Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 11-07-2010, 05:02 PM   #226
msgross
msgross's Avatar
Re: Project: Custom 71 4x4 hotrod
NV4500/np205 tranny setup would be nice too....
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-07-2010, 10:52 PM   #227
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I think it would be fairly easy to make some stainless u bolts if you can find some long stainless bolts with about 2" of threads or less, cut the head off, thread the other end then bend the center.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 11-07-2010, 11:22 PM   #228
silver7
silver7's Avatar
Good idea. I'll keep that in mind if I can't find any already made. Thanks.
Shawn
1971 C10 4x4
silver7 is offline   Reply With Quote
Old 11-10-2010, 08:01 AM   #229
silver7
silver7's Avatar
My Yukon Chrome Moly axle, super joints and 12 bolt yoke order arrived last night. Problem is they sent me OEM U-joints and a cast OEM yoke.
Shawn
1971 C10 4x4
Old 11-14-2010, 02:24 PM   #230
silver7
silver7's Avatar
Guys - I need some advice. I got my axle w/ U-joints together and was trying to get my knuckle with spindle mounted but could not get the top ball joint into the axle housing yoke. How is this usually done? It seems like the top ball joint is in the way - was I supposed to install this after the axle was installed through the knuckle?
Thanks in advance for any help.
Shawn
Shawn
1971 C10 4x4
Old 11-14-2010, 07:29 PM   #231
silver7
silver7's Avatar
Powerdriver 1958 got me straight. I had to remove my spindle from the knuckle and insert the axle through the hole. The grease fittings had to be removed from the U-joint due to clearance issues. Other than that and some finessing of the bolts went on fairly easy.
Shawn
1971 C10 4x4
Old 11-15-2010, 03:09 AM   #232
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Do you have the inner bearing and seal on the inner spindle for a reason, mock up or something?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-18-2010, 08:31 PM   #233
freakshow108
freakshow108's Avatar
Silver7, love the progress, its coming along nicely! What are you doing for the rear brake lines now that you have disc's? ive done the same with mine and have an idea on how to run them but would love to see your design. ive installed a stainless set of lines from inline but will have to modify the rear lines for the new callipers, just wondering how you will accomplish this on yours. thanks for any help and keep up the work, its looking bada@$!
freakshow108 is offline   Reply With Quote
Old 11-20-2010, 07:48 AM   #234
silver7
silver7's Avatar
Thanks for the kind words Freakshow. Unfortunately, I haven't gotten to my purchasing my brake lines yet. I figured I would probably buy a stainless kit from one of the top 3 suppliers. What did you have to modify to match your rear calipers?
Shawn
1971 C10 4x4
Old 11-20-2010, 10:44 AM   #235
freakshow108
so far i am only in the planning stage. im leaning towards having a local shop make up some stainless braided lines and adapt them to the hard lines that came in my kit. ill keep you posted with some pics if available.
Old 11-20-2010, 04:20 PM   #236
silver7
silver7's Avatar
Anyone know where I can buy a new front brake dust shield for 71 K10? LMC only carries them for C10 and can't seem to find them anywhere for K10. Napa does not carry them either. I'm going to try car-part.com and if that doesn't work try pull-a-part.
Shawn
1971 C10 4x4
Old 11-20-2010, 11:52 PM   #237
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Try classicindustries.com. It looks like you need either G3117(RH) or G3118(LH), Here's the left one: http://www.classicindustries.com/con...&currentPage=1 , I couldn't get the other one to show up so you might need to call them if that's the one you need. I took a picture from my catalog so you can see all the ones they had listed.
Tony
Old 11-21-2010, 12:28 AM   #238
Dieselwrencher
Hey guys, have any of you thought about zinc plating your u-bolts? We used to do that to lifted trucks that might see show time.
Ryan
Old 11-21-2010, 12:38 AM   #239
silver7
silver7's Avatar
Dude, this is perfect. Thanks!
Shawn
1971 C10 4x4
Old 11-21-2010, 12:40 AM   #240
silver7
silver7's Avatar
I was considering that as an alternative but definately prefer stainless if I can figure out how to make it work. Thanks.
Shawn
1971 C10 4x4
Old 11-21-2010, 12:53 AM   #241
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Your welcome! Are yours the real thick ones that are a dust shield/ disc brake mounts all in one?
Tony
Old 11-21-2010, 11:32 AM   #242
silver7
silver7's Avatar
Yes they are!
Shawn
1971 C10 4x4
Old 11-22-2010, 11:39 PM   #243
silver7
silver7's Avatar
70BLAZERx2 sold me a good set of front brake dust covers off a 73 K10 so I should be good to go after thanksgiving.
Shawn
1971 C10 4x4
Old 12-02-2010, 08:58 PM   #244
k5xjfiles
Junior Member
k5xjfiles's Avatar
Subscribed!! Awesome project...
