at the engine and take care of that himself.
In a fit of energy today (don't worry it won't last) I unbolted the head, kept the bolts in a numbered box that I punched holes in to held the bolts in the order they go back into the head/block. I also removed the head gasket and did a preliminary clean up job on the block, but haven't looked at the head yet.
Just an update.......
Any suggestion on how to clean the block and the head?
1953 Chevy 3100 - 5 window 1/2 ton pickup
My 1953 Chevy Work-In-Process Photo Gallery
"I don't have a carbon footprint, I drive everywhere."
TX3100Guy is offline   Reply With Quote
Old 02-05-2024, 10:08 AM   #178
1project2many
The bristle disc wheels mentioned previously are my first choice for this application.
1project2many is offline   Reply With Quote
Old 02-05-2024, 10:40 AM   #179
dsraven
when buffing the piston tops make sure to have the pistons at the top of their stroke so the cylinder walls don't take a beating.
eventually you will likely need/want to take the pistons out for machining work to be completed. the pistons could be cleaned up then. I usually put them in a tray of aluminum compatible solvent to soak and soften up all the carbon etc. for the gasket surfaces i use a long board with sandpaper. for the combustion chambers I use a stiff knotted wire wheel on a die grinder with the valves in place at first, then, after the valves are out, the same brush works well down inside the ports and bowls where the vales seat but be very careful not to go too deep or the steel body of the brush touches the valve seats and thats not a good thing. when the head is completely dissassembled you could use oven cleaner on it and then wash it all with hot water. then use compressed air to dry and when it is drying look for any traces of spots where the water doesn't dry uniformly as those spots may be holding water in a crack. the old heads had a habit of cracking in the combustion chambers. ensure to keep all the valves in order of where they came from if you take the head apart.
Old 02-05-2024, 10:53 AM   #180
leegreen
Are you going to tear it the rest of the way down? Pull a bearing cap or two to inspect? What to the bores look like? Valve seats, stems and guides?
The reason I ask, that block surface, piston tops look like more than break in hours to me. But maybe that is what you get from many years sitting.
And it may not be relevant if everything is in good shape.
The engine is clean enough inside to assume it has at least been apart in recent memory.
If I was preparing that block to put a new head gasket on without going any further:
plug oil passages with wound up rag
protect lifter alley from falling debris
stuff rags into each bore
clean block surface with scotchbrite pads by hand working around, away from holes holes
pull rags with a twisting wiping motion.
get everything as clean as possible & put it back together
degrease and paint once it is buttoned up
leegreen is offline   Reply With Quote
Old 02-05-2024, 05:07 PM   #181
dsraven
if taking the head apart for cleaning its a great time to replace the valve seals, check the valve springs and their retainers and the keeper grooves in the valve stems, valve stems for wear limits, stem to guide clearances, check the gaskets surfaces for warpage, etc. clean the head up well, check for any cracks, lube the valve stems with some assembly lube or molyslip grease (my personal choice for valves) and slip it all back together. then clean and check the rockers and the rest of the valve train, lube and assemble as much as you can, in modules, so when assembly time comes those parts are easy to unbag and you know they are good to go.
Old 02-05-2024, 06:08 PM   #182
TX3100Guy
TX3100Guy's Avatar
These are all tasks that I'm hoping to assist my engine builder buddy with. He's done this as a business for 60 years and now in semi-retirement (he's in his 80's) he's interested in passing "lessons" along and I'm a willing student.
I had already mentioned to him that when he was working on the end cap/line bore that I'd like to observe/assist/learn. He seemed to think that was a good idea.
Old 02-05-2024, 06:56 PM   #183
TX3100Guy
TX3100Guy's Avatar
Are the crankshaft bearing caps the same on the 235 Chevy as the 261?
I may have located an entire set of 235 end caps.
Old 02-05-2024, 07:27 PM   #184
leegreen
maybe. Sealed power 960M main bearings show as fitting both 235 and 261
Old 02-05-2024, 07:36 PM   #185
TX3100Guy
TX3100Guy's Avatar
Well, I may have wasted $40 if they aren't the same, however that isn't the most amount of money that I've wasted on this truck so far.....LOL
I found a used set on eBay and purchased them just in case they were a correct fit. I guess when they show up I'll have a better idea if the front end cap measures the same.
Name:  Screenshot 2024-02-05 at 4.55.04 PM.jpg
Old 02-05-2024, 07:51 PM   #186
leegreen
If it fits.....
I'd be tempted to plastigauge it to check how uniform the bearing clearance is with the new cap and then consider if it could go back together without line boring.
