05-02-2024, 01:55 PM | #1 |
CPP slip driveshaft and billet carrier bearing
I just bought a CPP slip driveshaft and billet carrier bearing, had it balanced. But feels some vibration.
Has anyone had similar issues with either? I bought a oem style carrier, and going to install to see if the bearing or the shaft is making the vibration |
05-03-2024, 01:23 PM | #2 |
Re: CPP slip driveshaft and billet carrier bearing
I used the billet style carrier bearing in my anniversary truck with stock drive shaft and had no problems.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
05-04-2024, 01:40 PM | #3 |
I installed the billet carrier and the slip rear drive shaft in my Burban (Not from CPP) It helped reduce vibrations. I ended up having to rebuild the rear end to eliminate more vibrations and then finally found the the pinon yoke was damaged before I got to the bottom of my vibrations.
You may have additional items contributing to your vibrations outside of the driveline. Is your truck lowered? That can add additional problems with U-joint angles. I was able to further reduce vibration by getting my U-joint angles properly set up. My Burban is lowered.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 05-05-2024 at 09:33 AM. Reason: Additional information on the U-joint angles. |
05-05-2024, 11:54 AM | #4 |
I think you hit the nail on the head.
Its lowered 4" in the rear. And this winter, I installed a shock relocation kit. I'm thinking the pinon angle is low, and the angle at the carrier bearing is steep. I'm going to tweak some things to see if it helps. |
05-06-2024, 12:14 AM | #5 |
I had to read this a couple of times to make sure I was reading it right but the gist of things is that all three U joints need to be on the same plane.
That matches the one piece driveshaft concept of output shaft and yoke on the transmission and the pinion shaft being on the same plane. Time to dig out the angle finder and schooch under it with it sitting flat on the floor.
05-06-2024, 08:16 AM | #6 |
Spicer has some good videos and this nice calculator for drive line angles.
https://spicerparts.com/calculators/...gle-calculator Here are some notes from when I was checking mine. Starts on post 348. there is a little bit more on the previous page about the installation. https://67-72chevytrucks.com/vboard/...698377&page=14
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
