sm465 top cover is stuck on truck will not come off
Here is my issue. I knew it had to be half way in reverse to put the top cover on and thought I had it. But, it will not shift into reverse. It is out of a 1967 C10. It will not go into reverse no matter what and now the cover only comes up half inch. Any ideas why I can not get the cover off and how to get it to come off? I searched the net and on here and all I can see is how to install it basically. No info on anything else.
Active Member
![]() Join Date: Sep 2023
Re: sm465 top cover is stuck on truck will not come off
you missed the slot in the reverse gear,,,,,,,,,,, it needs to be in reverse to get it off
Old dogs and children and watermelon wine ![]() |
I know, problem is, it will not go half way in reverse like it should. I watched the damn fork line up and go into gear half way, but apparently it slipped as the cover went down the last 1". I know what has to happen. But, it's not happening, that's why I am asking how to get it off when apparently it somehow slipped off the gear in the last inch. I read and watched every video to tell me how it goes on and comes off, but no one can tell me how to get it off if it somehow is not on the gear.
#4 | |
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
Like said above but add some side to side action. When it's misaligned the fork hits rhe case. It almost rolls out to the side then pops up. Once you have done it a few times it becomes second nature.
