Old 02-20-2024, 08:27 AM   #726
6DoF
6DoF's Avatar
Re: Project: Tow-Rat (Lil' Blue)
Originally Posted by dsraven View Post
is there a blackbackground mode on the screen maybe? that might help at night.
oh yeah, it's fully customizable to anything you'd want.
6DoF is online now   Reply With Quote
Old 02-20-2024, 09:51 AM   #727
6DoF
6DoF's Avatar
got the 'Aire Jax' switches hooked up last night and they are amazing. super easy proportional control for slower speed and fast as hell if you want. i dropped the front once hard enough i was worried about breaking something, but i can also easily take however long i want for it to drop. the new switch location is also money. highly recommend.
with the switches and no psi regulator, i was able to get 140psi in the front bags, the max on my tank regulator. but i got very little extra lift. i'm starting to get worried about making the 8-8.5" height i wanted.
after that i started hooking up the relay and fuse block to get the onboard pumps running. got them to run, now i just need to wire them thru the psi switch.
Old 02-20-2024, 09:57 AM   #728
dsraven
get'er done. let us know how it goes.
Old 02-20-2024, 10:01 AM   #729
dsraven
nice tidy work. good job you're doing. better than sone proffessional jobs I've seen.
Old 02-20-2024, 10:08 AM   #730
dsraven
Ii remember back in the day with the square body trucks they used some air bags inside the coil springs. can't remember if that was a factory thing or an aftermarket thing. I always wondered how much they helped but never actually found out since i was the repair guy not the truck owner or driver. mostly I seen them on 1 ton trucks but the max engine size/weight would have been a big block or a 6.2 diesel. hopefully you can make your's work without having to rework the control arm.
Old 02-20-2024, 03:29 PM   #731
6DoF
6DoF's Avatar
bag inside the coil spring or in place of the coil spring?
this is the second set of LCA's i've built to take a bag in place of the spring. these use an 8" dia bag, the first set was for a 9" dia bag. i could also go back and make another set for the higher capacity bag again.
Old 02-21-2024, 09:51 AM   #732
dsraven
bag inside the coil. standard factory ride height. i think maybe the ride height was taller on the air bag assisted trucks but that was a long time ago.
Old 02-21-2024, 10:25 AM   #733
6DoF
6DoF's Avatar
oh yeah, compensate for added weight or try a small lift by making things stiffer ... they still sell those, even seen ppl use footballs
Old 02-22-2024, 01:27 AM   #734
dsraven
yup, stiffer comes to mind for sure
Old 02-22-2024, 08:07 AM   #735
6DoF
6DoF's Avatar
got it! i was determined to get you that full height picture!
so i finished wiring up the dual OBA compressors with the tank psi switch and got actual good PSI to the bags. she went right up to height, and a weight off my shoulders.
8.5" front, 9" rear
Old 02-22-2024, 10:00 AM   #736
dsraven
fewf, load off.
looks good for height there.
thanks for the pics.
Old 02-22-2024, 01:46 PM   #737
daveshilling
daveshilling's Avatar
One of my favorite duallys! (and I'm not a dually guy)
daveshilling is offline   Reply With Quote
Old 02-22-2024, 04:22 PM   #738
dsraven
are you puting a bumper on the front?
Old 02-23-2024, 10:39 AM   #739
6DoF
6DoF's Avatar
thank you!
hopefully you still like it after i do the bed. it'll be a little different.
sure thing, i have the factory matching patina front bumper for it. will get placed a little tighter to the body, and a little lower to the ground.
i then have a 70's step bumper for the back
Old 02-23-2024, 09:48 PM   #740
dsraven
the task force trucks with no front bumper kinda look like they are launching when they are sitting still, haha.
Old 02-28-2024, 03:43 PM   #741
6DoF
6DoF's Avatar
so it begins ...
i only have a few things to hook up, but there are so many damn wires!!
Old 02-28-2024, 05:29 PM   #742
dsraven
looks pretty neat to me. keep going one circuit at a time and soon you won't have any circuits left.
Old 02-29-2024, 06:57 AM   #743
regan wilson
regan wilson's Avatar
You're on the downhill side. It looks good at that ride height.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 02-29-2024, 09:11 AM   #744
6DoF
6DoF's Avatar
thanks, and i even get to weed out n not use quite a few of these wire too!
i have always HATED the "Christmas tree press-in clip" style zip ties on factory harnesses. just a pain, never reusable, etc. well while working on the wife's vette i finally bought a bag of 100 of em and i'm starting to really like them. now that i can just cut em off n replace they are super handy. 1/4" hole, super secure, done.
also, this cheap split seam loom from amazon is way better than that old plastic corrugation stuff i've used in the past.
Old 02-29-2024, 09:15 AM   #745
6DoF
6DoF's Avatar
thanks! cross your fingers for me it functions n rides well too, haha.
i've searched and searched, but cant' find a good cheap set of factory late-gen C30 knuckles. i'd really like to have a set on the shelf for back-up. i made some 3" bag spacers for the back, and by swapping out these drop knuckles i could gain back a real functional height while still getting low enough to be pretty sick.
what drives me nutz is i had a set on that chassis i bought and they got scrapped. immediate regret.
Old 02-29-2024, 09:46 AM   #746
dsraven
there is also a tool that helps insert the wire into the splkit loom.
https://www.cabletiesandmore.ca/wire-loom-tools
Old 02-29-2024, 10:19 AM   #747
Rickysnickers
Wait!! You built a chassis from scratch and you are griping about pulling a few wires through your truck??? LOL. Is it just me???
Old 02-29-2024, 11:15 AM   #748
6DoF
6DoF's Avatar
generally a fabricator is allergic to electricity ya know!
satisfying at completion, just not my favorite work. partially cuz ideal functionality of routing is not the same as a nice looking routing for the most part ... i end up with an internal struggle of hidden and serviceability.
Old 02-29-2024, 11:39 AM   #749
6DoF
6DoF's Avatar
oo! good call on a tool for that. i used a box wrench last night and was pretty decent, but could be way better.
found these online and printing a few different sizes of them now.
https://www.printables.com/model/662...esser-werkzeug
Old 03-01-2024, 07:15 AM   #750
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Have you looked at a racepak for your gauges and data logging? For the cost of the holley stuff I think the racepak might be a better option price wise.
Your air valves look like the little Larry ones I have on my truck. I'm guessing these guys bought Larry out. Unless they changed design or upgraded something inside them, plan to add some lube to your air system maybe 1 or 2x a year. I only have the 2 valve and not the 4 but they will stick some times and that sucks. Hopefully yours won't. I've had mine on the truck for a long time so maybe mine is just an old design.
Ryan
1969 Chevy milk truck
