Old 03-11-2010, 10:33 AM   #226
67cheby
67cheby
67cheby's Avatar
Re: 67cheby DM 3.2 install, W/PB 4link, PB hood hinges
More progress, got my fuel cell, made a frame for it to set in. got a brace in place in front of the fuel cell, made frame gussets and got them welded in in front of the notch, mocked up battery mount... tonight working on the compressor mounts , got the upper bag mounts in the works, i think everyone is going to like them got a pretty cool idea for the upper mounts
67cheby is offline   Reply With Quote
Old 03-11-2010, 10:37 AM   #227
67cheby
67cheby
67cheby's Avatar
more
Old 03-11-2010, 10:43 AM   #228
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-11-2010, 11:09 AM   #229
VA72C10
VA72C10
VA72C10's Avatar
Re: Raising the bed floor 67cheby
Looks good...see you got the watts link welded in with it all set up!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-11-2010, 11:09 AM   #230
98L150
///Relaxed Atmosphere
98L150's Avatar
nice progress, looking good
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 03-11-2010, 11:19 AM   #231
67cheby
67cheby
67cheby's Avatar
thanks ...getting there slowly ,one foot ahead of the other
Old 03-11-2010, 11:44 AM   #232
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
That's sick, man. Love that Watt's link.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 03-11-2010, 01:02 PM   #233
watahyahknow
watahyahknow's Avatar
only way to get ahead without loosing it
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-11-2010, 02:02 PM   #234
64shortc10
64shortc10's Avatar
Very nice! Is that the KP components watts link? Did u have to modify it to make it level? The pics look like u cut down the bars? I plan on doing the PB trailing arm set up with the KP watts so just curious what u had to do to make it work? Thanks.
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 03-11-2010, 02:07 PM   #235
67cheby
67cheby
67cheby's Avatar
i did cut down the bars(i think i shortened them about an inch), i might replace them altogether, i am contacting kp today to check on them sending me another set of bars, it was a pain trying to get the heim joints in and out , that is my only complaint with the watt link
Old 03-11-2010, 02:22 PM   #236
tubbedII
needs more $$$
tubbedII's Avatar
That watts link does look good on there. I see you welded it on, but would it have been easy to bolt it up as well? Would you have had to drill/tap the notch itself to do so?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 03-11-2010, 02:48 PM   #237
67cheby
67cheby
67cheby's Avatar
i guess you could do it before you welded the notch together, but than placement would be an issue??? so i just welded it on !!
Old 03-11-2010, 09:02 PM   #238
c10seconds
c10seconds's Avatar
hey this is a sweet build! It will look great in silver. thats the color that i have planned for my 67. house of colors has a really nice bright metallic silver you should see if you havent checked it out yet. Anyways. cool truck
c10seconds is offline   Reply With Quote
Old 03-11-2010, 11:54 PM   #239
lolife99
67-72 parts collector,…
lolife99's Avatar
Do you think the bars just needed the threads cleaned out with a tap, prior to installing the heim joints?
Or was there another problem?
Keith
Convert to disc brakes.
Old 03-12-2010, 01:27 AM   #240
GVizzle
GVizzle's Avatar
Well its been a toss up to figure out what to use to center the rearend... Just bit the bullet and ordered the KP Components watts link... i hope i like it
Hey Cheby,
What made you go with the watts link, instead of the pan hard bar?
Also, how high is your truck for "ride height"?
Thanks for all the updates, looking good.
GVizzle is offline   Reply With Quote
Old 03-12-2010, 10:36 AM   #241
67cheby
67cheby
67cheby's Avatar
i will check out HOK silver thanks, i like the look of the watts link, ride height 4 1/2 inches off of the ground..... That said heres a little progress from last night, working on my compressor mount and bed mount bars
Old 03-12-2010, 10:37 AM   #242
67cheby
67cheby
67cheby's Avatar
couple more
Old 03-12-2010, 10:39 AM   #243
67cheby
67cheby
67cheby's Avatar
on the watts link heims, i probably should have chased the threads but i didnt have a tap that big, i put them in and out several times with all kinds of lubricants but still didnt help
Old 03-12-2010, 11:26 AM   #244
FnLow69
FnLow69's Avatar
looks good man. funny, cause the other day i was thinking how i was going to mount my bed and i came up with excactly what your doing. lol
FnLow69 is offline   Reply With Quote
Old 03-12-2010, 11:44 AM   #245
67cheby
67cheby
67cheby's Avatar
by the end of next week all of the back should be done, i am going to x across the front bed mounts and hang my air tank from it on driversde and exhaust from pass side, there will be mounting tabs welded on for the bed mounts
Old 03-12-2010, 11:51 AM   #246
Impalapawpaw
Impalapawpaw's Avatar
Love this Build.Alote of good info ,Great work
Impalapawpaw is offline   Reply With Quote
Old 03-12-2010, 11:54 AM   #247
SATownChevy
SATownChevy's Avatar
looking good dude. im in the process of tearing down my 68. after looking at your pics, i might consider raising my floor.
you make it looks so easy. waiting for more pics.
View pics of my truck - 1968 Chevy C10 SWB - Photobucket
I'm not wasting money on my truck, I'm helping to rescue the economy one mod at a time.
SATownChevy is offline   Reply With Quote
Old 03-12-2010, 11:56 AM   #248
67cheby
67cheby
67cheby's Avatar
Thanks to all for the encouragement when you have been working on one this long it really does help to have a "SUPPORT GROUP"..... I say "SUPPORT GROUP" because this is an ADDICTION !!
Old 03-12-2010, 12:01 PM   #249
SATownChevy
what hood hinges did you get? they look..........interesting.
Old 03-12-2010, 12:08 PM   #250
67cheby
67cheby
67cheby's Avatar
Porterbuilt hood hinges, nice set up relatively inexpensive
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
