#226 |
![]() ![]() Join Date: Jul 2002
Re: Lost My 65
subscribed
#227 | |
The 60-66 GMC/Pontiac guy....
Re: Lost My 65
As for disks on the torsion front clip, never seen them. Doesn't mean they don't exist of course but from my limited experience, disks are why most guys abandon the torsion front. Well, that and air bags. Best of luck my friend ![]()
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#228 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Lost My 65
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#229 |
It really is cool that you got it back after all this!
#230 | |
Re: Lost My 65
Sounds like a plan... ![]()
#231 |
Re: Lost My 65
I've been away for a while and missed the part where you got her back. I went back and re-read the entire thread and what a great story. Congrats! I will be following your build thread too just so I can see what becomes of her. Again great story, congrats and thanks for sharing!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
#232 | |
Re: Lost My 65
Welcome back
#233 |
Senior Enthusiast
Re: Lost My 65
I like your plan. It's a lot easier to maintain enthusiasm for a truck project that can actually be driven, or at least remains self propelled. And a non-running disassembled project is far more likely to go down the road if an unpredicted life event occurs, like marriage, kids, etc. I'm looking forward to the updates as the rebuild progresses.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#234 |
Re: Lost My 65
I couldn't wait another day.
I moved the 66 out of the barn/shop into the Costco Carport, and moved my 65 in. ![]() We had about 5" of snow a few days back, and it caused a big mess. We live within a semi-forest of Douglas Fir Trees, and as every year, we lose lots of branches. This time huge ones came crashing down and busted up our back covered area. This made me very concerned. The costco carport may keep my truck dry, but it surely won't stand up to big fir tree branches. So I didn't want another weekend to go buy without getting my 65 into my barn/shop. It's actually a good day.... Got my 65 back and ready to start turning bolts I haven't turned for over 25 years. ![]() As I mentioned earlier, I will concentrate my efforts toward first getting her to be a mechanically trustworthy driver. Then I'm going to see about getting a quart mixed up to match this color, and will just seal up the real problem areas. Maybe do some patch panels here and there, and minor body work, but definitely nothing major. I want to be able to drive her to work and back on really nice days this summer. Then, this winter I may dig into her deeper. This is what the paint looks like wet - I like it. ![]()
#235 |
Senior Enthusiast
Re: Lost My 65
A couple of suggestions regarding Costco tent/garages – if you live in a windy area make sure the frame is well tethered. If nothing else use ratchet straps to hold the inside corners to the truck bumpers. This will keep it from flying. Also anytime there is more than a few inches of snow, use a snow rake to remove it as quickly as possible. We had a bad storm a couple of years ago and lost every tent/garage in the neighborhood on the same night – they all caved in. Either the roof tubing collapsed and folded in, or one wall bent inward until the whole thing fell to one side. And if the tubing holds up, enough snow can stretch the fabric until it sags up to 18” between the rafters. This pulls the edges inboard and allows the drainage to run inside the walls.
When they fly, flip over, or cave in they can cause a lot of damage. Ours were triple staked and strapped to concrete, but after losing 3 in five years we finally gave up before anything really bad happened.
#236 |
Re: Lost My 65
What is this rear end?
Is it a good rear end? Are parts available? What gear ratio options? ![]() ![]() ![]()
#237 |
Re: Lost My 65
Nevermind... I figured it out searching the forums.
It's an Eaton HO32
#238 |
![]() Join Date: Mar 2011
Re: Lost My 65
I'm surprised to see this rear axle in your '65, I thought they were all 12 bolts by '65. It's the same 10 bolt that my '60 had and I have been told by many sources to get rid of it....FAST. I am putting a 12 bolt in with 3.73 gears.
http://67-72chevytrucks.com/vboard/s...d.php?t=456437 |
#239 |
Re: Lost My 65
My 65 is setting on a 62 frame.
It's what was available for me back in 84 when I built my truck back up. Posted via Mobile Device
#240 | |
![]() Join Date: Oct 2009
Re: Lost My 65
ditto... gonna follow along for the ride. and adding my congrats for successfully finding the old obsession and making it a new one. |
#241 | |
Re: Lost My 65
I am so anxious to really get going on this. I have my 6 lug discs and drop spindles and such on order. Once those arrive I'll start a build thread. Posted via Mobile Device
#242 | |
Re: Lost My 65
My neighbor has a 62 with that same rear diff that went 332,000+ miles and when he had the rear gone through last summer and asked the shop to replace everything and the shop told him it would have lasted even longer but the neighbor opted to do the rebuild anyway since it was already out. The shop updated the rear with heavier duty parts and gave him a 3 year 30,000 mile warranty. The neighbor runs a 283/auto. Point is, you can update what you have. Just my opinion.. I am looking forward to following your build ![]()
#243 |
Re: Lost My 65
Are the gears easy to swap out?
#244 |
Re: Lost My 65
For a 10 bolt, what the vendor did was update the original housing my neighbor has with later model carrier and other internals.
According to that shop/vendor, the only thing left original were the axles and housing. (he, my neighbor, did a disk conversion later.) I only have build experience with 9 inch and old Olds/Pontiac 3rd member style rear ends so I don't know how "easy" it will be to swap out anything. However, it couldn't be all that hard. Because of my neighbors truck, I know it is possible.
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() Last edited by 66-PMD-GMC; 03-26-2012 at 11:19 AM. Reason: spelling/grammar |
#245 | |
"Where were you in '62?"
![]() Join Date: Jul 2004
![]() Quote:
3.08 gear ratio. But the shipping would be crazy ha ha. Posted via Mobile Device
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#246 |
![]() Join Date: Jun 2007
Re: Lost My 65
Great story! Just read through the whole thread.
1966 427 biscayne with a 5 spd tremec on old school torque thrusts. 1972 Cheyenne Short Bed 1958 Apache short fleet 1980 Chevy short bed http://67-72chevytrucks.com/vboard/s...d.php?t=761005 1959 "Henry" http://67-72chevytrucks.com/vboard/s...d.php?t=670461 1966 Biscayne http://67-72chevytrucks.com/vboard/s...d.php?t=444419 1972 Suburban http://67-72chevytrucks.com/vboard/s...d.php?t=478828 |
#247 | |
Re: Lost My 65
![]() Posted via Mobile Device
#248 |
Re: Lost My 65
Thanks. All my friends can't believe I tracked down and got it back. I walk out quite often and put my hand on the hood - just to touch it.
#249 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Lost My 65
So you are saying that your neighbor, had a shop install a different model of 10 bolt carrier and gears into a Eaton HO32 housing? I have not heard of this before. Do you have any info as to what the application of the parts are?
#250 | |
Re: Lost My 65