72 K5/10/20 Hybrid 350, 465/205 44/14 bolt 35s, Detroit locker
89 XJ Pioneer, 4.5" 32s.
98 ZJ DD.
Parting..87-01 Cherokees
I bore throttle bodies-PM me for details!
k5xjfiles is offline   Reply With Quote
Old 12-04-2010, 01:37 PM   #245
silver7
silver7's Avatar
Thanks. Here are some updates.
Rear brakes - The rear brake conversion kit originally came with 'plain Jane' rotors but I wanted drilled and slotted rotors. Eventually I talked the guy into selling me the kit for $200 with calipers, pads, brackets and misc hardware - minus the rotors. I then bought my drilled and slotted rotors only to discover the rotors were too thick. After trying thinner pads and speaking with him we discovered his kit rotors were 1.0" thick and mine were 1.25" thick. I was able to exchange my Summit rotors for Power Stops (drilled but not slotted), due a little sanding on my pads and everything came together.
Front Hub assembly - I bought new Yukon Chrome Moly Alloy axles and super U-joints and installed them. Powdercoated my spindles and hub, installed the bearings and races and went to install and realized I forgot my brake dust cover/caliper brackets. My originals were shot so I bought a set of the thicker set from a 73 K10. These have been received and are awaiting sand blasting and paint. When completed I can finish assembling my front end.
Engine - Block is getting hot tanked over the weekend. Plan to epoxy primer it when I paint my other parts so it will be clean and ready for engine pre-assembly when I shift off the chassis.
12 bolt pinion yoke - Bought a forged 12 bolt pinion yoke from Yukon since it is now the weak point in my rear-end set-up.
Steering gear - One of the few original parts I plan to reuse. Drained, degreased and wire wheeled it this week. Got one of the pitman-arm pullers from O'Reillys and plan to remove the pitman arm this weekend.
Tie-rod and steering stabilizer stainless U-bolts - I discovered Totally Stainless sells custom made U-bolts (page 3 of catalog). I plan to measure what I need and order them once I get my hub, pitman arm, tie-rod and tires installed.
Painting - I already have some base Honda Rio Red and bought some single stage Kirker Jet Black. As soon as possible I plan to prime, base and clear my engine (epoxy prime for now), transfer case (epoxy prime), steering gear (black), pitman arm (black), pinion yoke (black), front brake caliper brackets (black), and front and rear brake calipers (red). Unfortunately, I haven't bought my new Autogear Muncie M22W 4-speed yet. But I'll probably paint my engine, transmission and transfer case the same color as my exterior truck color once I decide what that will be. The 2011 Harley Davidson Cool Blue is a color I am considering. D. Passmore bought my TH350 transmission so he should be picking that up in the next month or two.
Shawn
1971 C10 4x4
Old 12-04-2010, 03:15 PM   #246
MTCK
MTCK's Avatar
Great build - I'll be watching this one. I[m not a big big-rim fan but those look pretty cool!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 12-04-2010, 04:17 PM   #247
silver7
silver7's Avatar
Thanks. I searched long and hard for these and feel really good about how they look with my plan for the truck. In my humble opinion the 20" rims look good on a 35" or larger tire. I'm not a big fan of tiny little rims which give a rounded side wall when viewed from the front or back. 35" or larger diameter tires on 15 - 16" rims just look wrong to me. They look like big marshmallows going down the road.
Having said all of that, I certainly understand a 6" lift, traction bars and 20" Diesel XD rims on 35" Nitto Mud Grapplers isn't for everyone, especially the purists. "To Each His Own."
Shawn
1971 C10 4x4
Old 12-05-2010, 10:41 AM   #248
BIG HEAD
Wink Re: Project: Custom 71 4x4 hotrod
I believe the drilled rotors are directional. And from the looks of the picture of your front you are showing right rotor on left side. I may be wrong just tring to help. Looks great.
MY POND TRUCK BUILD http://www.67-72chevytrucks.com/vboa...d.php?t=297393
BIG HEAD is offline   Reply With Quote
Old 12-05-2010, 12:05 PM   #249
silver7
silver7's Avatar
Hey, I'll take all the help I can get. I'll definitely take a look - thanks Big head. Good news is I have to take it apart anyways to get my brake calipers installed that I forgot. . .
Shawn
1971 C10 4x4
Old 12-06-2010, 11:58 PM   #250
MTCK
MTCK's Avatar
Yeah I totally agree on the 'to each their own' thought, and you have totally nailed the theme on the build so far. The chassis looks amazing and it all just works, from the red powdercoating to the rims and the slotted/drilled rotors. I can't wait to see the body and drivetrain go in. You can tell when something has been thought out like this build.
-Marcus
Project Plow Truck