Old 02-05-2024, 08:29 PM   #187
dsraven
as a guy who worked in an engine shop waaay back outta high school, i would say that there isn't a snowball's chance in......it's gonna be a direct fit. but, you could install it and torque it up with no crank in there, just the bare bore, and then use an inside micrometer on it to see if it is round or not and it it is round through the whole fore to aft length. otherwise the engine guy you know will surely be able to fix you up for cheaper because he will already have a good front bearing cap to work with.
too late now anyway since you already hit "pay the guy" on ebay, lol.
you can always make a cool lamp out of the stuff it it doesn't fit. lol.
Old 02-05-2024, 08:30 PM   #188
TX3100Guy
TX3100Guy's Avatar
If it fits.....
It could happen.......
Old 02-05-2024, 08:32 PM   #189
TX3100Guy
TX3100Guy's Avatar
Lamp???? With all the stuff I've bought and not used I could make a huge lawn ornament and have the HOA throw me out of the neighborhood.
I have a call into my engine buddy to see what he thinks. He's the one who told me that this route might be my best shot time and money wise.
Old 02-08-2024, 11:56 PM   #190
TX3100Guy
TX3100Guy's Avatar
Look what $40 on eBay got me.
Old 02-11-2024, 11:54 PM   #191
TX3100Guy
TX3100Guy's Avatar
My engine builder buddy suggested I take the new bearing cap and the old bearing shell and smear a fingers worth of clean engine oil on the shell and the crank. Then mount the cap and in increments of 10 ft/lbs test how easy the crank turns by hand. I started by torquing the bolts to 30 ft/lbs and the crank turned just as easily as it had without the bearing cap. I continued in increments of 10 ft/lbs up to 90 ft/lbs and the crank was just s easily turned as it was without the bearing cap. I didn't want to press my luck at 100 ft/lbs, but will do that tomorrow. My engine buddy called me the luckiest guy in Dallas. More to come, but in the end the crank will still come out.
Old 02-12-2024, 12:53 AM   #192
dsraven
if you wanna see how tight the tolerances are all the way around the crank, clean the bearings and the crank with a clean lint free cloth so no oil to speak of is on the bearings or the crank journal, then put some plastigage the full length of the bearing cap 1/2 of the bearing, then put the cap back on and torque it up being careful not to turn the crank while doing this. then remove the bearing cap and see what you have for clearance on the plastigage. if you don't know what plastigage is, it is a plastic thread that comes in different colors for different clearances, you likely need the green stuff that will show up to a couple of thousands clearance. when you put that on the bearing and then torque it up it will get squeezed and flatten out some depending on the clearance there is left between the two parts. then when you take the thing apart and look you will see the thread has flattened out. the little paper package that the plastigage come in has markings on it to compare the width of the flattened out plastic thread. really flat means not nuch clearance. of course the opposite for a thread that didn't get flattened out much. when you put the thread around the whole half circle of the bearing cap bearing shell and torque it down when you look at the plastigage after you can see if there are parts that show a more flattened out thread that other parts are showing. this can help you see if the bearing cap you bought is a close match to being bored on the same center line as your old cap. it's one in a million but there is a chance it is close enough to run it that way without doing any machine work. if thats the case then you need to buy your engine buddy, LG, me and yourself a lottery ticket. haha.
Old 02-12-2024, 01:11 AM   #193
leegreen
could also plastigauge the clearance with old and new caps to see how they compare
Old 02-12-2024, 01:15 AM   #194
dsraven
yeah, good point LG.
you think of everything. inside and outside the box.
Old 02-12-2024, 12:56 PM   #195
TX3100Guy
TX3100Guy's Avatar
Ok, so today I inserted a piece of Green plastigauge on the newly acquired bearing cap (with the original bearing shell) and torqued the two bolts down to 100 ft/lbs and here is the result.
When I did the same thing on the old bearing cap (the cracked one) the result was even less thick than with the new bearing cap. It was clearly compressed by not by as much as the new bearing cap.
Did I hit the bearing cap lottery?
Old 02-12-2024, 01:01 PM   #196
dsraven
that actually looks pretty good. maybe have your engine buddy look at it and see what he thinks, or send him the pics.
buy a ticket, lol.
Old 02-12-2024, 01:02 PM   #197
dsraven
measure at it's fattest point and see what you get but it looks pretty good.
Old 02-12-2024, 01:02 PM   #198
TX3100Guy
TX3100Guy's Avatar
buy a ticket, lol.
I posted here first and then sent him the same photos.
Old 02-12-2024, 01:04 PM   #199
TX3100Guy
TX3100Guy's Avatar
Where I have the paper plastigauge measuring guide (.002) was the widest part of the thread.
Old 02-12-2024, 01:05 PM   #200
dsraven
hopefully thats not a nick on the journal there. gotta be careful moving things around etc. I usually put an oil moistened rag around my journals and use tape to keep them on there until ready to do something with the crank. you are already working with it but just a thought for when you store it until the engine guy has a chance for a peek or whatever your plan is.
