Old 05-21-2024, 09:55 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
PS not working unless RPM is up
Power Steering not working at idle. Up the RPM and it works. Any Ideas
HELP
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 05-22-2024, 12:26 AM   #2
lil hoodlum
lil hoodlum's Avatar
Re: PS not working unless RPM is up
Shooting from the hip with a WAG, Wild @ss Guess, but my thought are an air pocket.
Curious to find out what the more knowledgable people on the board say.
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is online now   Reply With Quote
Old 05-22-2024, 07:31 AM   #3
That would be my guess also, but not sure really unless it is a pump issue
Old 05-22-2024, 12:19 PM   #4
j_cst_10
j_cst_10's Avatar
I've had an issue with the stock pumps turning larger tires - not sure if that is the case or not with you.
I drained and put in some expensive synthetic fluid and it worked.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual
1972 Cheyenne Super Short Bed 557 Med Olive DK olive
1970 K5 Blazer Dark Gold
1966 Coronet 440 35k mile survivor
1991 Suburban 2500 454/4L80E 2wd
1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9"
j_cst_10 is offline   Reply With Quote
Old 05-22-2024, 01:15 PM   #5
A1971Blazer
A1971Blazer's Avatar
you may have to monkey with the pressure relief spring
google it....you can increase the pressure
pump may be worn as well
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 05-22-2024, 03:33 PM   #6
68Gold/white
Lucas makes some PS stop leak stuff. I think it has other good things it does.
I'd buy some of that first. It won't take very much. Try 2-3 ounces, see what happens.
68Gold/white is offline   Reply With Quote
Old 05-22-2024, 05:37 PM   #7
purple gas
Was it working before and this just happened out of the blue?
Have you been doing anything with the system, pump, hoses, connections, steering box?
Is there any evidence of leaking fluid?
Were you driving and have any type of incident?
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 05-22-2024, 09:20 PM   #8
1970 CST Short Wide
Senior Moment
No leaks
No work done on steering at all
Started out of the Blue
Only thing we can find is the belt could stand to be a little tighter
This is my Sons Truck, I’m going over tomorrow and check it out
Pittsburg Ca
94565
Old 05-22-2024, 09:46 PM   #9
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: PS not working unless RPM is up
Steve, my guess would be a bad p-s pump if it happened out of the blue.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 05-22-2024, 10:38 PM   #10
1970 CST Short Wide
Senior Moment
Ya that’s what I’m afraid of. That’s my Sons luck lately. If it wasn’t for Bad Luck he wouldn’t have Any
Pittsburg Ca
94565
