Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 04-02-2024, 11:48 PM   #1
Yamariv
Yamariv's Avatar
What Brand of Stud Welder to buy?
Hey Gents,
I'm getting into some minor body dent repairs on the truck and am looking to buy a Stud Welder. Amazon sells Vevor brand but it seems to have not so good reviews.
Is there another company that makes these that aren't going to break the bank but are of decent quality that you'd recommend?
Cheers!
1971 Chev C10 - 250ci L6 w/3 speed on the floor
Upgrades: Power Steering
3 Core Radiator
7 Hole Gauge Cluster
Power Brakes (Incoming!!..)
1971 350 (Incoming!!..)
Yamariv is offline   Reply With Quote
Old 04-03-2024, 01:24 AM   #2
D-n-Tyke
Re: What Brand of Stud Welder to buy?
Interested in answers to this one too.
D-n-Tyke is offline   Reply With Quote
Old 04-03-2024, 08:28 AM   #3
BROWN 70
BROWN 70's Avatar
Smile Re: What Brand of Stud Welder to buy?
hi, my girl friend bought me a harbor freight stud gun to pull out a dent in my oil pan that was touching the crank. worked well and got the dent out without putting a hole in it. BROWN 70
BROWN 70 is offline   Reply With Quote
Old 04-03-2024, 04:25 PM   #4
LS short box
I bought a Harbor Freight stud puller gun and puller. Worked well for a hobby project like my 68 C10.
But if I was working in a production shop I would buy a slide hammer with collet like Snap On has. The Snap On slide hammer has a collet the you tighten more or less like a hand drill.
Old 04-03-2024, 06:00 PM   #5
sfont66
sfont66's Avatar
I agree 100%. I too have the Harbor Freight stud welder.
It works fine for how cheap it is. Definitely hobby Grade though.
The slide hammer leaves a lot to be desired, the way it grips the stud is not great, kind of fiddly . Years ago in 1987 when I was starting to buy tools I bought a very nice stud gun , professional grade, a Bluepoint if memory serves. It was expensive at almost $600 then. It came in a nice case and had attachments like a shrinking tip, but the best thing was the slide hammer was like LS short box described tightening similar to a cordless drill chuck , much better and faster for production use. Wish I still had it, never sell your tools or guns if you can help it…..
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 04-04-2024, 01:34 AM   #6
Fbks_Cruiser
Fbks_Cruiser's Avatar
I also have a Harbor freight stud gun but didn’t like the slide hammer. I welded vise grips to another cheap one I have and also made a stud lever which allows me to apply pressure to the dent while hammering down the high perimeter. Something you can’t easily do with a slide hammer.
1972 GMC K2500 Super Custom
Matt
Fbks_Cruiser is offline   Reply With Quote
Old 04-04-2024, 06:11 AM   #7
Getter-Done
Getter-Done's Avatar
Is this the same one from Amazon?
You also get a Discount if you order direct from Vevor.
Link: https://www.vevor.com/stud-welder-c_...p_010633845352
84 Chevy K-20
Old 04-04-2024, 08:58 AM   #8
raggedjim
raggedjim's Avatar
I've got an H&S Autoshot I picked up at the pawn shop. It is great.
I also have the Harbor freight one but I've never used it. Some one told me the Harbor Freight ones work better if you buy studs that are better grade.
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 04-04-2024, 12:37 PM   #9
JJH Jimmy
JJH Jimmy's Avatar
I'm cheap. I buy the studs from Harbor freight and tack them on with my tig welder and pull them with a slide hammer that i got from Eastwood.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 04-04-2024, 09:33 PM   #10
Fbks_Cruiser
The vevor has several accessories the HF doesn’t. Like shrinking tips and wavy crease pullers. If I were doing it again, as a hobbyist, I’d prolly go with the vevor.
Matt
Old 04-04-2024, 09:50 PM   #11
Yamariv
Yamariv's Avatar
Awesome guys, looks like I'll have to give the Vevor a try to start!
3 Core Radiator
Old 04-04-2024, 10:49 PM   #12
Getter-Done
Just a Reminder .
If you register you get a Discount .
I have bought several things from them and all was good.
A Planishing hammer was one of many things.
84 Chevy K-20
Old 04-04-2024, 10:59 PM   #13
Yamariv
Yamariv's Avatar
Originally Posted by Getter-Done View Post
Just a Reminder .
Register with Vevor? Was gonna buy it off of Amazon
3 Core Radiator
Old 04-04-2024, 11:08 PM   #14
Getter-Done
Go direct to Vevor site.
If you register you get 5% or more discount.
84 Chevy K-20
Old 04-04-2024, 11:14 PM   #15
Getter-Done
Just added this in case it is a better deal.
I always Compare when shopping.
Hope this Helps.
84 Chevy K-20
Old 04-04-2024, 11:15 PM   #16
Yamariv
Yamariv's Avatar
Hope this Helps.
Appreciate the tip, but I'm in Canada and I'm sure ordering from Vevor direct will be crazy shipping costs on top
3 Core Radiator
Old 04-04-2024, 11:26 PM   #17
Getter-Done
I just done a Search and Vevor says from California to Canada the shipping is free.
It might be different when you check on your computer.
I am not a Sponsor just trying to Help a Brother out.
84 Chevy K-20
